Old 08-23-2010, 05:20 PM
Sl33man Sl33man is offline
MyMovies not compatible with sagetv core 7.0.15+??
Well I was going through my plugins and saw that the Mymovies plugins had updates, so I did just that. Now it says that there is a compatibility issue.
The plugins I'm trying to install are:
SageMyMovies 1.130 beta
SageMyMovies API 1.150 Beta
In both cases they list as "Not Compatible" and when I click on the "view plugin details" button it says: Incompatibility Reason: SageTV core version: 7.0.15+
This is the same message that appears for both
Is there something that I'm missing here? I thought if i ununstalled and reinstalled the plugin then perhaps this would resolve the issue, but no luck.
Any suggestions would be appreciated.
Wade
Old 08-23-2010, 05:23 PM
PLUCKYHD PLUCKYHD is offline
You need to be running the latest beta of sagetv version 7.0.15
Old 08-23-2010, 05:24 PM
Just to clarify there was an API change in that build that I needed for multi disc support and user restrictions it will not work without that.
Old 08-23-2010, 09:03 PM
ah thanks for pointing that out, I thought SageTV auto updated or at least prompt me for a update like the plugins do.
So I updated and the plugin installed well.
MyMovies for SageTV Awake Sage My Movies 5 08-04-2010 09:47 AM
To get a faster dual-core or slower quad-core? That is the question... robogeek Hardware Support 33 03-09-2009 08:33 PM
MyMovies type of addon for SageTV? Sizam SageTV Customizations 3 07-07-2008 04:24 PM
ERROR (-10)... Only with Quad core, not Dual core? jerryt Hardware Support 2 04-03-2008 07:13 PM
quad core vs dual core garyellis Hardware Support 16 03-13-2008 10:36 PM
