Old 06-06-2016, 10:26 AM
bialio's Avatar
bialio bialio is offline
EPG data issues
So if I try to use my original SageTV server key to configure guide data for a video source, I get a 'can't connect to server' error after searching for my zip code.
While using schedules direct, I have a LOT of channels that have NO DATA sprinkled in with actual programming details.
Are these known issues?
PHOENIX 3 is here!
Old 06-06-2016, 02:10 PM
jusjoken jusjoken is offline
Contact Narflex by PM to ensure your license is white listed....there have been a number that have not been which causes this issue.
k
Old 06-06-2016, 05:01 PM
You could also just keep trying to connect. In the past two weeks I've had it take me several days of trying before I would get through. Usually it just works right away but I have had some days where it doesn't.
Old 06-06-2016, 06:36 PM
tmiranda's Avatar
tmiranda tmiranda is offline
The EPG server is acting up. I get constant "Channel lineup lost from EPG server" errors.
Old 06-07-2016, 06:53 PM
CptKirk CptKirk is offline
Same, I've got no EPG data now as well.
SageTV running on: Win7 SP1 64 Pro
SageTV 9.1.9.778 (32 bit)
Java 1.7.0_80 (32 bit)
OpenDCT 0.5.29 (Comcast Music channels set to FFmpeg)
Clients: HD300 (x2)
HDHR3-CC Prime 20190621 (Comcast CableCard) - 3 Tuners
Hauppauge 1950 STB SD (USB-UIRT Zone 1)
Hauppauge 1950 STB SD (USB-UIRT Zone 2)
Old 06-08-2016, 07:03 AM
I reported this a while back got no response ..... so frustrating I went with Schedules Direct.
http://forums.sagetv.com/forums/showthread.php?t=63217
Old 06-08-2016, 10:11 AM
markds's Avatar
markds markds is offline
Same. EPG has the hiccups. On my fresh reinstall of v7 it took multiple attempts into the server to set up video source and retrieve DirecTv USA lineup.
hp intel quad 2.8Ghz 16GB ram Win 7 pro 64bit hauppauge 1250 usb/serial connect 15TR storage recording directv TRYING to get sageTV9 to install over 7 without the SERVICE keeping on blowing up
Old 06-08-2016, 05:10 PM
So is there anything we can do on our end to get this working again?
Or is it all on the server side?
Clients: HD300 (x2)
Old 06-08-2016, 05:23 PM
KryptoNyte's Avatar
There are some tips on what the user can do over in the ... EPG forum.
This thread has similar issues, and tips from Opus;
http://forums.sagetv.com/forums/showthread.php?t=62135
If you are using a valid license/key, the EPG server should be working, or you can post in that forum.
Old 06-08-2016, 05:34 PM
KryptoNyte,
Thanks for that link. I've got a valid license/key. I've been using Sage for years. v7 and now v9. Just started with the EPG no data a few days ago. I'll read through that thread and I hope I can get it working again.
Clients: HD300 (x2)
Old 06-08-2016, 05:40 PM
KryptoNyte's Avatar
Here is a direct link to Opus' guide on what the user can do if you haven't come across it already;
http://forums.sagetv.com/forums/show...704#post119704
If all else fails, submit a request for support, just be patient;
http://www.sagetv.com/request.html
Old 06-26-2016, 11:17 AM
stefano540's Avatar
stefano540 stefano540 is offline
debugging EPG issues
I have been a happy Sage user for 10 years, have 2 V7 active servers (windows XP , windows 7 and Windows 10) feeding multiple clients and decided to try V9 on separate, non production hardware.
Everything installed perfectly on Windows 10 and Linux version I also tried, but none were ever able to get an EPG. I clearly have 2 good, up to date licenses since everything in V7 works, but V9 doesn't.
This is the debug trace I get:
Sat 6/25 16:26:14.041 [AWT-EventQueue-0@928739] WarlockRipper logged in OK.
Sat 6/25 16:26:14.146 [AWT-EventQueue-0@928739] Repeated errors in communicating with server :java.io.EOFException
Sat 6/25 16:26:14.146 [AWT-EventQueue-0@928739] processOptionsMenu optionsMenu=default:BASE-85087|OptionsMenu:ServerConnectError
Sat 6/25 16:26:17.833 [AWT-EventQueue-0@928739] WarlockRipper logged in OK.
Sat 6/25 16:26:17.898 [AWT-EventQueue-0@928739] Repeated errors in communicating with server :java.io.EOFException
Sat 6/25 16:26:17.898 [AWT-EventQueue-0@928739] processOptionsMenu optionsMenu=default:BASE-85087|OptionsMenu:ServerConnectError
I turned off the firewall altogether, to no avail.
How do I make any progress ?
Thanks a lot,
Stefano
ASUS Z68MX-UDH2, Ci5-2500k @3.4GHz, 4GB , 2x2TB Seagate Pipeline, HDHR Prime, HDHR, Win 10x64, Sage 7.1.9
Clients: 1 HD 200, 1 HD 300, 5 PCs
Old 06-26-2016, 05:42 PM
weeber weeber is offline
I was having problems with this, and thought it was the EPG server, but it turned out it was me.
When I first converted from V7 to V9, I used my original Sage License key. I think I got this waaaaay back during the v2 days. Somewhere along the line (v5 or v6?), I got an upgrade key.
When I installed v9, I used my "original" v2 key for the EPG server. Wrong..my "upgrade" key was what was recognized.
Just something to be aware of.
Old 07-02-2016, 05:04 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
You should be able to use either of them...but when I did the whitelisting import; there's very old ones (or some bought through PC Alchemy) that I likely didn't end up including because they were stored some other place I no longer remember. You can always contact me with a PM if your key doesn't seem to be working and I can easily verify if its on the whitelist or not.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 07-02-2016, 06:13 PM
Thanks Narflex. My original key did come from PC Alchemy (that brings back memories), so that explains why it didn't work.
Old 07-03-2016, 07:38 PM
I can no longer connect
dropping you a pm
Windows 7 64bit Home Premium
1tb 3 disk Recording Pool
all in a beautiful Antec 1200
HD100/HD300 extenders
Request for pointer to alternate guide data plugin when Sage stops providing EPG data Savage1701 SageTV Customizations 3 04-29-2012 05:50 AM
Program guide data issues with HD in qam wolverines SageTV EPG Service 2 01-07-2009 08:48 PM
Zap2It & SageTV: Built-in data not affected; Alternatives for EPG data not included? Opus4 SageTV EPG Service 20 08-21-2008 06:31 PM
EPG no data issues pat_smith1969 SageTV Beta Test Software 2 07-29-2008 05:15 PM
Guide Data issues, multiple Line-ups ptaylor SageTV EPG Service 6 04-24-2008 05:34 AM
