SageTV EPG Service Discussion related to the SageTV EPG Service used within SageTV. Questions about service area coverage, channel lineups, EPG listings, XMLTV, or anything else related to the service or programming guide data for SageTV should be posted here. |
Unable to connect to SageTV Server
I am having a problem connecting to SageTV server to add capture cards (and I assume EPG data). I already have a card installed and have a full EPG but that will be running out soon if I cannot find the problem.
I opened up port "7760" in my firewall (I think - I am not very familiar with this) with no success. I also completely disabled the firewall and also had no success. I am clueless about what to try nexr. I obviously have an internet connection as I am wirtting this post. Lain |
Double-check your firewall, you may need to reboot it for the settings to take. I just checked the server and its up, and port 7760 is the correct one.
I had to reinstall to get it to work but I was able to save my wiz.bin file to this wasn't too painful. |
Ok, this has taken a strange turn. After I got sage working again I saved a copy of the properties file just in case. Today, I was "unable to connect" so I replaced the properties file with my saved copy so all is again well but I did not go into the properties file since saving the backup. It seems that SageTV is changing my properties file in a way the messes up the connection. One work around is to automatically replace the properties each night. Of course, that would mean backing up each time I made any changed to to setup. I will send you a copy of the bad file as soon as I finish writing this.
Lain |
