Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Phoenix 3.0
Phoenix 3.0 This forum is for discussing the user-created Phoenix 3.0 custom interface for SageTV.
Old 07-01-2022, 03:16 PM
jusjoken jusjoken is offline
Phoenix Core Services 3.4.3 - new TV providers
This new version of the phoenix core/api now adds 2 TV providers giving you the following options...
  • tvdb - existing option that will likely be pulled by TVDB as its being replaced by them in favor of their subscription based v4 - see below. For now it continues to be free and mostly functional (missing access to banners and seems to provide less data/series). TVDB keep pushing out the cancellation date so not sure how long this will be available.
  • tvdb4 - new provider that supports TheTVDB.com latest api which is subscription based. To use this you must go to their site and register and pay for a user subscription ($11.99 annual USD) which will provide you with a PIN code. Once you have this then...
    • go to BMT, Configure, Phoenix, Fanart Options
    • change TV Metadata Provider(s) to tvdb4 (then click save)
    • go to BMT, Configure, Phoenix, TheTVDB4 Configuration
    • Enter your PIN in the TVDB4 API PIN field (then click save)
    • Note.. you can also put the pin in the sage.properties file directly with sage NOT running. For example
      • phoenix/metadata/tvdb4/pin=PINCODEFROMTVDB
  • tmdb - new provider to offer another free provider. The source data seems mostly current for newer shows and is fan supported if you want to get involved and update data. I did find a number of my test series to be lacking in source data but otherwise this is a good free option once the old tvdb provider goes away. To use this...
    • change TV Metadata Provider(s) to tmdb (then click save)
Other changes...
  • Fix: Old TVDB provider should now work on Java 11
  • Fix: if Fanart is disabled (local and central), metadata will still be retrieved unless Automatic Fanart/Metadata is disabled. In this state, no fanart should be downloaded.
Note: you will need the latest version of BMT as well if you use BMT. I also tested the changes with CMT and everything seems to work fine.
This was a large effort so please let me know if anyone runs into any issues and I will work to resolve.
K
Old 07-01-2022, 10:52 PM
phelme's Avatar
phelme phelme is offline
Cool and thanks!
Does it matter which order we install the plugins in? Have had some issues with that in the past.
Old 07-02-2022, 04:44 AM
Originally Posted by phelme View Post
Cool and thanks!
If you install the BMT update it will force the update of the others.
K
Old 07-02-2022, 02:47 PM
trk2 trk2 is offline
Nice. Thanks for your work!
Old 07-03-2022, 10:12 AM
phelme's Avatar
K
thanks, I'll back everything up and start with BMT.
Old 07-05-2022, 08:30 AM
DarkWolf77 DarkWolf77 is offline
Nevermind, I had a typo in my pin because I transcribed it by hand into Sage... ugh. sorry!
Old 07-05-2022, 10:28 AM
Does TMDB have banners for TV shows? I just took a quick look and I don't see them. I use banners in my TV view so if they are not there that is an issue.
These subscriptions are starting to add up - we now have to pay for guide data and other metadata. Not a fortune, but it is starting to tick up.
Old 07-05-2022, 12:45 PM
tvmaster2's Avatar
Great stuff, thanks a bunch
Old 07-05-2022, 02:17 PM
phelme's Avatar
well nuts, as I feared I updated (starting from BMT) and now the service crashes on startup. this is what happened last time these were updated.
I thought I had cleared up all the old Java components from the last round, but obviously something still isn't right. sigh. time to roll-back.
Old 07-05-2022, 02:32 PM
Can you provide any logs first?
K
Old 07-05-2022, 02:34 PM
I do not believe TMDB does banners and I believe the old TVDB banners no longer download for new items.
And I agree on the comment on subscriptions, but at least SageTV users have the option now.
K
Old 07-05-2022, 03:06 PM
phelme's Avatar
K
it never gets that far for any log, it just crashes. and unfortunately, I just tossed everything from the update.
but I did find a post from myself when this happened last time in Feb. when sagex-api was updated, that removing the "jetty/work" directory is what fixed it for me. maybe I'll try again tomorrow with this in mind.
