Old 01-24-2004, 11:38 PM
falltime falltime is offline
Help w/ USB-UIRT to control SA-3100 STB
I am usually pretty good at figurng this stuff out, but I cant get the USB-UIRT to recongnize commands from my Digital Cable Remote - Scientific Atlanta 3100. Is it not compatible? Seems weird b/c it has got to be the most popular cable box around.
Anyone got any ideas.
TIA
Old 04-12-2007, 04:36 PM
LazyGun LazyGun is offline
Sorry to bump an old thread, but has anyone got this working?
My USB-UIRT doesn't flicker it's LED when trying to train the PC. But if I try it with my old Hughes Remote, it does.
So I guess my UIRT is working. But it doesn't seem to notice my Comcast remote for this SA-3100.
The remote has a jumper inside by the battery compartment, but I have no idea what that does either (if it is even relevant ).
LazyGun
Old 04-12-2007, 05:08 PM
So, apparently the remote is a 56khz (from a post on the USB-UIRT forum), and I assume the UIRT I have is not the 56khz option. So, it won't learn my remote codes.
Does anyone have .ir file for their Comcast remote that controls this box (or I assume a similar box) that I could have?
Old 04-13-2007, 07:43 AM
Armondole's Avatar
Armondole Armondole is offline
try putting the remote a few centimeters away from the receiver when learning the codes...
Old 04-13-2007, 08:16 AM
mattdcknsn's Avatar
mattdcknsn mattdcknsn is offline
Also, make sure that Sage is NOT running in service mode. I had that problem earlier, and I am not sure if it has been fixed.
Old 04-13-2007, 08:32 AM
I tried all kinds of distances (I was even tempted to duck tape the thing to the remote ) so I don't 'think' it's that, but I will try more tonight.
And I'll try the service mode thing. That surprises me as the LED blinks on the UIRT when I use a different remote.
Old 04-13-2007, 09:12 AM
BTW: this problem should have been fixed for v6.1.6 and later.
Also, check the USB-UIRT forum -- I think there is a test program to check usage of the USB-UIRT. But, if it is the 56khz issue, then I suppose it may just depend on finding an existing .ir file. (I thought it could send those codes, but not learn them w/o that optional detector.)
Old 04-13-2007, 10:11 AM
That was my guess when I couldn't get the LED to blink.
I'll look for the test program tho. Thanks
Old 04-14-2007, 07:48 AM
It works!
So i downloaded the lrnHelper.exe from the USB-UIRT forums, and hey presto it started to receive my IR commands.
So I just pressed each button, copied it into the .ir file..and away I went.
I've attached my IR file in case anyone else wants it.
I didn't try the service mode thing, and I noticed I am still running 6.0.
So it could well have been that issue.
Anyway..all is good now.
Thanks for your help.
P.S. attached it as a txt file..so rename it to .ir if you need it.
Problems controlling DEC-3000S with USB UIRT oaamaas Hardware Support 2 04-10-2007 01:52 PM
USB UIRT not always tuning phunny Hardware Support 3 03-24-2007 07:51 AM
STB control and setup questions mcbinder Hardware Support 0 04-18-2006 12:25 PM
DirecTV D11 Serial (USB) control works Se7enLC Hardware Support 3 04-07-2006 08:24 AM
Usb Uirt doesnīt work in Sagetv Service mode in V4 Nadim Hardware Support 3 12-08-2005 12:32 AM
