Old 03-11-2017, 11:12 AM
MattHelm MattHelm is offline
Not finding any metadata
I just ran BMT for the first time after updating to V9, and when searching for data for an impoorted movie, I get no data back. I did try to install and uninstall BMT. Here is the error in the sagetv_0.txt file:
WARN - WebUI Search failed for: SearchQuery [type=MOVIE, fields={QUERY: Doctor Strange,}, hints=Hints [hints=empty]]
MetadataException []
	at sagex.phoenix.metadata.provider.tmdb.TMDBMetadataProvider.search(TMDBMetadataProvider.java:401)
	at sagex.phoenix.metadata.MetadataManager.search(MetadataManager.java:321)
	at org.jdna.bmt.web.server.BrowsingServicesImpl.searchForMetadata(BrowsingServicesImpl.java:458)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
	at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
	at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
	at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
	at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:389)
	at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
	at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
	at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
	at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417)
	at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
	at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
	at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
	at org.mortbay.jetty.handler.rewrite.RewriteHandler.handle(RewriteHandler.java:230)
	at org.mortbay.jetty.Server.handle(Server.java:326)
	at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:534)
	at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:879)
	at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:747)
	at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
	at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
	at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
	at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:520)
Caused by: java.lang.NoSuchMethodError: com.omertron.themoviedbapi.TheMovieDbApi.searchMovie(Ljava/lang/String;Ljava/lang/Integer;Ljava/lang/String;Ljava/lang/Boolean;Ljava/lang/Integer;Ljava/lang/Integer;Lcom/omertron/themoviedbapi/enumeration/SearchType;)Lcom/omertron/themoviedbapi/results/ResultList;
	at sagex.phoenix.metadata.provider.tmdb.TMDBMetadataProvider.getResults(TMDBMetadataProvider.java:409)
	at sagex.phoenix.metadata.provider.tmdb.TMDBMetadataProvider.search(TMDBMetadataProvider.java:399)
	... 32 more
Old 03-11-2017, 09:28 PM
jusjoken jusjoken is offline
Check the jar folder and see if you have two themoviedb jars. Delete the old one 3.x when sage is not running.
k
Old 03-11-2017, 10:55 PM
OK, when I do the search, I don't have a source (it's blank). And the error is:
MetadataException [query=SearchQuery [type=MOVIE, fields={QUERY: Doctor Strange,}, hints=Hints [hints={update_fanart: true,update_metadata: true,scan_missing_metadata: true,scan_subfolders: true,import_tv_as_recording: true,}]], ]
	at sagex.phoenix.metadata.MetadataManager.search(MetadataManager.java:297)
Did I remove something I shouldn't, or did I not have a higher level jar?
Old 03-12-2017, 05:22 AM
If you don't have a source, then it's not going to work. I recall a post a week or so about something similar... If this is an upgrade, then check the jars folder, and see if you have any duplicate looking jars. And I wold re-install phoenix/bmt, since you should have exactly 1 source for tv and once source for movies.
Old 03-12-2017, 02:33 PM
Removed both twice, and I still get a blank line for source!!! Not sure what I'm doing wrong.
"themoviedbapi-4.1.jar" is the one I need, correct?
Old 03-12-2017, 03:13 PM
OK, got on my dad's old V7 system, and copied the file "themoviedb-3.0.1.jar" over to mine.
I'm back to this error:
	... 32 more
Old 03-12-2017, 04:20 PM
Yes...
After removing 3 again and restarting sage go to BMT but make sure the cache is cleared on the browser or use a browser you have not used for BMT and try the search again.
If these things dont work, then post the phoenix.log
k
Old 03-13-2017, 09:03 PM
Originally Posted by jusjoken View Post
Yes...
k
OK, did all that, and I still have no sources.
Here is the phonix.log
Old 03-14-2017, 05:21 PM
Sadly, your plugins are a mess ... there lots of duplicate jars in there for many things...
I would backup your jars and then start finding the dups and removing the OLDER version of files.