Old 07-05-2022, 07:04 PM
By old TVDB banners you mean the old API? But banners do get downloaded with the new API?
Old 07-06-2022, 07:31 AM
Correct. In my testing the old TVDB api quit downloading banners many months ago and they do not seem to have fixed it and I would doubt they will.
In my testing of the new TVDB V4 api, it does download banners.
K
Old 07-06-2022, 09:31 AM
Yeah the old v3 API now returns a bad URL for banners (basically .../banner//banner/...)
Old 07-06-2022, 10:10 AM
Perfect, thanks guys. I guess I will switch to the new API. I don't add a lot of TV series these days so I have manually downloaded banners. But I guess I will have to ante up for the new TVDB API soon.
Any update on when they shut down the old API for good?
Old 07-06-2022, 12:38 PM
Not that I have heard. The last announcement was that it would end in the first half of 2022...so they missed that but I have yet to see an update.
k
Old 07-06-2022, 12:51 PM
phelme's Avatar
Follow-up. Updated again, BMT and then let it do the supporting plugins, shutdown service, cleaned jetty/work folder. Still crashes on start.
I've attached various log files and here is a list of my JARs.
a----          4/9/2016   7:36 AM          53347 ActiveAspectRatios.jar
-a----         4/25/2010   7:29 AM        3466991 activemq-all-5.3.1.jar
-a----        12/20/2010   1:46 PM           7960 ant-javamail.jar
-a----        12/20/2010   1:46 PM          12322 ant-launcher.jar
-a----        12/20/2010  12:46 PM        1933743 ant.jar
-a----        12/23/2012  12:18 PM          25839 AntiFavorites.jar
-a----         1/14/2022   7:34 AM        1050846 apache-jsp-8.5.70.jar
-a----         1/14/2022   7:34 AM          21239 apache-jsp-9.4.44.jar
-a----         1/14/2022   7:34 AM          12549 apache-jstl-9.4.44.jar
-a----        11/22/2015   7:47 PM          30877 api-common-2.0.jar
-a----         1/14/2022   7:34 AM         122004 asm-9.2.jar
-a----         1/14/2022   7:34 AM          34257 asm-analysis-9.2.jar
-a----         1/14/2022   7:34 AM          72642 asm-commons-9.2.jar
-a----         1/14/2022   7:34 AM          52660 asm-tree-9.2.jar
-a----        10/18/2015  12:10 PM         686501 cling-core-2.0.1.jar
-a----        10/18/2015  12:11 PM         490043 cling-support-2.0.1.jar
-a----         12/1/2017   6:03 PM          79179 CommercialDetector.jar
-a----        11/22/2015   7:47 PM         263965 commons-codec-1.9.jar
-a----          2/5/2010   8:36 PM          41376 commons-dbutils-1.3.jar
-a----        10/11/2009  11:42 PM          49259 commons-exec-1.0.1.jar
-a----         2/23/2017  10:51 PM         208700 commons-io-2.5.jar
-a----        10/28/2018   7:36 PM         268794 commons-jxpath-1.1.jar
-a----         1/24/2010   5:50 PM         261809 commons-lang-2.4.jar
-a----        11/22/2015   7:47 PM         434678 commons-lang3-3.4.jar
-a----        11/22/2015   7:47 PM          61829 commons-logging-1.2.jar
-a----          4/5/2010   2:22 PM         180792 commons-net-1.4.1.jar
-a----        11/12/2009   8:38 PM          96221 commons-pool-1.5.4.jar
-a----          9/8/2009  10:02 PM         373438 commons-vfs-20070823.jar
-a----          4/8/2010   5:43 PM         152619 concurrent-1.3.2.jar
-a----          4/8/2010   5:43 PM          36045 cron4j-2.2.1.jar
-a----         1/25/2008   5:54 PM          12210 df_fav_excluder.jar
-a----        10/13/2008   9:46 PM          18293 df_sageutils.jar
-a----         2/22/2008   4:16 PM           2166 df_sleep_timer.jar
