Old 04-13-2016, 05:47 AM
NoodleNT NoodleNT is offline
No Data For Major Network Channels
Any way to force a guide update?
Old 04-13-2016, 06:02 AM
Thomas Wischgol's Avatar
Thomas Wischgol Thomas Wischgol is offline
If you have a the web interface installed you can force an update from the main page there. I am seeing the same issue though so there seems to be some problem with the EPG source.
Old 04-13-2016, 12:30 PM
zoundz zoundz is offline
Had the same problem and forcing an EPG update had no apparent effect. Following the instructions in this message http://forums.sagetv.com/forums/show...704#post119704 seems to have fixed it. Of course, YMMV.
Zoundz in Lake Arrowhead
Old 04-13-2016, 05:10 PM
tvmaster2's Avatar
same here, for the first time in a very long time, I'm showing assorted NO DATA areas throughout my listings.
Old 04-13-2016, 05:41 PM
Thanks, it looks like that fixed it for me. After removing the server_update_id entries and restarting the service the data eventually came back. Thanks!
Old 04-13-2016, 06:14 PM
Worked for me too... I had to delete both lines and then do an EPG forced update from the web UI. In about 10 minutes everything was back to normal.
Old 04-13-2016, 08:41 PM
tvmaster2's Avatar
you just remove the entries AFTER server_**_** and NOT the headings themselves, correct?
Old 04-13-2016, 09:06 PM
pvr599 pvr599 is offline
Same problem. Watching for responses to make sure I do it correctly.
Diehard SageTV User
Hardware:
Vizio M550NV 55",GA-H67A-UD3H-B3 LGA 1155, Intel i3, 4Gb DDR3, USB-UIRT, 2x Colossus, 1 HDHR, HD100, HD200
Software - Win7 64 bit, SageTV 7.1.9, Java v6, HD100 firmware v20100212-0, HD200 firmware 20100909 0
Old 04-13-2016, 10:13 PM
miloj miloj is offline
Worked for me too. You can remove the entire lines.
Old 04-14-2016, 05:16 AM
I did the entire line. It gets recreated when it starts back up.
Old 04-14-2016, 08:34 AM
barogers barogers is offline
Worked for me as well.
Old 04-14-2016, 10:41 AM
tvmaster2's Avatar
ok, thanks - that seemed to work as well. I forced an update after deleting the lines and restarting the service/sageTV
Old 04-14-2016, 07:06 PM
EdwardATeller EdwardATeller is offline
This worked for me. Thanks.
STV 9.1.5.683 / Vista Premium / Compaq Presario SR-5550F / AMD Athlon 64 X2 5400 / nvidia GeForce 8400GS / 3 GB DDR2 / 500 GB SATA / 1 TB SATA / M2N68-LA Motherboard / 2 x Hauppauge HVR-1250 / Hauppauge HVR-1600 / 2 x STX-HD100 / OTA
Old 04-14-2016, 08:02 PM
girbim girbim is offline
Thanks!!
It worked for me too. I deleted the one line that had 'server_update_id' and forced an update by toggling a channel in channel setup back and forth.
Old 04-15-2016, 07:16 PM
SteveW's Avatar
SteveW SteveW is offline
There is a caveat here, and I got burned by it last time. If you are like me for example on Bell Satellite and you have channels disabled in the channel manager for your line up (French stations, on demand Vu channels, NHL channels, channels you don't subscribe to, etc), when you delete the properties as mentioned in the above link, all channels in that lineup are enabled again.
Fortunately I wrote down this time what channels should be enabled based on my subscription before I wiped the properties out so disabling the ones I don't need / don't get should go a lot faster this time.
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, WD Green 2 TB x 1 and WD Red 6 TB x 2 for DVD/Bluray Rips, Music, Home Movies, etc., Sage 9.1.8.770, HDPVR x 2, BellTV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver
Clients: PC Client x 2, HD-300 x 4 (1 Using Netgear MoCA Coax Bridges), Placeshifter x 1
Old 04-15-2016, 07:26 PM
That sounds like you deleted more than just the properties containing server_update_id and expanded_until.
I've done this many times over the years and never had it reset any disabled channels.
