Old 04-04-2009, 01:36 PM
troycheek's Avatar
troycheek troycheek is offline
HD200 date/time display glitch (now with pics and log!)
Pretty much everywhere my new HD200 displays a time and date, it displays it wrong.
  1. Numeric dates are displayed in dd/mm form. April 1 is 1/4 instead of 4/1.
  2. Times are missing the AM/PM. 3:05 PM is displayed as 3:05.
  3. Names of days and months are left out altogether, though there is usually a blank area where they should be. Sat, Apr 4 3:36 PM comes out looking like 4 3:36.
And so on just about anywhere in the UI where a date or time is shown. It's like the time/date font is missing the letters and like the date is set in European mode instead of American.
I've tried SaveTV V6.5.12.208 and V6.5.13.209, Java 1.6.0_11 on the server. I've tried the HD200 with both the latest recommended firmware "20081230 0" and the beta firmware "20090403 0", both SageTV3 and SageMC STV with and without my favorite imports. Client PC with same STV and imports displays fine. I've changed every setting I can find to no avail. I'm open to suggestions. I've attached a log which shows some fails and hangs, but I don't know what to make of it.
Now with pics!
Recording detail (client/extender)
http://home.comcast.net/~troycheek/pics/detail.jpg
http://home.comcast.net/~troycheek/pics/detailhd.jpg
System info (client/extender)
http://home.comcast.net/~troycheek/pics/system.jpg
http://home.comcast.net/~troycheek/pics/systemhd.jpg
List of recordings (client/extender)
http://home.comcast.net/~troycheek/pics/recordings.jpg
http://home.comcast.net/~troycheek/p...cordingshd.jpg
Corner detail on the extender
http://home.comcast.net/~troycheek/pics/rechd.jpg
Old 04-25-2009, 01:58 PM
troycheek's Avatar
Who recognizes this language?
After deleting the server's client files (again) and resetting the HD200 (again), I finally got month names and AM/PM to start displaying. However, they are in a language I don't recognize:
In addition to all times and dates, under UI Language, when I choose English from the list, instead of English, it tells me I selected a squiggle. The German, Italian, etc appear to be correct as well as I can tell.
I vaguely remember seeing a font like this when I first installed Windows XP. During the installation, Windows somehow got the idea that I lived somewhere in the Middle East and needed special language support. The time in my Windows system tray had squiggles similar to these. However, it changed to AM/PM once I changed the settings in Region and Language Options. I've checked every setting I can find and if Windows still thinks I live in Saudi Arabia (or wherever), I can't find it, so I can't see how SageTV or the HD200 found it.
Old 04-27-2009, 12:28 PM
Tiki's Avatar
Tiki Tiki is offline
Have you looked in your properties files? You should have one for the server called sage.properties, and one for each extender. They will be located on your server PC inside the SageTV installation directory (C:\Program Files\Sage TV\....). Just open them on your server computer using Notepad or a similar text editor. I would start by checking these lines:
ui/translation_country_code=
ui/translation_language_code=
On mine they are blank and everything is in American English. I believe that if they have some value, Sage will try to translate things for other languages and localizations.
You could also search your properties files for the word "font". There are several places that list a font face (mine are pretty much all set to "Arial". If you have some funny font, it could explain the squiggles.
PS - You can look at the properties files with Sage running, but you can't edit them. You must Completely shut down Sage (including stopping the Sage Service) before you open the properties files for editing or your changes won't take.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 04-29-2009, 03:36 PM
troycheek's Avatar
I had looked in the properties files but hadn't noticed those line. I tried a whole bunch of changes specifying new countries and new languages (running up and down the stairs with every change since the server is in the basement and the HD200 is in the family room upstairs), but in the end, the answer was simply this:
ui/translation_language_code=English
This changed the squiggles to English letters and the dates to the American mm/dd format like I'm used to. It also changed the UI Language displayed in the Detailed Setup to English instead of the squiggle. However, if I select English as the UI Language using the Detailed Setup screen, it's back to the squiggle. Apparently, I have to tell SageTV to translate my English into English in sage.properties for it to work.
Thanks loads for the help, Tiki!
Old 04-29-2009, 03:45 PM
I suggest you contact SageTV support to find out what is happening because "English" isn't even a valid language code for that property, so it is telling it to use a non-existent language & probably defaults to the normal untranslated settings.
Old 04-29-2009, 05:17 PM
troycheek's Avatar
I had bet myself that you would reply to this thread, but I lost because I had bet that you'd tell me what page of the manual to look on to fix the problem.
You're right that it doesn't have to be a valid code, as "Pig Latin" works just as well for me, and I'm pretty sure that's not a supported UI language.
I've sent SageTV support the story so far. We'll see what they have to say.
Old 05-24-2009, 05:34 PM
troycheek's Avatar
SageTV support, after requesting a few more log files, decided that the problem was "probably the default locale for Java on your computer is set incorrectly. But your workaround is sufficient and fixes it."
I uninstalled Java and installed the latest (_13). I removed the workaround and tried again. Instead of English, the UI Language setting now says that it's Arabic, but all the menus are in English and all the times and dates are in the proper (American) format, so the family is happy now.
Next recording date/time or hh:mm from now - can this be displayed? pseudonym SageTV Customizations 9 03-20-2008 01:41 PM
Date and Time off by 5 hours? leahhallett SageTV Software 8 02-20-2007 03:02 PM
Display Current Time toricred SageTV Customizations 0 03-31-2006 07:15 PM
Date and Time Stamp in file name david4021 SageTV Recorder Software 0 10-19-2005 07:10 AM
Display won't show after some time off m0ng00se30 SageTV Software 5 09-16-2005 08:27 AM
