Old 04-30-2017, 04:21 PM
mike1961 mike1961 is offline
Playon and Netflix
Hello - a while back I was able to watch and record Netflix with Playon but it stopped working a while ago. I have upgraded to version 9 and I was wondering if there is a way to get this working. When I try to browse playon, netflix, genres it says there are no videos available.
Old 04-30-2017, 08:40 PM
MacDaddy MacDaddy is offline
I'm using PlayOn V4.3.5.18477 running on a Windows 7 PC. My Sage machine is running on the unRaid docker platform. Im using Gemstone with the uPnP plugin to allow access to PlayOn. I had to use the menu manager to add the uPnP menu in to my screen options (hit options once to bring up menu manager and then hit options again to enter "copy" mode).
I'm able to browse to PlayOn/Netflix/genres and see a listing. Are you on the latest version of PlayOn?
Frankentivo: iStar D-380HB, SuperMicro X107-F-O, Xeon 1270v3 CPU, Kingston 8 GB 1600MHz DDRR3L x 4
Tuners: 4 x HDHR OTA, 4 x HDHR3 OTA, 3 x HDHR Prime
UnRAID Pro: 1 x Samsung 500GB Cache, 5 x WD Red 4TB (1 Parity, 4 Data)
Extenders: 2 x HD-200, 1 x HD-300 on Atlona PRO3HD66m
Sage: V9.0.14.567 with OpenDCT on unRaid docker, Gemstone, BMT, Web UI, PlayOn, TiSage
Old 04-30-2017, 11:05 PM
I figured it out. I have to go into Playon first. For some reason at Online it shows Netflix and I can't go in there. I first have to go into Playon and then Netflix.
Old 01-01-2020, 09:35 AM
Deano Deano is offline
This thread is old, but completely applicable to what I'm trying to figure out.
I, too, am using Gemstone and would like to copy the UPnP browser to Gemstone. I pressed option once in the menu manager, and see something called "Copy Mode", but don't understand the options.
It's currently set to "Disabled", and I'm not sure what to select to get UPnP Browser to Gemstone. My choices are:
Main Menu
Video Folder Browser
File Browser
Enable Copy Mode Only
Anyone with some help?
Old 01-01-2020, 02:04 PM
jusjoken jusjoken is offline
Main Menu
File Browser
It looks like u found out how based on anther response...if not, let me know.
Old 01-01-2020, 02:31 PM
Whoops.....yes. I figured this out. Thank you for checking. I posted in the other thread.
Playon/Netflix issue bmac.to SageTV v7 Customizations 3 09-27-2013 07:00 AM
Playon & netflix paulie SageTV United Kingdom 10 03-29-2012 02:27 AM
Playon Netflix, framerate robjen1019 SageTV Customizations 1 02-14-2010 08:59 AM
PlayOn/NetFlix - can use w/remote? APillowOfClouds SageTV Customizations 8 01-12-2010 04:59 PM
HD Netflix Content with Playon fyodor SageTV HD Theater - Media Player 0 03-14-2009 08:04 PM