Andy
Old 04-15-2016, 07:46 PM
SteveW's Avatar
Andy
I can confirm those are the only two entries I've deleted. I've done this process maybe four times I can think of over the last 5 or 6 years and the result is the same each time. I can send you a copy of the properties file if you wish so I can show you what the lines look like on my end.
Old 04-16-2016, 07:48 AM
KryptoNyte's Avatar
That is strange. I have done this procedure 7 or 8 times now on a couple different SageTV servers and I have never seen it re-enable channels that were previously disabled.
Old 04-16-2016, 07:40 PM
SteveW's Avatar
So here is an excerpt from my sage properties file. As per the FAQ, I deleted the "server_update_id" line and "expanded until" line.
Anytime I have ever done this, I've had to re-disable channels that I don't want showing in the guide from the lineup because they are either non english, PPV, descriptive video channels, etc.
I have bolded those two sections below. Am I missing something here as to why others don't see to have that issue?
Keep in mind the formatting gets a little mangled pasting into the forum page... "epg_data_sources/5427534/unavailable_stations=..." is actually all one line in the file...
epg/showcards_update_id=1460378903000
epg/zip_code=B2T1E7
epg_data_sources/5427534/applied_service_level=2
epg_data_sources/5427534/chan_download_complete=true
epg_data_sources/5427534/disable_data_scanning=false
epg_data_sources/5427534/enabled=true
epg_data_sources/5427534/epg_class=WarlockRipper
epg_data_sources/5427534/epg_name=Bell TV Digital - Canada (East)
epg_data_sources/5427534/expanded_until=1460924699820
epg_data_sources/5427534/last_run=1460838299820
epg_data_sources/5427534/provider_id=8829789
epg_data_sources/5427534/server_update_id=31558,1460709720;72603,1460709720;17609,1460709720;17608,1460709720;17610,1460709720;75971,1460709720;17615,1460709720;10984,1460709720;89925,1460709720;17628,1460709720;17629,1460709720;72638,1460709720;17639,1460709720;17638,1460709720;17642,1460709720;16545,1460709720;16544,1460709720;17648,1460709720;81282,1460709720;48815,1460709720;19556,1460709720;16320,1460709720;27190,1460709720;62092,1460709720;89876,1460709720;53502,1460709720;17563,1460709720;19515,1460709720;70520,1460709720;17594,1460709720;17595,1460709720;17593,1460709720;11832,1460709720;13264,1460709720;15176,1460709720;16135,1460709720;13266,1460709720;15181,1460709720;73549,1460709720;86816,1460709720;89009,1460709720;72484,1460709720;76863,1460709720;73963,1460709720;11779,1460709720;34200,1460709720;48727,1460709720;17417,1460709720;38061,1460709720;32723,1460709720;72517,1460709720;19596,1460709720;80173,1460709720;45733,1460709720;61998,1460709720;76921,1460709720;48742,1460709720;19631,1460709720;19630,1460709720;19629,1460709720;16244,1460709720;16020,1460709720;13834,1460709720;27503,1460709720;10036,1460709720;97312,1460709720;97315,1460709720;32795,1460709720;22564,1460709720;16001,1460709720;12222,1460709720;12223,1460709720;12892,1460709720;75031,1460709720;67405,1460709720;16063,1460709720;89701,1460709720;54743,1460709720;15085,1460709720;73467,1460709720;49338,1460709720;11220,1460709720;20714,1460709720;44792,1460709720;11182,1460709720;10106,1460709720;59119,1460709720;52247,1460709720;10105,1460709720;44794,1460709720;10104,1460709720;10111,1460709720;10108,1460709720;44784,1460709720;10097,1460709720;44786,1460709720;16088,1460709720;44788,1460709720;44790,1460709720;10100,1460709720;20709,1460709720;10091,1460709720;16064,1460709720;10088,1460709720;10094,1460709720;10092,1460709720;69551,1460709720;75117,1460