Old 11-25-2007, 08:31 PM
chadman chadman is offline
Create .edl file with Comskip?
I just tried Comskip and it seems to work ok, but it only creates a .txt. I have edited the .ini file with output_edl=1, but I still only see a text file created. Am I missing something? I am pretty sure it is reading the .ini file because I have set verbose=0 to stop logging and that seemed to work. Chad
Old 11-25-2007, 09:28 PM
pseudonym's Avatar
pseudonym pseudonym is offline
Hi,
I found this thread in the Comskip support forums:
http://www.kaashoek.com/comskip/view...&highlight=edl
Quote from that thread:
Set output_edl=1
Drag and drop the previously generated .txt file on comskip.
Hit the 'W' key and comskip will generate the .edl file.
I didn't see anything that says it can happen automatically. You might want to do some searches over there and see what you turn up?
--pseudonym
Old 11-25-2007, 09:29 PM
toricred's Avatar
toricred toricred is offline
It does create it automatically, but the edl file isn't created until the process is completely finished. Did you wait for it to finish?
Old 11-25-2007, 10:40 PM
Well I have it working, but I had to use Comskip Monitor. I was using Dirmon2 before, but not sure why it did not work. I thought that I did wait until the file was done, but now that you mentioned that I might not have. Now that I installed Comskip Monitor I like it better anyway. I like how it has the option to run at scheduled times and I could not figure out how to do that with Dirmon2.
In the past I was using SA, but can not get it to work on one of my local channels that I record with a lot. I am hopping this might help.
Thanks, Chad
Old 11-26-2007, 01:25 AM
waltraud waltraud is offline
Hi,
you also need to set output_default=0 in compskip.ini
Martin
Main System: Athlon X2 +3800, Asus A8N-E, 4GB RAM, 1x 200GB SATA, 3x 400GB SATA, 1x 500GB SATA, Geforce 7600GT, 1x Hauppauge PVR500, 1x Hauppauge PVR150, SageTV 6.2.4, XMLTV+Clickfinder to XMLTV, Windows XP Pro
Bedroom: Hauppauge MVP
Old 11-26-2007, 04:39 AM
erik erik is offline
Setting
output_edl=1
should force the creation of the EDL file, no need to set output_default=0
Support Comskip, visit the forum and donate at http://www.comskip.org/
Old 11-26-2007, 05:58 AM
Thanks, Chad
Dirmon2 works, but you have to specify the ini cmdline option.
[Job Description 1]
Name = Comskip
Processor = C:/Program Files/SageTV/Comskip/comskip.exe
Targets Are Paths = 0
Targets Are Extensions = 1
Command Line Options = --ini="c:\program files\sagetv\comskip\comskip.ini"
Must Exist 1 = mpg
Must Exist Logic = OR
Must Exist 2 =
Must And Or Must Not Exist Logic = AND
Must Not Exist 1 = edl
Must Not Exist Logic = OR
Must Not Exist 2 =
Directory 1 = //sagetv-server/tv
Target 1 = mpg
Resources Needed = 33
Timeout Enabled = 0
Timeout = -1
Priority Boost Due To Job Description = 0
Priority Boost Due To Age = 1
Priority Boost Due To Name = 0
Process Subdirectories = 0
Wait Until File Is Finished = 0
Wait Until File Is Idle = 0
Wait Until File Is Not Growing = 0
Wait Until File Is Not Growing Time = 1
Wait Until Drive Is Idle = 0
Wait Until Drive Is Idle Time = 2
Hide Console = 1
Blackout Enabled = 0
Blackout Start Time = 0
Blackout End Time = 0
Old 11-29-2007, 10:06 AM
megamojo's Avatar
megamojo megamojo is offline
Make sure that you have the ini file in your recording directory(ies), not just where the comskip exe lives. It should output the edl file while processing is in progress, and if you set enable_livetv (or is is just live_tv?) to 1 it will process files as they are recording and output the commercials as it finds them instead of waiting until the processing is complete.
Old 02-05-2008, 07:53 AM
Steve52 Steve52 is offline
I think I am having the same problem with my install of comskip as the other posters above. I make changes to the .ini file that is in the same directory as my comskip.exe, but the changes do not seem to take. I set it to create .edl files and to not create .txt and log files, but it still creates them anyway. I have three SageTv recording directories. Do I need to place a copy of the revised .ini in each of my three recording directories for comskip to work properly? If this is the case then why does the install of comskip monitor ask for a path to the .ini file?
Central Sage Server Win 10 64 Bit, Three HD200, Two HD300, & One PC Client 18 TB storage. SageTv v9
Old 02-05-2008, 10:52 AM
No. But make sure in your comskip monitor ini file that you are calling out the correct comskip directory for your installation. Comskip monitor will use the comskip.exe from that named directory. If your making changes and using another direcdtory that is why you're having issues.
Utility: Comskip erik SageTV Customizations 278 04-14-2016 08:13 PM
Can an EDL file yield a VPRJ file without rerunning Comskip? dmiraclejr SageTV Customizations 4 08-12-2007 06:25 AM
SageTV Transcoder syntax for sage.properties file krasev SageTV Customizations 0 05-14-2007 06:51 AM
Force Delete a File mike1961 SageTV Software 4 03-12-2007 11:52 PM