JARs\GoogleWeather.jar
JARs\RPAD.jar
JARs\SageTCPServer.jar
JARs\YouTube.jar
JARs\ant-javamail.jar
JARs\ant-launcher.jar
JARs\ant.jar
JARs\api-common-1.0.jar
JARs\api-common-2.0.jar
JARs\cling-core-2.0.1.jar
JARs\cling-support-2.0.1.jar
JARs\commons-beanutils-1.8.3.jar
JARs\commons-cli-1.0.jar
JARs\commons-codec-1.3.jar
JARs\commons-codec-1.9.jar
JARs\commons-dbutils-1.3.jar
JARs\commons-exec-1.0.1.jar
JARs\commons-io-2.4.jar
JARs\commons-io-2.5.jar
JARs\commons-jxpath-1.1.jar
JARs\commons-lang-2.4.jar
JARs\commons-lang3-3.0.jar
JARs\commons-lang3-3.4.jar
JARs\commons-logging-1.1.1.jar
JARs\commons-logging-1.2.jar
JARs\commons-net-1.4.1.jar
JARs\core-3.1.1.jar
JARs\cron4j-2.2.1.jar
JARs\dom4j-1.6.1.jar
JARs\fluent-hc-4.2.1.jar
JARs\gkusnick.sagetv.jar
JARs\google-api-client-1.20.0.jar
JARs\google-api-client-gson-1.20.0.jar
JARs\google-api-client-jackson2-1.20.0.jar
JARs\google-api-services-oauth2-v2-rev91-1.20.0.jar
JARs\google-api-services-youtube-v3-rev138-1.20.0.jar
JARs\google-http-client-1.20.0.jar
JARs\google-http-client-jackson2-1.20.0.jar
JARs\google-oauth-client-1.20.0.jar
JARs\google-oauth-client-java6-1.19.0.jar
JARs\google-oauth-client-jetty-1.20.0.jar
JARs\google-oauth-client-servlet-1.20.0.jar
JARs\groovy-all-2.0.5.jar
JARs\gson-1.7.1.jar
JARs\gson-1.7.2.jar
JARs\gtools.jar
JARs\gwt-servlet.jar
JARs\gxt.jar
JARs\h2-1.2.145.jar
JARs\hamcrest-core-1.3.jar
JARs\htmlparser-1.6.jar
JARs\httpclient-4.2.1.jar
JARs\httpclient-4.5.1.jar
JARs\httpclient-cache-4.2.1.jar
JARs\httpcore-4.2.1.jar
JARs\httpcore-4.4.3.jar
JARs\httpmime-4.2.1.jar
JARs\jackson-annotations-2.5.1.jar
JARs\jackson-annotations-2.6.3.jar
JARs\jackson-core-2.5.1.jar
JARs\jackson-core-2.6.3.jar
JARs\jackson-databind-2.5.1.jar
JARs\jackson-databind-2.6.3.jar
JARs\jcifs-1.1.6.jar
JARs\jetty-6.1.19.jar
JARs\jetty-ajp-6.1.19.jar
JARs\jetty-rewrite-handler-6.1.19.jar
JARs\jetty-sslengine-6.1.19.jar
JARs\jetty-starter.jar
JARs\jetty-util-6.1.19.jar
JARs\joda-time-2.8.1.jar
JARs\jpathwatch-0-93-rc1.jar
JARs\json-20140107.jar
JARs\jsoup.jar
JARs\jsp-2.1-jetty-6.1.19.jar
JARs\jsp-2.1.jar
JARs\jsp-api-2.1.jar
JARs\jsr305-1.3.9.jar
JARs\junit-4.12.jar
JARs\junit-4.8.2.jar
JARs\libgrowl.jar
JARs\livepvrdata4j.jar
JARs\livepvrdata_shared.jar
JARs\log4j-1.2.15.jar
JARs\log4j-1.2.17.jar
JARs\lucene-core-3.0.1.jar
JARs\lucene-core-3.6.0.jar
JARs\mail.jar
JARs\metadata-updater.jar
JARs\mjlib.jar
JARs\mjxml.jar
JARs\nielm_sageimdb.jar
JARs\nielm_sageutls.jar
JARs\nielm_sagewebserver.jar
JARs\nielm_sagexmlinfo.jar
JARs\phoenix.jar
JARs\sagealert-common.jar
JARs\sagealert.jar
JARs\sagex-api.jar
JARs\sagex-h2.jar
JARs\salicense.jar
JARs\sbbi-upnplib-1.0.3.jar
JARs\seamless-http-1.1.0.jar
JARs\seamless-util-1.1.0.jar
JARs\seamless-xml-1.1.0.jar
JARs\servlet-api-2.5-6.1.19.jar
JARs\sjq-agent.jar
JARs\sjq-common.jar
JARs\sjq-listener.jar
JARs\sjq.jar
JARs\slf4j-api-1.6.0.jar
JARs\slf4j-api-1.7.12.jar
JARs\slf4j-log4j12-1.6.0.jar
JARs\slf4j-log4j12-1.7.12.jar
JARs\snark.jar
JARs\somf.jar
JARs\sqlitejdbc-v056.jar
JARs\sre.jar
JARs\themoviedbapi-4.1.jar
JARs\thetvdbapi-1.8.jar
JARs\twitter4j-core-2.1.2.jar
JARs\validation-api-1.1.0.Final.jar
JARs\vecmath.jar
Old 03-16-2017, 07:21 PM
Any idea what caused this?
When I get back home, I'll try and see what happens.
Oh, and thanks.
Old 03-16-2017, 08:23 PM
Oh, what about jars outside the JAR directory. I noticed I have a few older jars in other directories.
And what about removing all my plugins? I'm sure I have plugins I don't use anymore.
Imported Recordings not finding MetaData mgpaulus SageTV v9 Customizations 2 02-28-2017 04:07 PM
change metadata not visible from Raw Metadata JonTom Batch Metadata Tools 2 08-30-2011 03:53 PM
Finding Metadata for some files BobbyDing SageTV v7 Customizations 2 02-06-2011 12:36 AM
Clean out old metadata created by My Movies before creating new metadata for SageTV? Texas-Hansen SageTV Customizations 0 02-12-2009 10:31 AM
Finding My Music Whatsamobo SageTV Beta Test Software 23 04-30-2004 01:00 PM
