Very strange MVP booting problem
I sent a description of this problem also to support, but was wondering whether anyone can help.. Sorry for the long text - but I need to explain quite some things.
I have been using the combination of SageTV and a MediaMVP extender successfully for quite a while using a PC called ´tv-pc´. As this PC is used for multiple purposes I decided to buy a complete new PC to become my MediaServer. This PC is called ´Mediaserver.
On both of the PC´s I have SageTV v5.0.4.92 and Java 1.5.0_06. On ´tv-pc´3 PC clients and a MediaMVP are attached and working fine with a PVR-350 card.
On ´Mediaserver´ (containing a PVR-500 card) the sageapp on the pc itself is running fine, and placeshifter is also working great. The same MediaMVP however refuses to connect to it. When starting the MVP I see a list of the 2 pc´s but when selecting the ´Mediaserver´it says afterwards it cannot find the server and tells me to reset the server and brings me back to the list of the two pc´s. On ´Mediaserver´the firewall is OFF (to avoid problems at this time), the service and extender are enabled. Restarting the server or PC, nor re-installing from scratch help! I see no differences between the two setups.
When I enable the debug mode I get following trace info: (note I stopped the service at the end and my text continues there)
do 8/31 22:55:00.356 NOTHING TO RECORD FOR NOW...
do 8/31 22:55:00.474 Seeker clearing unwanted and partial files...
do 8/31 22:55:00.477 Seeker waiting for 154 mins.
do 8/31 22:55:08.546 Received mvp packet
do 8/31 22:55:08.717 Sending mvp reply
do 8/31 22:55:10.742 Received mvp packet
do 8/31 22:55:10.913 Sending mvp reply
do 8/31 22:55:14.330 Received mvp packet
do 8/31 22:55:14.501 Sending mvp reply
do 8/31 22:57:23.545 Ministry is waiting for 180 sec
do 8/31 23:00:00.490 Seeker awoken
do 8/31 23:00:00.491 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture #2 clients=[] ir=false
do 8/31 23:00:00.491 Seeker in AUTOMATIC mode nextRecord=A[1870,1869,"TerZake Zomer",28926@0901.01:35,265] nextTTA=9299509
do 8/31 23:00:00.491 newRecord=null
do 8/31 23:00:00.492 NOTHING TO RECORD FOR NOW...
do 8/31 23:00:00.492 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture clients=[] ir=false
do 8/31 23:00:00.492 Seeker in AUTOMATIC mode nextRecord=A[1876,1875,"TerZake Zomer",28926@0901.20:00,50] nextTTA=75599509
do 8/31 23:00:00.492 newRecord=null
do 8/31 23:00:00.594 Seeker clearing unwanted and partial files...
do 8/31 23:00:00.596 Seeker waiting for 149 mins.
do 8/31 23:00:23.553 Ministry is waiting for 180 sec
do 8/31 23:01:55.967 Sage.exit() called.
do 8/31 23:01:55.968 Cleaning up servers
do 8/31 23:01:55.969 NetworkClient fullCleanup /127.0.0.1:1484
do 8/31 23:01:55.969 Cleaning up c/s connection
do 8/31 23:01:55.973 Cleaning up c/s connection
do 8/31 23:01:55.974 Error communicating with server:java.net.SocketException: Socket closed
do 8/31 23:01:55.975 Cleaning up c/s connection
do 8/31 23:01:55.977 NetworkManager CommunicationFailure : /127.0.0.1:1484 type=1
do 8/31 23:01:55.978 NetworkClient fullCleanup /127.0.0.1:1484
do 8/31 23:01:55.978 Cleaning up c/s connection
do 8/31 23:01:55.978 MsgRecv thread is terminating for /127.0.0.1:1484
do 8/31 23:01:55.978 Seeker awoken
do 8/31 23:01:55.978 Seeker is dropping client from watch map because its connection is dead:/127.0.0.1:1484@@SAGETV_PROCESS_LOCAL_UI
do 8/31 23:01:55.979 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture #2 clients=[] ir=false
do 8/31 23:01:55.979 Seeker in AUTOMATIC mode nextRecord=A[1870,1869,"TerZake Zomer",28926@0901.01:35,265] nextTTA=9184021
do 8/31 23:01:55.979 newRecord=null
do 8/31 23:01:55.980 NOTHING TO RECORD FOR NOW...
do 8/31 23:01:55.980 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture clients=[] ir=false
do 8/31 23:01:55.980 Seeker in AUTOMATIC mode nextRecord=A[1876,1875,"TerZake Zomer",28926@0901.20:00,50] nextTTA=75484021
do 8/31 23:01:55.980 newRecord=null
do 8/31 23:01:55.990 Scheduler awoken
do 8/31 23:01:56.101 Seeker clearing unwanted and partial files...
do 8/31 23:01:56.102 Seeker waiting for 148 mins.
