Does anyone use the HDHomeRun Extend (HDTC-2US)?
If so, could you please post your HDHomeRun configuration setup including whether you use OpenDCt with it or not. I've had an Extend for 4 years and it was working reliably with SageTV until a couple weeks ago. It works fine with other PVR software so it's not an issue with the EXTEND hardware but for some reason SageTV will no longer record shows with it because i keep getting messages like:
The device input "Silicondust HDHomeRun Tuner 10562C06-0 Digital TV Tuner" stopped producing data while recording "Sesame Street" on WGBXDT7 on physical channel 32-2-3. SageTV will try to reset the device. This may be caused by a channel that is no longer available.;VCaptureDeviceInput=Silicondust HDHomeRun Tuner 10562C06-0 Digital TV Tuner;VCaptureDevice=Silicondust HDHomeRun Tuner 10562C06-0;VPhysicalChannel=32-2-3;VChannelName=WGBXDT7;VAiringID=138841;VTitle=Sesame Street; This issue has been driving me crazy for days and I can't figure out what's wrong.
- James M - Capture Devices: HDHomerunXTEND, HDHomerunPrime |
Nickk is on fixing the BDA drivers on Sagetv64 bit.
https://forum.silicondust.com/forum/...383758#p383758
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 06-01-2022 at 01:06 PM. |
HDHomeRun EXTEND H.264 and SageTV | brandypuff | Hardware Support | 35 | 05-30-2022 03:15 PM |
hdtc-2us firmware update broke SageTV 7 | handeland | Hardware Support | 0 | 12-17-2016 11:48 AM |
Question re:HDHomeRun Extend | KeithAbbott | Hardware Support | 1 | 08-24-2015 06:15 AM |
To Extend(er) or not to Extend(er) | greggerm | SageTV Media Extender | 7 | 03-24-2009 01:35 PM |
Extend Trial | Brent | SageTV Software | 16 | 02-06-2009 09:24 PM |
