Old 07-07-2008, 11:59 AM
Sizam Sizam is offline
MyMovies type of addon for SageTV?
Hi All,
Over the weekend I discovered MyMovies for VMC which gives you a nice interface to browse ALL your movies on your drives (standard DVD, BluRay, HD-DVD) and plays them by starting up PowerDVD 8 or 7 (and goes back to VMC after you quit PDVD). This is really awesome, especially now that my HTPC usage is about 60% HD shows/movies, 30% netflix WatchNow and 10% TV shows (via SageTV). Plus there is this VMCNetFlix which manages your NetFlix queue and WatchNow via VMC.
This double whammy is killing me as I don't want to use VMC (I prefer Sage), is there anything available for SageTV that is similar to MyMovies? I see there is already a netflix plugin so that helps!
Sam
Old 07-07-2008, 03:57 PM
Brent Brent is offline
Have you tried out the user-created SageMC replacement STV for SageTV? It has much of the functionality for organizing and viewing your movies in a way similar to MyMovies. MyMovies is better, but you probably can get what you need out of the SageMC STV - lots of other goodies in there too.
Old 07-07-2008, 04:12 PM
Yup,
I'm running SageMC right now, and it works very well for standard def movies but for BluRay and HDDVDs it needs to run an image-mounter for isos and PowerDVD to play the movie which I don't think it currently can. Please please correct me if I'm wrong.
Sam
Old 07-07-2008, 04:24 PM
I haven't gone Blu Ray with SageTV yet, but if you haven't already you might want to check out these two threads to see if they help at all
Thread 1
Thread 2
DVD Playback issues after Clean install Ender SageTV Software 6 05-03-2008 10:40 PM
Black screen and no audio on Client shatter SageTV Software 7 02-21-2007 08:41 PM
AUDIO not rendered. No source pin found! kminder SageTV Software 3 12-16-2006 08:30 AM
client 4.1.5 not showing livetv after reboot alon24 SageTV Beta Test Software 2 01-24-2006 12:09 AM