-a----         4/10/2010  10:27 PM         313898 dom4j-1.6.1.jar
-a----         3/20/2011   4:12 PM           8524 EPPlayOn.jar
-a----         8/28/2021   8:40 AM         255839 Gemstone.jar
-a----         6/17/2011  11:28 AM         439965 gkusnick.sagetv.jar
-a----         6/18/2010   4:19 PM          95368 gkusnick.sagetv.studio.jar
-a----         5/19/2010   1:31 PM         100897 gkusnick.sagetv.studio.tools.jar
-a----         8/28/2021   9:31 AM         114129 GoogleWeather.jar
-a----         10/4/2012   2:24 PM        6215448 groovy-all-2.0.5.jar
-a----         8/30/2016  10:41 AM         173608 gson-1.7.2.jar
-a----         1/26/2018  11:24 PM          33642 gtools.jar
-a----          2/3/2014  11:29 AM        1638306 h2-1.3.175.jar
-a----        11/22/2015   2:32 PM          45024 hamcrest-core-1.3.jar
-a----         2/13/2010   7:02 AM         288098 htmlparser-1.6.jar
-a----        11/22/2015   7:47 PM         732765 httpclient-4.5.1.jar
-a----        11/22/2015   7:47 PM         326594 httpcore-4.4.3.jar
-a----         12/3/2009  11:43 PM          25443 httpmime-4.0.1.jar
-a----        11/26/2008  10:48 AM           3527 imageutils.jar
-a----        11/23/2015   9:22 AM          46989 jackson-annotations-2.6.3.jar
-a----        11/23/2015   9:22 AM         258875 jackson-core-2.6.3.jar
-a----        11/23/2015   9:22 AM        1170801 jackson-databind-2.6.3.jar
-a----        12/21/2020  12:30 PM       19849195 JavaFFmpeg.jar
-a----         5/23/2010   6:51 PM          67696 javasysmon.jar
-a----         1/14/2022   7:34 AM          26586 javax.annotation-api-1.3.2.jar
-a----          7/6/2022  11:14 AM          56615 jaxws-api-2.3.1.jar
-a----        10/28/2018   7:36 PM         394099 jcifs-1.1.6.jar
-a----          4/8/2010   5:43 PM         435347 jcs-1.3.jar
-a----        10/28/2018   7:36 PM          72906 jdic.jar
-a----         1/14/2022   7:34 AM          86707 jetty-annotations-9.4.44.jar
-a----         1/14/2022   7:34 AM          63091 jetty-deploy-9.4.44.jar
-a----         1/14/2022   7:34 AM         224574 jetty-http-9.4.44.jar
-a----         1/14/2022   7:34 AM         178897 jetty-io-9.4.44.jar
-a----         1/14/2022   7:34 AM          47642 jetty-jaas-9.4.44.jar
-a----         1/14/2022   7:34 AM          42353 jetty-jmx-9.4.44.jar
-a----         1/14/2022   7:34 AM          46773 jetty-jndi-9.4.44.jar
-a----         1/14/2022   7:34 AM          65608 jetty-plus-9.4.44.jar
-a----         1/14/2022   7:34 AM          44678 jetty-rewrite-9.4.44.jar
-a----         1/14/2022   7:34 AM         188164 jetty-schemas-3.1.jar
-a----         1/14/2022   7:34 AM         118509 jetty-security-9.4.44.jar
-a----         1/14/2022   7:34 AM         718742 jetty-server-9.4.44.jar
-a----         1/14/2022   7:34 AM         145911 jetty-servlet-9.4.44.jar
-a----         1/14/2022   7:34 AM         107499 jetty-servlets-9.4.44.jar
-a----         1/14/2022   7:34 AM          56806 jetty-starter.jar
-a----         1/14/2022   7:34 AM         581520 jetty-util-9.4.44.jar
-a----         1/14/2022   7:34 AM         140293 jetty-webapp-9.4.44.jar
-a----         1/14/2022   7:34 AM          68300 jetty-xml-9.4.44.jar
-a----        10/28/2010   2:19 PM         466697 jpathwatch-0-93-rc1.jar
-a----          1/7/2014   1:36 PM          64952 json-20140107.jar
-a----         9/19/2009  11:01 AM          36843 json.jar
-a----         11/9/2012   4:31 PM         278273 jsoup.jar
-a----        11/22/2015   2:32 PM         314932 junit-4.12.jar
-a----          9/2/2011  11:26 AM           3252 livepvrdata4j.jar
