Comskip Playback + Commercial Detector server/client
I use to run the STVi import for the comskip playback on my clients with Comskip running as a service on the server. But now I switched over to the built in plugins for better integration + updates. The problem I'm having is that the Commercial Detector plugin only runs comskip on recordings as / after they have been recorded. If I have a recording with a bad comskip file and i use Comslip Playback to delete the edl file, the only way to re-run comskip is to go to the server plugins page, go to the plugin's settings, then have it scan for recordings without comskip files. I noticed that Comskip Playback has an option for manually running comskip on a recording but I can't get it to work. It brought up a file browser for the server's file system and i pointed it to sagetv->sagetv->comskip->comskip.exe. But when I choose the "Run Comskip" option in the recordings menu it doesn't start the comskip process on the server. Does this feature only work from the SageTV interface on the server?
I think the manual comskip option only works if there is no comskip file already for the program your trying to comskip . Also it may not work if your trying to use it during one of the restricted times you set up for it but I am unsure on that one.
If you have a comskip file already generated for a show you can right click the show like your going to play it and click delete comskip files and then you can manually run comskip again. One other thing is if your recordings are crappy or have weather alerts or news banners running on the bottom of them, this could throw off comskip and not generate a good comskip edl file. Also I used comskip on placeshifter but I am not sure if I installed it via the placeshifter after installing it on the server. |
My problem is that I want to use the option in the Comskip Playback plugin to "Run Comskip". When I select that option once i have enabled it on a recording without a comskip file nothing happens. My SageTV server is running on a Windows Home Server. I'm logged into it via remote desktop and watching the process monitor and when I select that option nothing happens. I'm wondering if the "Run Comskip" feature in the Comskip Playback plugin doesn't work with a client - server setup.
Did you click one of the shows you want to comskip like your going to play the show and choose run comskip under that menu as the menu you posted the pic of is for the comskip settings.
You need to go to TV and select a show and a menu will pop up with the watch now option and if you look down the menu you'll see Run Comskip if the tv show you clicked has not been comskipped already. If the show you clicked has been comskipped already you wont see the Run Comskip option for it. |
You can do this from any SageClient, PlaceShifter or the server. Tom
EDIT: Quote:
Well the Commercial Detector UI plugin installed fine on my laptop but on my gaming PC it complains about a dependency. A bit odd as I can download the file it is complaining about just fine. To make google happy it says:
Plugin Client Install Progress: Done - FAILED - Dependency Install commercialdetector-Failed - Zip Extraction of http://tmiranda.googlecode.com/files/comskip-80.032.zip ![]() |
Try going to the "General" tab and installing the CommercialDetector plugin located there. If that works then go back to the "UI Mod" section and install that.
Commercial detector on client | gabrielcab | SageTV v7 Customizations | 10 | 03-29-2011 01:26 PM |
Convert with Commercial Detector | rickybee | SageTV v7 Customizations | 2 | 02-26-2011 08:53 AM |
Commercial Detector/ Comskip & Playon Issue? | HTPCguy | SageTV v7 Customizations | 3 | 10-29-2010 11:07 AM |
How do I access Commercial detector ui ? | rnadeau | SageTV v7 Customizations | 2 | 08-21-2010 12:24 PM |
ComSkip Playback STVi with Server -> Client | thegodfaza | SageTV Customizations | 4 | 08-09-2009 07:55 AM |
