Old 11-18-2016, 02:18 PM
CollegeProject CollegeProject is offline
Clipping issue
Can someone with an hd300 confirm if this table clips to the left as you scroll. It should clip and immediately redraw the missing.It does on the shield and I am trying to see if it's just with it or with any extender. Stuckless is crazy busy guy so trying not to bother him to see if the it's on android only or not.
Import it into the default STV should add a menu item then see if as you scroll it clips to the left. I am noticing this that if I move a widget with an animation widget it will clip at the original bounds before the animation widget moved it. But it doesn't appear to happen on the computer as far as I can tell.
I don't have a hd300 to test only an android device.
Please only those that know how to manually import and unexport stvi's.
Thanks for anyone that looks.
clipping /error on big text CollegeProject SageTV Studio 8 11-03-2016 02:28 PM
Hauppauge 1600 Audio Clipping? Skybolt Hardware Support 8 10-25-2011 07:26 AM
DTS 'clipping' srcurtis SageTV Beta Test Software 0 09-27-2010 05:00 PM
PVR250 Audio Clipping srcurtis Hardware Support 5 01-25-2005 05:52 AM
