Old 05-31-2017, 07:14 AM
dstanley's Avatar
dstanley dstanley is offline
Manual Comskip in Docker
Just noticed this error recorded in sagetv_0.txt when I try to manually run comskip on a recording from the SageTV UI:
Wed 5/31 9:04:59.186 [Fork-JREkiwi-616107@3db73520] Caused by: java.io.IOException: Cannot run program "/opt/sagetv/server/STVs/SageTV7/Externals/comskip.cmd" (in directory "/opt/sagetv/server/STVs/SageTV7/Externals"): error=13, Permission denied
Any ideas as to what may be happening and how to fix!?
Dwight
Old 05-31-2017, 07:27 AM
Dwight
It is trying to run a windows batch file - not going to work. I'm thinking you are using the old Comskip Playback plugin. I think the CommerciaDetecter UI contains some fixes for this. Try installing it and see if it launches properly.
Old 05-31-2017, 09:51 AM
dstanley's Avatar
Running the current SageTV Docker in Unraid
- under plugins it says the Commercial Detector and Commercial Detector UI are both installed as well as Comskip Playback.
So not sure what else to try - no big deal but curious why it doesn't work for me ...
EDIT - Just noticed under installed plugins the Detector UI was disabled - will check that out!
This is the error I am getting now:
Wed 5/31 11:55:29.209 [EventRouter-ac220b89f45c@2c13eacc] processUserEvent-UserEvent[anything] evtTime=Wed 5/31 11:55:29.208
Wed 5/31 11:55:29.215 [EventRouter-ac220b89f45c@2c13eacc] CD: SystemStatus: Number running = 1
Wed 5/31 11:55:29.216 [EventRouter-ac220b89f45c@2c13eacc] CD: SystemStatus: Jobs running = 1
Wed 5/31 11:55:29.216 [EventRouter-ac220b89f45c@2c13eacc] CD: SystemStatus:   MediaFileID = 30882080
Wed 5/31 11:55:29.216 [EventRouter-ac220b89f45c@2c13eacc] CD: SystemStatus:   Title : Episode = House Hunters International : Seeking the Center In Frankfurt, Germany
Wed 5/31 11:55:29.216 [EventRouter-ac220b89f45c@2c13eacc] CD: SystemStatus: No jobs in queue.
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] CD: ComskipJob.executeComskipLinux: comskip failed with return code = 2
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] java.lang.Exception
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] 	at tmiranda.cd.Log.write(Log.java:64)
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] 	at tmiranda.cd.ComskipJob.executeComskipLinux(ComskipJob.java:386)
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] 	at tmiranda.cd.ComskipJob.executeComskip(ComskipJob.java:173)
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] 	at tmiranda.cd.ComskipJob.executeUsingDefault(ComskipJob.java:187)
Wed 5/31 11:55:29.221 [Thread-77@1deb8866] 	at tmiranda.cd.ComskipJob.run(ComskipJob.java:130)
Wed 5/31 11:55:29.222 [Thread-77@1deb8866] 	at java.lang.Thread.run(Thread.java:745)
Wed 5/31 11:55:29.222 [Thread-77@1deb8866] CD: ComskipJob.adjustJobTime: Null Times.
Wed 5/31 11:55:29.222 [Thread-77@1deb8866] CD: ComskipJob.updateRatio: Old, Current and new Ratios 0.07721863:3.888889E-6:0.06949715
Old 05-31-2017, 06:32 PM
tmiranda's Avatar
tmiranda tmiranda is offline
Go to the Plugin configuration for CommercialDetector and make sure you have selected the option to run comskip natively. It looks to me that it's trying to run comskip the old way.
If that doesn't work please post more of the log so I can see what happened leading up to the error.
Edit: See next post. When I wrote this I didn't notice you were trying to run comskip from the UI.
Old 05-31-2017, 06:34 PM
tmiranda's Avatar
I don't think I ever updated the UI to make the "Run Comskip" button run comskip natively under Linux
Old 06-01-2017, 04:33 AM
EnterNoEscape's Avatar
It has been working for me in the SageTV Docker container.
Need help with OpenDCT on Docker willieb SageTV for unRAID/Docker 5 03-07-2017 07:36 AM
How are you running ComSkip in unRaid/Docker setups with v9? mgpaulus SageTV v9 Customizations 5 01-22-2017 05:53 PM
SageTV Server Linux with Comskip for Docker (and unRAID) Support Thread stuckless SageTV for unRAID/Docker 409 10-10-2016 07:22 AM
NASs? Docker? ThePaladinTech SageTV Github Development 10 08-16-2015 02:34 PM
Comskip Manual Skip not working ThePaladinTech SageTV Customizations 0 10-04-2010 11:33 AM
