Old 12-13-2007, 10:37 AM
swerlin swerlin is offline
hd-dvd & bluray question
This looks like an awesome product, but I want to make sure that before I buy it I will be able to send the signal from my computer drive (new lg hd dvd + blue ray drive) to my tv. these would be the original movies bought at the store or rented and it would be awesome to send them to my bigscreen. Im all set to buy but just want to make sure and would the picture quality be as good.
thanks in advance for any and all help
sean
Old 12-13-2007, 12:04 PM
No, the extender can't play HD DVDs or BDs. To my knowledge PowerDVD, and Nero are the only products that can play HD DVDs or BDs on the PC.
Old 12-13-2007, 02:18 PM
SHS's Avatar
SHS SHS is offline
You forgot WinDVD
Old 12-13-2007, 02:33 PM
Can you actually buy WinDVD, and if you can, does it actually work?
Technically Arcsoft Total Theater 2 does too, but you can't buy it in the US.
My HD Future unkyjoe General Discussion 13 12-01-2007 08:04 PM
The Beginning of the End? lobosrul General Discussion 76 05-01-2007 06:39 PM
Can this PC do HD? dholmes97 Hardware Support 4 02-15-2007 09:23 PM
Bonus DVD and also general plugin question. traker1001 SageTV Software 1 12-11-2006 01:35 PM
DVD / Manual Question OttoNP SageTV Beta Test Software 1 11-23-2006 07:32 AM
