Old 01-19-2020, 07:00 PM
t4runnr t4runnr is offline
Unable to get metadata
Anyone else having issues with getting metadata for TV shows? This has been an issue for me in the last couple days.
When I search for metadata manually, BMT finds the series I'm looking for but then is unable to fetch the info.
This only happens with TV and not movies.
I'm using SageTV V9.
Old 01-20-2020, 07:21 AM
jt4242 jt4242 is offline
Yes, I'm having the same problem.
Old 01-21-2020, 09:23 AM
dstanley's Avatar
dstanley dstanley is offline
On January 9th TheTVDB.com made changes to it's system:
API Update: Removing legacy SSL support
I wonder if this is the problem with BMT and it would require an update?
https://forums.thetvdb.com/viewtopic.php?f=3&t=61687
Old 01-21-2020, 07:08 PM
That looks like the problem - I wonder if it can be fixed.........I really miss the feature.
Old 01-26-2020, 02:23 PM
mine is only failing on certain shows, for example westworld.
Windows 7 64bit Home Premium
1tb 3 disk Recording Pool
all in a beautiful Antec 1200
HD100/HD300 extenders
Old 01-26-2020, 03:44 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I'm pretty sure they only removed SSLv3. If your using Java 1.8 then it wont be the cause of the issue as by default it uses TLSv1.2
John
Old 01-29-2020, 10:29 AM
graywolf's Avatar
graywolf graywolf is offline
Same issues here but 95% sure Iím at Java 1.8.
Will double check this weekend
Old 01-29-2020, 12:51 PM
I confirm I'm at 1.8+.
"unable to get metadata" araomd Batch Metadata Tools 24 06-21-2013 08:26 AM
Unable to Get Metadata -- tvdb instafails aedgington Batch Metadata Tools 2 08-20-2012 10:05 AM
TV: "60 Minutes" (1968) - tvtbdb.com = Unable to get Metadata mkanet Batch Metadata Tools 11 12-19-2010 03:42 PM
"Unable to get Metadata" sdsean Batch Metadata Tools 19 10-22-2010 09:35 PM
Unable to play files with large metadata in SageTV7 Peter_h Batch Metadata Tools 16 07-09-2010 07:25 PM
