Old 02-01-2019, 12:11 PM
rickgillyon's Avatar
Errors Thrown by BMT
BMT isn't automatically updating metadata, and when I check the log after telling BMT to update metadata in a folder I get a lot of these errors in the log:
Expression: If(bmt_api_IsBMTPluginInstalled(), "Enabled", "Disabled")
Fri 2/1 18:04:16.785 [EventRouter-0a0027000005@13cfd1a9] processUserEvent-UserEvent[anything] evtTime=Fri 2/1 18:04:16.785
Fri 2/1 18:04:16.786 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 61.
Expression: bmt_api_SetBMTPluginInstalled(!bmt_api_IsBMTPluginInstalled())
Fri 2/1 18:04:16.787 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:16.788 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:16.952 [EventRouter-0a0027000005@13cfd1a9] processUserEvent-UserEvent[anything] evtTime=Fri 2/1 18:04:16.952
Fri 2/1 18:04:16.953 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 61.
Fri 2/1 18:04:16.954 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:16.955 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:30.060 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:30.061 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:30.090 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
Fri 2/1 18:04:31.170 [EventRouter-0a0027000005@13cfd1a9] Parsing Error: Unexpected ")" at column 33.
I have had some permissions issues with other files this week (ffmpeg), so I don't know if this could be a permissions problem. Anyone? Any ideas how to track it down?
Also the "Automatic Metadata/Fanart" in clients' settings looks like the attached file, no options available.
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.1, tvHeadEnd for recording back end, OpenDCT, SDEPG, SageTV 9
Clients: 3 Nvidia Shields, 1 FireTV, 2 Android Miniclients (Amlogic S905X), 3 Win10 Pro PC Clients
Old 02-02-2019, 05:49 AM
Not sure where that is coming from. I searched BMT and Phoenix sources for 'IsBMTPluginInstalled' and I don't see any reference to that API.
This looks like it could be coming from another plugin.
When you say "BMT" do ou mean the BMT Web UI? Or you mean Phoenix Core Services (which is what actually does the fanart updating -- bmt web ui is just the UI part).
Old 02-02-2019, 05:57 AM
When I say BMT I say it from a position of ignorance. I use the BMT Web UI to try and kick off an update of metadata, but automatic updates fail too, so as you say the problem is probably core services. Have I posted in the wrong place again?
Old 02-02-2019, 06:10 AM
jusjoken jusjoken is offline
Found a reference to that here...
https://github.com/stuckless/customs...luginInstalled
Perhaps you are running a very old version of bmt?
k
Old 02-02-2019, 06:14 AM
Everything looks up to date in Plugins. Any idea how I remove all core services, BMT etc. and reinstall?
How Do I Correct Genre Errors and Fanart Location Errors ThePaladinTech Batch Metadata Tools 3 05-25-2010 12:26 PM
Errors in the log bastafidli SageTV Beta Test Software 1 05-21-2010 12:17 PM
SEEKER EXCEPTION THROWN:java.lang.OutOfMemoryError Flips SageTV Software 9 04-08-2009 08:13 AM
Java SEEKER EXCEPTION THROWN mayamaniac SageTV Software 3 04-26-2007 04:49 AM
OT: Mup.sys errors Kirby Hardware Support 0 08-21-2006 12:45 PM
