External ATSC tuner recommendations
Hi. looking for a reliable, external, standalone ATSC ota tuner.
Unit must have HDMI, optical/coax audio and component outputs. NOT looking for a networked HDHomerun tuner, etc. Have one already. Preferably one which does a good job pulling in those distant channels. Planning to pair it with either a Colossus or HDPVR recorder. Thanks.
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
There is at least one listed on Amazon for a good price: https://www.amazon.com/3300STB-Conve...2797364&sr=8-6
I have no idea how well it works. Note that you will need a way of changing channels on the device, just as if it is a cable box.
For some reason, the HDHomerun network tuner I have produces stuttering video when accessed via Sage. But every other tuner in the house produces quality video. Can’t figure out why Sage is not handling the Silicon Dust feed.
I would simply add that you might want to get one that offers ATSC 3.0 support. This is a new broadcast method that supports 4k and it's the wave of the future. It's not currently available in most of the country, but it is coming and will eventually be the standard method for OTA broadcast. Since you are in the market for a tuner, you might as well get one that is compatible. It will be ATSC 1.0 backwards compatible as well, so you can use it now even if your market hasn't switched to 3.0
i7-6700 server with about 10tb of space currently SageTV v9 (64bit) Ceton InfiniTV ETH 6 cable card tuner (Spectrum cable) OpenDCT HD-300 HD Extenders (hooked to my whole-house A/V system for synched playback on multiple TVs - great during a Superbowl party) Amazon Firestick 4k and Nvidia Shield using the MiniClient Using CQC to control it all |
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.9.2, sagetvopen-sagetv-server-opendct-java11 Docker Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
All good points. Has anyone who owns a HDHomerun product found their tuners are weak compared to built-ins from Samsung, Sony, Vizio etc.?
I find it just the opposite they are much better as they have a built in AMP.. SageTV is not the best to see how well your tuners work... As I also get no signal sometimes even when using SageTV with OPENDCT ... but every other APP has no problem. I always use the HDhomeRun APP before saying the tuning is weak.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 09-30-2021 at 11:20 AM. |
I don't consider the HDHR a great tuner. When I was doing direct tuner comparisons I've had better experience with an ATI digital tuner (decidely superior) and a Hauppauge tuner on the same antenna. Martin |
OTA tuner recommendations | jjstok | Hardware Support | 9 | 09-14-2018 05:23 PM |
Tuner Recommendations? | TheraEdge | Hardware Support | 24 | 12-07-2015 09:02 PM |
OTA Tuner Recommendations | BarkOLounger | Hardware Support | 18 | 10-12-2015 04:10 PM |
Tuner recommendations please | LazyGun | Hardware Support | 1 | 09-28-2015 08:38 PM |
Better tuner (ATSC) than the HDHR v2? | stanger89 | Hardware Support | 20 | 01-31-2012 09:53 AM |
