Old 02-11-2019, 03:19 PM
SD server status?
hi.
having issues connecting with server. I know a few days ago they had a comment on their website that there were issues with servers. Does anybody know current status? I cant find any mention on their website.
Old 02-18-2019, 10:59 AM
rmeden rmeden is offline
There are automated system checks every 5 minutes. If something fails, a message is put on the top of every page at http://schedulesdirect.org.
The SD-JSON service was down for maintenance a few days ago.
Old 03-04-2019, 11:47 AM
tomdomm tomdomm is offline
Deleted Lineup for Shedules Direct entry
Not sure where to to post this?
My HD300 & HD200 units 'Setup Video Sources' Source Lineup entry is DELETED LINEUP-USA-OH00323-X(sdepg). Checking the Program Guide shows the expected information. The Sources/tuners are tuning the digital channels. So it appears to be working. the log entries are below: Hope some one can tell me what the problem is!
Sun 3/3 22:21:15.061 [EPG@4226a8] sage.epg.sd.SDRipper@1134aeb needs an update in 23:37:47
Sun 3/3 22:21:15.062 [EPG@4226a8] sage.epg.sd.SDRipper@1ed68c0 needs an update in 0:00:00
Sun 3/3 22:21:15.063 [EPG@4226a8] EPG needs an update in 0 minutes
Sun 3/3 22:21:15.065 [EPG@4226a8] EPG PRIORITY EXPANSION attempting to expand DELETED LINEUP - USA-OH00323-X (sdepg)
Sun 3/3 22:21:15.066 [EPG@4226a8] expand called on DELETED LINEUP - USA-OH00323-X (sdepg) at Sun 3/3 22:21:15.066 expandedUntil=Sun 3/3 22:20:14.487 scannedUntil=Sun 8/17 2:12:55.807
Sun 3/3 22:21:15.067 [EPG@4226a8] EPG Expanding DELETED LINEUP - USA-OH00323-X (sdepg) at Sun 3/3 22:21:15.067
Sun 3/3 22:21:23.052 [EPG@4226a8] SDEPG Set the system clock to be Sun 3/3 22:21:23.052
Sun 3/3 22:21:23.055 [EPG@4226a8] SDEPG Exception: LINEUP_DELETED code=2106
Sun 3/3 22:21:23.057 [EPG@4226a8] sage.epg.sd.SDException: LINEUP_DELETED
Sun 3/3 22:21:23.057 [EPG@4226a8] at sage.epg.sd.SDRipper.extractGuide(SDRipper.java:1252)
Sun 3/3 22:21:23.057 [EPG@4226a8] at sage.EPGDataSource.expand(EPGDataSource.java:709)
Sun 3/3 22:21:23.057 [EPG@4226a8] at sage.EPG.run(EPG.java:732)
Sun 3/3 22:21:23.057 [EPG@4226a8] at java.lang.Thread.run(Unknown Source)
Sun 3/3 22:21:23.057 [EPG@4226a8] ERROR Updating EPG Source DELETED LINEUP - USA-OH00323-X (sdepg)
Sun 3/3 22:21:23.059 [EPG@4226a8] ErrorText:expand called on DELETED LINEUP - USA-OH00323-X (sdepg) at Sun 3/3 22:21:15.066 expandedUntil=Sun 3/3 22:20:14.487 scannedUntil=Sun 8/17 2:12:55.807
EPG Expanding DELETED LINEUP - USA-OH00323-X (sdepg) at Sun 3/3 22:21:15.068
Old 03-04-2019, 02:59 PM
Tiki's Avatar
Tiki Tiki is offline
Are you sure you are still getting new data for this lineup? You might want to check the guide and see how far out it goes (typically about 3 weeks for the US).
Iíve seen others post something similar. In those case I think SD renamed the lineup. The fix was to setup the tuners from scratch and select the new lineup name.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 03-04-2019, 03:55 PM
tvmaster2's Avatar
Listings have been fine for my system...
Old 03-05-2019, 10:36 AM
When I accessed SageTV from server the Entries where correct. So the problem seems to be with the client SageTV HDs. The Program Guide shows entries out to 3/21 8PM, 2 weeks worth is about normal for me. Will rebuild the tuners this afternoon. Looking in the properties files I see no entries for schedule line up in Client, but two entries in server. the first has the DELETED_LINEUP Entry, the 2nd has the proper entry from Schedules Direct. Backing up system than rebuild tuners. Worse case I update to latest version with a rebuild of SageTV.
Jetty Web Server (status update) stuckless SageTV Github Development 65 09-19-2016 08:34 AM
Status v9 sflamm SageTV Github Development 5 09-02-2016 01:25 AM
350 & OSD - What's the status Ralnee Hardware Support 7 10-04-2004 02:21 PM
OEM PVR-250 Status? rcleav General Discussion 13 09-23-2003 07:49 PM
