Lately I have not been tracking this forum.
If there is interrest I would not mind posting a message here when new functionality becomes available. In case you want to know more about how Comskip develops (such as support for HD and visual tuning tools) I suggest you monitor the Comskip forum at http://mk.kaashoek.com/comskip/ Latest release notes Quote:
Wow, thanks for the heads up
![]() I'll have to check this new TS support out tonight. |
Wow, i'm impressed with the newest comskip. It didn't do too well on HDTV 24, but it nailed HDTV Gilmore girls. Great work
No problem, i'll get you the info tonight.
I am using this newest version of comskip along with SageMC 16x9 STV and for some reason, it is not being run by SageTV automatically. Has anything changed in the syntax for running comskip that might have caused this?
If I revert to an older version, say .54 or so, everything works fine. Thanks for any help. |
Nothing has changed as far as I know.
Any possibility to log something? Other peope seem to be able to run the new version. Any particular directory path names? Do you know chich command line parameters are being used?
Support Comskip, visit the forum and donate at http://www.comskip.org/ |
It seems to have corrected itself after I updated to the beta version of SageTV. I'm not sure what the problem might have been.
Utility: Comskip 0.79 build 26: Three new detection methods
Comskip build 26 is available
There will be no support during the next couple of days. From the changelog Changes in 0.79.26 - Added scoring modifiers based on comparing this block to the average value of Brightness, Non-Uniformity, Volume, Non Silence and Scene change rate. - Added parameters to controll this scoring: punish, punish_threshold and punish_modifier, see ini file for details. - Added graphs in Debugwindow to show where parameters are above threshold for scoring, indicated by red lines. - Warning: Do not blindly enable these because you assume commercials are louder, brighter, etc... Do check your assumptions. I have not yet found a foolproof approach to have them always enabled. - No longer required to have Black Frame detection enabled. Certain recordings work better without them
Thank You
Utility: Comskip can also read DVR-MS and TS files
The newest Comskip release can read also DVR-MS and MPEG TS files.
The TS files must contains only one show, possibly in multiple resolutions and with multiple audio formats. The DVR-MS files must contain regular MPEG2 video and either MPEG2 or AC3 audio. More information is available on http://mk.kaashoek.com/comskip
Utility: Comskip
After some serious work on the MPEG decoder I think I have solved many of the audio/video synchronisation and timeline problems.
Some serious MPEG Transport Stream and DVR-MS testing could further improve Comskip so keep sending me your feedback. From the change log Changes in 0.79.32 - Added the BTV Smartskip output format, set output_btv=1 in the comskip.ini file to enable - Bug solved: AC3 sound volume is too high causing missing of black frames - Bug solved: Recording with 3/2 pull down has wrong frame numbers leading to incorrect cut points - Bug solved: The volume_slip default value is too low - Added parameter in ini file: ms_audio_delay=5 set to the number of frames audio lags video in dvr-ms files. Default value of 5 should be OK for most recordings.
made an error during building.
If your comskip.exe does not do anything but exit, download build 32 again.
Compared to ShowAnalyzer
Is this better than SA?
There are people who tried both, I rather have them comment.
The reason I ask is it seems SA is getting worse at detecting commercials and it seems from this thread that comskip is adding more detection methods, etc.
So if someone is using this newest version of comskip how is it working for you? Is it fast? The one thing I like about SA is the GUI. If I recall correctly comskip still relies on manually setting up a config file (?) |
Reboot at the GBPVR forum has been using both.
You could ask him
The only thing I notice is it shows maybe half a second of a commercial before it skips. Any user-end fix for this ? What do you mean................is it fast ? Overall I been more then happy with erik's comskip work thx Erik Last edited by Fluffdaddy; 04-16-2006 at 08:44 PM. |
Comskip Monitor: Announcement | Steep | SageTV Customizations | 340 | 09-26-2020 09:23 AM |
STV Import: Comskip Playback for Default STV (v1.5.4 30/August/2008 for SageTV 5/6) | JREkiwi | SageTV Customizations | 600 | 11-23-2011 07:58 AM |
Sage TV partial recordings and Comskip | garyellis | SageTV Customizations | 4 | 04-22-2009 04:33 PM |
Dirmon2 + Comskip + Mencoder | bnh | SageTV Customizations | 11 | 09-08-2008 06:40 PM |
Comskip & SageMC ? | raoul | SageMC Custom Interface | 17 | 01-27-2008 05:13 PM |