do 8/31 23:01:56.103 Error w/SageTV client connection:java.net.SocketException: socket closed
do 8/31 23:01:56.104 Cleaning up PM
do 8/31 23:01:56.104 MiniUI ServerSocket died from:java.net.SocketException: socket closed
do 8/31 23:01:56.105 Seeker awoken
do 8/31 23:01:56.106 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture #2 clients=[] ir=false
do 8/31 23:01:56.106 Seeker in AUTOMATIC mode nextRecord=A[1870,1869,"TerZake Zomer",28926@0901.01:35,265] nextTTA=9183894
do 8/31 23:01:56.107 newRecord=null
do 8/31 23:01:56.107 NOTHING TO RECORD FOR NOW...
do 8/31 23:01:56.107 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture clients=[] ir=false
do 8/31 23:01:56.107 Seeker in AUTOMATIC mode nextRecord=A[1876,1875,"TerZake Zomer",28926@0901.20:00,50] nextTTA=75483894
do 8/31 23:01:56.108 NOTHING TO RECORD FOR NOW...
do 8/31 23:01:56.221 Seeker clearing unwanted and partial files...
do 8/31 23:01:56.222 Seeker waiting for 148 mins.
do 8/31 23:01:56.244 Killed Carny.
do 8/31 23:01:56.245 Scheduler.updateSchedule() called time=do 8/31 23:01:56.223 manual=[ManualRecord[A[1104,1102,"Dieren in nesten",989@0830.20:05,20] time=wo 8/30 20:05:00.000 dur=0:20:00], ManualRecord[A[10455,10453,"Ultratop 50",55355@0830.14:00,180] time=wo 8/30 14:00:00.000 dur=3:00:00]] schedules={Hauppauge WinTV PVR PCI II Capture #2=[Sched=[A[1865,1864,"Blackadder Goes Forth",28926@0831.23:25,30], A[1870,1869,"TerZake Zomer",28926@0901.01:35,265], A[1212,1211,"Het journaal en sport",989@0901.18:00,10], A[1642,1641,"Spring",28926@0901.18:10,15], A[1218,1217,"Het journaal en sport",989@0901.19:00,35], A[1651,1650,"3rd Rock from the Sun",28926@0901.19:35,24], A[1222,1221,"Dieren in nesten",989@0901.20:00,20], A[1226,1225,"F.C. de Kampioenen",989@0901.20:25,40], A[1884,1883,"Blackadder Goes Forth",28926@0901.22:05,35], A[1889,1888,"TerZake Zomer",28926@0902.01:05,295], A[1686,1684,"Wicked Science",28926@0902.11:00,25], A[1689,1687,"Out There",28926@0902.11:25,25], A[1710,1709,"Die Pfefferkörner",28926@0902.17:50,30], A[1714,1713,"Spring",28926@0902.18:30,15], A[1284,1283,"F.C. de Kampioenen",989@0902.20:35,39], A[1900,1898,"Cold Feet",28926@0902.22:25,50], A[1752,1751,"Wicked Science",28926@0903.11:10,25], A[1754,1753,"Out There",28926@0903.11:35,25], A[1759,1757,"My Parents Are Aliens",28926@0903.12:10,25], A[1762,1760,"Holly’s Heroes",28926@0903.12:35,24]] MustSee=[A[1870,1869,"TerZake Zomer",28926@0901.01:35,265], A[1212,1211,"Het journaal en sport",989@0901.18:00,10], A[1642,1641,"Spring",28926@0901.18:10,15], A[1218,1217,"Het journaal en sport",989@0901.19:00,35], A[1222,1221,"Dieren in nesten",989@0901.20:00,20], A[1226,1225,"F.C. de Kampioenen",989@0901.20:25,40], A[1889,1888,"TerZake Zomer",28926@0902.01:05,295], A[1714,1713,"Spring",28926@0902.18:30,15], A[1284,1283,"F.C. de Kampioenen",989@0902.20:35,39]]], Hauppauge WinTV PVR PCI II Capture=[Sched=[A[1647,1646,"Degrassi: The Next Generation",28926@0901.18:50,20], A[1876,1875,"TerZake Zomer",28926@0901.20:00,50], A[1897,1895,"Midsomer Murders",28926@0902.20:50,95]] MustSee=[A[1876,1875,"TerZake Zomer",28926@0901.20:00,50]]]} scheduleRandSize=13
do 8/31 23:01:56.246 # Airs=39
do 8/31 23:01:56.250 MUST SEE FINAL-Hauppauge WinTV PVR PCI II Capture #2-[A[1870,1869,"TerZake Zomer",28926@0901.01:35,265], A[1212,1211,"Het journaal en sport",989@0901.18:00,10], A[1642,1641,"Spring",28926@0901.18:10,15], A[1218,1217,"Het journaal en sport",989@0901.19:00,35], A[1222,1221,"Dieren in nesten",989@0901.20:00,20], A[1226,1225,"F.C. de Kampioenen",989@0901.20:25,40], A[1889,1888,"TerZake Zomer",28926@0902.01:05,295], A[1714,1713,"Spring",28926@0902.18:30,15], A[1284,1283,"F.C. de Kampioenen",989@0902.20:35,39]]