709720;76221,1460709720;20675,1460709720;15024,1460709720;16098,1460709720;16100,1460709720;18805,1460709720;11156,1460709720;18808,1460709720;10050,1460709720;53711,1460709720;96507,1460709720;10145,1460709720;82747,1460709720;14926,1460709720;58882,1460709720;12045,1460709720;94289,1460709720;10135,1460709720;10128,1460709720;10130,1460709720;10131,1460709720;58890,1460709720;10142,1460709720;61078,1460709720;10136,1460709720;61079,1460709720;60123,1460709720;10137,1460709720;60121,1460709720;10116,1460709720;14947,1460709720;10118,1460709720;10113,1460709720;10112,1460709720;10114,1460709720;10125,1460709720;10124,1460709720;10127,1460709720;10122,1460709720;17693,1460709720;72270,1460709720;14863,1460709720;15939,1460709720;15942,1460709720;15941,1460709720;15940,1460709720;15993,1460709720;15995,1460709720;15997,1460709720;14909,1460709720;66500,1460709720;15990,1460709720;15991,1460709720;15976,1460709720;71332,1460709720;67476,1460709720;15981,1460709720;10191,1460709720;36844,1460709720;24771,1460709720;64549,1460709720;18990,1460709720;68827,1460709720;18168,1460709720;72093,1460709720;51981,1460709720;89425,1460709720;89424,1460709720;24804,1460709720;14786,1460709720;89422,1460709720;89423,1460709720;60734,1460709720;18141,1460709720;17046,1460709720;10392,1460709720;59663,1460709720;11474,1460709720;65619,1460709720;11460,1460709720;11456,1460709720;61628,1460709720;17143,1460709720;89378,1460709720;61568,1460709720;14724,1460709720;21489,1460709720;72139,1460709720;91855,1460709720;83116,1460709720;11502,1460709720;58646,1460709720;24514,1460709720;33725,1460709720;24525,1460709720;46245,1460709720;58630,1460709720;26829,1460709720;61557,1460709720;79782,1460709720;93825,1460709720;46217,1460709720;11325,1460709720;16910,1460709720;26783,1460709720;26780,1460709720;77420,1460709720;26779,1460709720;26776,1460709720;26777,1460709720;26772,1460709720;61474,1460709720;63639,1460709720;53128,1460709720;53121,1460709720;53120,1460709720;75456,1460709720;21351,1460709720;82984,1460709720;88515,1460709720;26785,1460709720;76792,1460709720;76799,1460709720;62890,1460709720;64831,1460709720;13365,1460709720;10724,1460709720;68012,1460709720;17406,1460709720;17400,1460709720;17396,1460709720;17398,1460709720;10626,1460709720;33382,1460709720;17389,1460709720;17388,1460709720;17390,1460709720;72895,1460709720;66858,1460709720;14492,1460709720;72844,1460709720;70676,1460709720;34313,1460709720;52745,1460709720;17344,1460709720;20455,1460709720;72804,1460709720;71729,1460709720;28055,1460709720;71733,1460709720;72780,1460709720;20431,1460709720;61777,1460709720;72769,1460709720;65995,1460709720;84445,1460709720;65990,1460709720;65988,1460709720;71785,1460709720;59521,1460709720;10518,1460709720;70827,1460709720;20358,1460709720;72705,1460709720;70809,1460709720;55097,1460709720;20362,1460709720;72729,1460709720;20373,1460709720;72723,1460709720;60645,1460709720;58494,1460709720;
epg_data_sources/5427534/unavailable_channel_nums=1453,1452,1455,761,1454,762,1499,983,1840,889,1721,1462,1170,1623,754,755,752,753,146,751,1463,1060,756,1451,
