Commercial detector on client
Hello, do i need to do or change something when i install a new client to use commercial detector? I have sagetv on a WHS server and I'm running a new client installation, i installed the plugin on the client but the current shows that has the commercial removed aren't showing.
Waiting for Sage 8. ![]() |
Or the drives have to be mapped on the client exactly as they are on the server. It's easier to just use UNC paths on the server though
Thanks!, I changed the recording directory path to UNC path but i still cant see the commercial detector, do i need to do any rescan? where?
New recordings should be OK but for old recordings you'll have to get the Sage core to update the database. There are detailed instructions on how to do this, just search for "UNC" and you'll find a lot of information.
I searched UNC and read the commercial detector wiki and i cannot find how to update the Sage core database. I did scan imported media but it didnt do the trick, how can i do it?
Basically sage needs to "see" the directory where the file used to be as empty. So let's assume your recordings were on D:\Recordings and now you have configured the recording directory to be \\MyServer\Recordings. Sage needs to see that D:\Recordings is empty.
Stop SageTV Rename D:\Recordings to D:\NewRecordings Create a new directory D:\Recordings and keep it empty Change your UNC mapping so \\MyServer\Recordings points to D:\NewRecordings Restart Sage Now when Sage starts it will see that D:\Recordings is empty and it will update the database with \\MyServer\Recordings. It may take Sage a few minutes to do the update. Make sure that you have configured the recording directory to be \\MyServer\Recordings and not D:\Recordings or D:\NewRecordings. Tom
Thanks tmiranda, I renamed the tv recording directory then created the old recording directory and leave it empty, then i enter sage tv and deleted some recordings that was showing "like 4-6", then i renamed again the directory where i have all recordings to leave it like it was but now i cannot see any recordings, i'm using UNC path on the server and the client.
And i'm getting a capture error in playback message when try to view livetv ![]()
Waiting for Sage 8. ![]() Last edited by gabrielcab; 03-27-2011 at 08:56 PM. |
I don't understand what you are saying. Why did you rename the directory again? What is the path of the old recording directory? Are there any files in it? What is the path of the new recording directory? Are there any files in it? What is the name of the UNC path and where does it map to?
You need to have D:\shares\Recorded TV defined as an import directory so sage can see that it is empty.
You should not define \\Server\Recorded TV as a recording directory unless you really want Sage to record to it. (Which I don't think you want to do.)
is it possible to have commercial detector use VPrj files? | freewheeling | SageTV v7 Customizations | 7 | 03-23-2011 01:26 PM |
Convert with Commercial Detector | rickybee | SageTV v7 Customizations | 2 | 02-26-2011 08:53 AM |
Commercial Detector/ Comskip & Playon Issue? | HTPCguy | SageTV v7 Customizations | 3 | 10-29-2010 11:07 AM |
Reinstalled Commercial Detector - Detection no longer working | Sl33man | SageTV v7 Customizations | 1 | 08-29-2010 09:44 PM |
How do I access Commercial detector ui ? | rnadeau | SageTV v7 Customizations | 2 | 08-21-2010 12:24 PM |
