Old 11-10-2009, 11:20 AM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
New channels not getting added to lineup
I have a HDHR, 2250 and 2xHDPVR's for a total of 6 tuners. The HDHR and 2250 share the same Lineup (Charter Communications Digital - Charlton). The HDPVR shows a Lineup of (Hauppauge HD PVR Capture Device Component).
Charter seems to be adding new HD channels once or twice a week and I get the system message telling me when. However, they are only getting added to the Charter Communications Digital lineup and not the HD PVR lineup. How can I update the lineup, or do I keep having to delete them and re-add them everytime a new channel comes up?
If this doesn't work right, Then:
"I'm going to blow up the Earth!"
Old 11-10-2009, 11:35 AM
Copied lineups do not get the newly added channels because they aren't built-in lineups in the EPG database. You can either recopy the lineup or manually added the channel(s) to the lineup.
gplasky gplasky is online now
Where did you get your lineup for the HD-PVR? If you copied it from one of the other tuners you need to copy it again anytime that original lineup gets new channels added to it. If it has its own lineup then you would need to enable the new channels once they start showing up in the lineup.
How Quickly are New Channels Added? darcilicious SageTV EPG Service 2 09-30-2009 10:05 AM
Cablevision lineup changing: VOOM channels gone; other HD getting added Opus4 SageTV EPG Service 3 02-17-2009 05:45 PM
Comcast added HD channels, not showing in lineup Bandit SageTV EPG Service 3 10-26-2007 01:45 PM
disable auto-enabling of channels added to lineup salsbst SageTV Software 3 10-14-2005 06:17 AM
How can I get a lineup added/changed? agover SageTV EPG Service 1 08-20-2005 09:01 PM
