Old 02-21-2017, 10:26 AM
sigl sigl is offline
Metadata not found for French recordings
Hello,
I found that BMT does not find any metadata from tvdb for French recordings.
I have included the phoenix.log file
I got the following error :
2017-02-21 11:08:37,358 [1128530239@qtp-1363870579-4] INFO  sagex.phoenix.metadata.provider.tvdb.TVDBSearchParser - TVDB Search: http://www.thetvdb.com/api/GetSeries.php?seriesname=Votre+beau+programme
2017-02-21 11:08:37,359 [1128530239@qtp-1363870579-4] INFO  sagex.phoenix.util.url.CachedUrl - Removing Cached Url File: ./userdata/Phoenix/cache/url/656859e8dbd3c201071c6f2f66f76281.cache
2017-02-21 11:08:37,591 [1128530239@qtp-1363870579-4] WARN  sagex.phoenix.metadata.provider.tvdb.TVDBSearchParser - Could not find any results for: CachedUrl: http://www.thetvdb.com/api/GetSeries.php?seriesname=Votre+beau+programme; UrlId: 656859e8dbd3c201071c6f2f66f76281; CachedFile: ./userdata/Phoenix/cache/url/656859e8dbd3c201071c6f2f66f76281.properties
2017-02-21 11:08:37,591 [1128530239@qtp-1363870579-4] INFO  sagex.phoenix.metadata.MetadataManager - No good matches for Votre beau programme will try other providers if available.
I tried directly on my browser : http://www.thetvdb.com/api/GetSeries...beau+programme and I got and empty result.
But if I specified the language in the command (&language=FR) I got the result.
http://www.thetvdb.com/api/GetSeries...me&language=fr
Same thing if I add &language=ALL
http://www.thetvdb.com/api/GetSeries...e&language=all
I saw in the source file "sagex.phoenix.metadata.provider.tvdb" the following lines
 private static final String SEARCH_URL = "http://www.thetvdb.com/api/GetSeries.php?seriesname=%s&language=%s";
private static final String SEARCH_URL_NO_LANG = "http://www.thetvdb.com/api/GetSeries.php?seriesname=%s";
I think you can send the metadata request using a language option but I cannot find how ? Is it in some config files ??
Old 02-26-2017, 06:55 PM
stuckless stuckless is online now
Did you set the TVDB language to "fr" in the BTM web UI. If you go into Configuration, search for tvdb, and set the language to "fr" it might work. The alternative it use the BMT matcher capabilities and create Matcher for your shows so that BMT will know how to do future lookups.
TV recordings and Metadata? btrupp SageTV Software 6 12-23-2013 03:03 PM
Metadata in french nox71 Phoenix 7 05-21-2013 09:12 AM
metadata errors on new recordings raklar Batch Metadata Tools 11 05-21-2010 03:47 PM
Composite Recordings Not Found - Where Are They? Chris99 SageTV Software 2 08-04-2009 09:38 AM
Scan Channels for french Tv => TNT INDIANS SageTV Software 1 12-02-2006 11:10 AM
