Old 09-29-2008, 07:25 AM
Jetracers Jetracers is offline
Cant play avi's in MY Videos
Here's the problem I have some AVI videos that I've been trying to play using sagetv interface however whenever i start to play the video it does nothing like it's on pause if I hit FF it jumps 10 seconds and does nothing else these videos play fine in other programs like VLC. So does anyone have any insight on whats going on. I'm using SageTV software version 6.4.8.184 and SageTVMC plugin version 6.3.7a-fix. thanks in advance.
Jet
Old 10-20-2008, 11:38 AM
Appeared to be a Codec issue, had to uninstall all codecs and reinstall. Then it started working again.
Setup: AMD Phenom II x4 940@3.0 GHz Processor: Gigabyte GA-M750SLI-DS4 Motherboard: 4 GB Corsair PC2 6400 Memory:
OS Drive 320 GB Seagate hard drive: Recording Drives 2x500 GB WDCaviar 64k Clusters, 1x1.5TB Seagate 64k clusters, 1x320 GB Seagate 4k Clusters, 1x250 Seagate external USB 32k Clusters:Tuners(w/5 setup for recording HD; 2 for SD content): 1 Hauppauge HVR-1600, 1 HDHomeRun, 2x Hauppauge HVR-1250; XP Pro 32 bit, SageTV V6.5.9 SAGEMC V6.3.8a
Old 11-06-2008, 07:38 AM
alan92rttt alan92rttt is offline
I had the same preoblem. I reloaded my codecs and its works fine now.
Play AVI file from DVD drive jusjoken SageMC Custom Interface 3 04-04-2008 03:34 PM
SageTV can't play its own converted videos GTwannabe SageTV Software 5 10-02-2007 02:37 PM
Compressed TV Shows Won't Play - Help!! infocus13 SageTV Software 10 09-06-2007 02:42 AM
can't play all videos anymore?? ChePazzo SageTV Beta Test Software 1 12-09-2006 10:16 AM