-a----         5/26/2010   4:51 PM          10235 livepvrdata_rpc_clnt.jar
-a----          9/2/2011  10:12 AM           7294 livepvrdata_shared.jar
-a----        12/12/2015   9:07 PM         489884 log4j-1.2.17.jar
-a----        10/28/2018   7:36 PM        1535258 lucene-core-3.6.0.jar
-a----        11/17/2009  12:13 PM         462098 mail.jar
-a----        12/21/2020  12:31 PM          16574 MediaFormatParserPlugin.jar
-a----         1/27/2011   8:01 PM          35372 metadata-updater.jar
-a----         3/29/2009   6:35 PM         107221 miglayout-3.6.3-swing.jar
-a----          8/2/2009  10:02 PM         174019 mjxml.jar
-a----        10/21/2010   7:12 PM           7314 nielm_autoaspect.jar
-a----         3/13/2021   4:45 PM          62924 nielm_sageimdb.jar
-a----         3/21/2011   5:54 PM          15344 nielm_sageutls.jar
-a----         3/21/2014   5:13 PM         403085 nielm_sagewebserver.jar
-a----         5/16/2010  11:27 AM          55271 nielm_sagexmlinfo.jar
-a----         1/14/2022   7:34 AM         206430 org.apache.taglibs.taglibs-standard-impl-1.2.5.jar
-a----         1/14/2022   7:34 AM          40153 org.apache.taglibs.taglibs-standard-spec-1.2.5.jar
-a----         1/14/2022   7:34 AM        2884633 org.eclipse.jdt.ecj-3.19.0.jar
-a----         1/14/2022   7:34 AM          21239 org.eclipse.jetty.apache-jsp-9.4.44.jar
-a----         1/14/2022   7:34 AM         256317 org.mortbay.jasper.apache-el-8.5.70.jar
-a----         1/14/2022   7:34 AM        1050846 org.mortbay.jasper.apache-jsp-8.5.70.jar
-a----          6/4/2010  11:14 PM          21514 ortus_favexcluder.jar
-a----        10/28/2018   7:36 PM         134032 packager.jar
-a----          7/1/2022   7:06 AM        1344484 phoenix.jar
-a----         3/20/2011   2:20 PM           1941 PlayOnUtils.jar
-a----         7/23/2009   7:49 PM           3794 razr-tools.jar
-a----        11/13/2010  10:29 AM          11441 razr.jar
-a----         7/28/2007   3:55 AM          20542 rsslib4j-0.2.jar
-a----          5/6/2011   7:28 AM         144359 SageDiamond.jar
-a----        10/13/2008  10:46 PM          66795 sagemc.jar
-a----          3/6/2010   4:17 PM         287120 sageortus.jar
-a----         1/29/2011   5:55 PM         275134 sageortustve.jar
-a----          6/1/2022   8:24 AM         520058 sagex-api.jar
-a----        11/14/2010  10:21 AM           9430 sagex-h2.jar
-a----          8/5/2013  10:57 AM           2708 salicense.jar
-a----        10/28/2018   7:36 PM          56121 sbbi-upnplib-1.0.3.jar
-a----         6/21/2010  12:16 PM          26298 scribe-0.6.7-SNAPSHOT.jar
-a----        10/18/2015  12:10 PM          21646 seamless-http-1.1.0.jar
-a----        10/18/2015  12:10 PM          94456 seamless-util-1.1.0.jar
-a----        10/18/2015  12:10 PM          63142 seamless-xml-1.1.0.jar
-a----         1/14/2022   7:34 AM          95806 servlet-api-3.1.jar
-a----         12/4/2005   2:25 PM          31789 servlet.jar
-a----        10/18/2011   4:45 PM          39376 sjq-agent.jar
-a----         6/20/2011  11:39 AM          38860 sjq-common.jar
-a----         2/26/2011   6:20 PM           9418 sjq-listener.jar
-a----         6/20/2011  11:39 AM          51090 sjq.jar
-a----        11/22/2015   7:47 PM          32127 slf4j-api-1.7.12.jar
-a----        12/12/2015   9:07 PM           8860 slf4j-log4j12-1.7.12.jar
-a----         12/9/2006   6:09 PM          51117 slimplayer.jar
-a----         5/14/2010   1:03 PM           4558 slugger-dev-tools.jar