epg_data_sources/5427534/unavailable_stations=73682,16261,67190,44962,49543,49542,65025,49541,65024,49540,49539,49538,49537,49536,19520,19521,39080,20896,49547,67174,49546,49545,49544,20895,47857,20894,20893,20892,47858,49584,20891,20890,20889,58333,47840,47841,47842,27202,27201,91308,47848,47849,91306,47854,47855,48859,69287,89875,89874,89873,16336,68348,17564,62111,62109,96541,89906,17590,17591,17589,16374,16379,16378,16377,16383,16380,72468,16133,81202,90206,16393,73556,87894,20783,64241,69199,15209,34290,73578,16188,16187,69200,73571,69203,69204,73572,45820,73574,69206,69207,49498,49497,49496,60327,49502,49501,63040,49500,49495,68205,90119,61439,90118,61436,61434,61435,80167,61432,61433,90112,61981,76887,61431,90125,80168,90124,90123,90122,34234,73531,49535,49521,49520,67231,49523,49522,61377,20829,16498,76926,26204,26203,26202,26201,49519,26200,26199,49505,26198,49506,49507,49508,49509,16023,26550,12870,21735,16017,26554,60020,49030,67429,68531,26556,67448,67449,30354,90588,16000,74078,85862,16828,15098,16831,74083,75054,16827,55559,21707,20608,97311,15072,10107,31250,26614,26615,89611,21667,10109,26608,21674,10090,26597,10089,26592,26607,26606,26605,26604,52235,11185,21636,21637,21638,21639,21632,21633,21635,21640,21641,65385,18798,21642,65384,18799,18801,18800,16099,45867,26561,26563,53701,53704,74041,53705,19906,21615,21613,21612,89807,10170,89812,21626,89813,21627,89814,21624,89815,21625,89808,21630,89809,68384,10146,96509,21631,89810,21628,89811,21629,89820,21618,89821,49172,21619,89822,21616,89823,21617,21622,89817,21623,89818,21620,89819,21621,69466,10134,49195,58884,89824,58885,58889,10119,30258,88753,81006,16727,21545,21544,16731,21543,21542,16729,16732,22762,22760,82801,82802,82803,82814,22753,82815,22756,71348,22751,15984,15986,15987,15988,15989,15977,15979,15978,73275,45986,65531,15982,73271,14075,44425,44424,44427,44426,44429,44428,44431,53091,44430,65566,44423,44422,48288,44432,44433,44434,73198,44435,79632,44459,44458,44457,44456,15747,89427,89426,44455,89431,44454,89430,44453,89429,44452,89428,68859,68858,73141,73142,57735,17144,29093,73107,62670,58870,44529,19134,75451,88498,26827,15675,53242,15676,71974,15677,26828,74479,45298,49952,20203,26823,58634,29008,26872,76355,26873,33684,45249,27811,66793,18002,26782,45217,45218,26781,45219,26778,45220,24455,45221,45222,45224,26775,45225,26773,26771,26768,17956,26769,58688,45247,45246,72984,72988,15685,64721,72976,61443,61441,72980,61440,15682,72005,72974,68670,70104,72972,19141,72960,45215,26784,45214,26786,92074,91109,72940,48569,56105,69651,56109,69653,69652,26980,69655,69654,55264,26884,72865,72871,26882,26883,46463,72877,70699,56159,17384,17387,17383,17376,72892,17374,17375,17373,17369,56165,58592,45329,56161,56163,47502,45324,72857,22093,56194,22092,22094,22089,22088,22091,22090,22085,22084,22087,22086,68946,22081,22080,22083,18291,22082,20477,47475,81448,28755,49692,24935,28756,27125,21053,21063,22017,22016,22018,59546,61742,46575,17250,72755,66005,15463,59532,15462,66003,66001,75721,61714,22074,22075,22072,22073,22078,22079,22076,12445,22077,22066,22067,22065,22070,22071,22068,22069,88279,
event_delay_to_discard_max=100
event_delay_to_discard_min=100
Old 04-18-2016, 08:48 PM
I asked more about this because your server_update_id line is different from what I expected, but as far as we can tell, deleting only the 'server_update_id' and 'expanded_until' lines should have no effect on your disabled channels.
Maybe you are also affecting the 'unavailable_channel_nums' and/or 'unavailable_stations' properties; by accident if not on purpose.
I don't remember hearing from anyone else about disabled channels getting enabled after this process.
Andy
Dish Network PPV data Denali SageTV EPG Service 0 06-10-2010 01:46 PM
Big Ten Network Alternate/Overflow Guide Data redondo_se SageTV EPG Service 0 09-08-2008 10:48 AM
Sage TV 6 MAJOR, MAJOR issues pgman SageTV Software 35 01-22-2007 11:41 AM
DISH Network (Guide info no data) steingra General Discussion 2 04-01-2006 03:00 PM
losing data and network drives with 2.0 jbuszkie SageTV Beta Test Software 11 05-05-2004 03:32 PM
