Old 08-01-2015, 01:23 PM
GoodbyePayTV GoodbyePayTV is offline
Replacement Power Supply HD Theater 300
I need to replace a power supply for the HD Theater 300. Can anyone provide the specifications of the power supply or, even better, a link to where I can purchase a replacement? Thank you in advance!
Old 08-02-2015, 12:52 PM
KryptoNyte's Avatar
This is it:
Honor ADS-24S-12 1224GPCU
If you search Google you'll find some made by Honor, and I see some other off-brands on Amazon for less than 20 bux.
Old 08-02-2015, 01:04 PM
KryptoNyte's Avatar
Mine looks very similar to this (same specs):
http://ecx.images-amazon.com/images/I/417%2BzYmfsrL.jpg
Old 08-21-2015, 03:01 AM
Oddity Oddity is offline
Any power supply that has the same output voltage and current will do. Just check the connector is the right type and you'll be fine.
Old 08-21-2015, 02:37 PM
pjpjpjpj pjpjpjpj is offline
Yeah, I replaced an HD200 power cord years ago with something really cheap from Amazon, just make sure you verify you have the right volts, amps and +/- plug configuration. Nothing unusual or proprietary.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Software: SageTV v9, stock STV with ADM.
Old 08-24-2015, 08:00 PM
skiingwiz skiingwiz is offline
I've purchased (and used) this power supply from Amazon with an HD300.
HD PVR power supply tvmaster2 Hardware Support 13 01-12-2012 03:13 PM
HD-PVR replacement power supply dead_ferrets Hardware Support 5 05-26-2011 07:59 AM
HD Theater 300 Power Supply Oddity SageTV Media Extender 3 12-06-2010 01:13 PM
Replacement power supply/adapter for SageTV Media Extender moakes Hardware Support 2 06-14-2009 09:11 PM
HD PVR power supply Fingergottes Hardware Support 1 09-22-2008 01:13 PM