do 8/31 23:01:56.252 MUST SEE FINAL-Hauppauge WinTV PVR PCI II Capture-[A[1876,1875,"TerZake Zomer",28926@0901.20:00,50]]
do 8/31 23:01:56.252 Evaluating Potentials
do 8/31 23:01:56.253 COMPLETE SCHEDULE-----**&^%&*-------COMPLETE SCHEDULE
do 8/31 23:01:56.254 [A[1865,1864,"Blackadder Goes Forth",28926@0831.23:25,30], A[1870,1869,"TerZake Zomer",28926@0901.01:35,265], A[1611,1610,"Round the Twist",28926@0901.09:20,25], A[1212,1211,"Het journaal en sport",989@0901.18:00,10], A[1642,1641,"Spring",28926@0901.18:10,15], A[1218,1217,"Het journaal en sport",989@0901.19:00,35], A[1651,1650,"3rd Rock from the Sun",28926@0901.19:35,24], A[1222,1221,"Dieren in nesten",989@0901.20:00,20], A[1226,1225,"F.C. de Kampioenen",989@0901.20:25,40], A[1884,1883,"Blackadder Goes Forth",28926@0901.22:05,35], A[1889,1888,"TerZake Zomer",28926@0902.01:05,295], A[1686,1684,"Wicked Science",28926@0902.11:00,25], A[1689,1687,"Out There",28926@0902.11:25,25], A[1710,1709,"Die Pfefferkörner",28926@0902.17:50,30], A[1714,1713,"Spring",28926@0902.18:30,15], A[1284,1283,"F.C. de Kampioenen",989@0902.20:35,39], A[1900,1898,"Cold Feet",28926@0902.22:25,50], A[1750,1749,"Die Pfefferkörner",28926@0903.10:40,30], A[1752,1751,"Wicked Science",28926@0903.11:10,25], A[1754,1753,"Out There",28926@0903.11:35,25], A[1759,1757,"My Parents Are Aliens",28926@0903.12:10,25], A[1762,1760,"Holly’s Heroes",28926@0903.12:35,24]]
do 8/31 23:01:56.254 [A[1647,1646,"Degrassi: The Next Generation",28926@0901.18:50,20], A[1876,1875,"TerZake Zomer",28926@0901.20:00,50], A[1897,1895,"Midsomer Murders",28926@0902.20:50,95]]
do 8/31 23:01:56.254 Killed Scheduler.
do 8/31 23:01:56.255 Error calling finishWatch from VF goodbye:java.lang.NullPointerException
do 8/31 23:01:56.255 Ministry is shutting down....destroying the converts in progress
do 8/31 23:01:56.255 Killed Seeker.
do 8/31 23:01:56.256 Killed EPG.
do 8/31 23:01:56.257 stopEncoding0 called
do 8/31 23:01:56.258 Stopped graph res=0x0
do 8/31 23:01:56.258 teardownGraph0 called for device=Hauppauge WinTV PVR PCI II Capture
do 8/31 23:01:56.368 stopEncoding0 called
do 8/31 23:01:56.369 Stopped graph res=0x0
do 8/31 23:01:56.369 teardownGraph0 called for device=Hauppauge WinTV PVR PCI II Capture
do 8/31 23:01:56.478 Killed MMC.
do 8/31 23:01:56.479 Killing UIMgr UIManager:localhost@@SAGETV_PROCESS_LOCAL_UI
do 8/31 23:01:56.479 Error calling finishWatch from VF goodbye:java.lang.NullPointerException
do 8/31 23:01:56.479 Killed VideoFrame
do 8/31 23:01:56.480 Killed Studio
do 8/31 23:01:56.480 Killed RootPanel
do 8/31 23:01:56.535 Disposed Window
do 8/31 23:01:56.536 Killed UIManager.
do 8/31 23:01:56.541 Killed Wizard.
do 8/31 23:01:56.644 Bye-bye.
AND NOW the strange part. When I boot the MediaMVP using the TV-PC selection, it boots up and shows the UI session of the ´MediaServer´! So it seems that the mvp fetches the bin from the TV-PC and then carries on with the Mediaserver!!
At this time (temporarily) both licenses are identical, maybe that is the reason for this mixup.
When I remove TV-PC from the network I can continue to use the MVP until I shut it down and have to reboot, from then on it fails...
Can someone please help me?? I cannot keep this PC-TV alive forever. I have investigated all mvp threads and checked all hints. FYI the MediaServer is based on a ASROCK AliveNF4G-DVI - that contains a nForce NIC that probably has a HW firewall (learned that in the forum). Therefore I am using a plain DLINK DFE-500TX ethernet pci card. No firewall on that  . So that is not the reason.
What can I do to solve this problem?