-a----          7/8/2008   2:36 PM          80815 slugger_sage-job-queue.jar
-a----         3/22/2011   8:10 PM          69863 snark.jar
-a----         8/15/2007   7:23 PM        1772311 SoftSqueeze.jar
-a----         1/19/2011   4:25 PM           4254 somf.jar
-a----          9/8/2009   5:26 PM        2684154 sqlitejdbc-v056.jar
-a----         3/25/2009   8:08 PM         466359 sqljdbc4.jar
-a----         5/25/2010   8:09 PM           4772 SystemMonitor.jar
-a----         9/24/2021   6:24 AM         220808 themoviedbapi-4.4.jar
-a----         6/18/2022   4:57 AM          37617 thetvdbapi-1.10.jar
-a----          4/8/2019   1:26 PM         179676 trakt.jar
-a----         9/20/2006  10:10 AM         110481 tritonus_share.jar
-a----          1/8/2017   2:43 PM          63777 validation-api-1.1.0.Final.jar
-a----        10/28/2018   7:36 PM         289881 vecmath.jar
-a----         9/20/2006  10:10 AM          17003 vorbisspi1.0.2.jar
-a----        12/17/2021   7:59 PM         665586 webui-4.0.0.jar
-a----        12/18/2011   6:25 PM           7546 WIcons.jar
-a----         9/11/2009   2:43 PM          34407 ws-commons-util-1.0.2.jar
-a----          2/6/2010   5:13 PM          58573 xmlrpc-client-3.1.3.jar
-a----          2/6/2010   5:12 PM         109131 xmlrpc-common-3.1.3.jar
I'll keep looking to see if anything stands out to me.
Do I need to do something with the webapps folder maybe?
Thanks.
EDIT: am I seeing this right that the only things that are changing are these JARs:
jaxws-api-2.3.1
sagex-api
phoenix
thetvdbapi-1.10
and then a new "bmt.war" in webapps?
I'm trying to see if I there is any easy way to roll back and forth without copying GB's of data.
Old 07-06-2022, 05:41 PM
Thanks.
jaxws-api-2.3.1
sagex-api
phoenix
thetvdbapi-1.10
There would also be some config files in stvs/phoenix that changed
I will review the logs later and see if I can find the issue
Old 07-07-2022, 07:15 AM
Thanks.
jaxws-api-2.3.1
sagex-api
phoenix
thetvdbapi-1.10
I completed my review. Notes...
- Jetty is starting Ok so I do not think it is Jetty related. I do see an old "servlet.jar" file in your JARs that could cause a conflict but I do not think it is. It would not hurt to rename this jar to avoid any issue.
- According to your logs, Sage just dies at the last part of the plugin installs and never starts the new version of phoenix. I noted a number of JARs that phoenix depends on were older on your system than on 2 of my test systems. I then noted that the MIN version stated in the plugin manifest had a too low version in it so if the old version existed on a system then it would not install the latest version which "may" be causing phoenix to fail.
To fix the above MIN version issue I have updated the manifests for bmt and phoenix to force it to use the latest jar versions for these dependencies. This could easily be the issue but we will not know until you try it out again.
The updated plugins have been published so the next time you try you will get the newer dependencies.
I hope it works better for you. Thanks for your patience.
K
Phoenix Core Services Failed after update SWKerr Phoenix 8 05-18-2016 03:01 PM
Phoenix Core Services problem sacrament055 Phoenix 15 11-21-2012 10:37 AM
Help with configuring Phoenix Core Services Chriscic SageTV v7 Customizations 2 01-01-2011 12:33 AM
Can't install Phoenix Core Services parkimar SageTV v7 Customizations 5 11-30-2010 12:06 PM
Minor Update to 4.3 (actually phoenix core services) stuckless Batch Metadata Tools 1 07-30-2010 09:00 AM
