Go Back   SageTV Community > Information & Announcements > SageTV Downloads & Instructions
SageTV Downloads & Instructions This forum is for discussions containing Downloads and Instructions related to the Open Source version of SageTV. Please do not post questions in this forum.
Old 06-22-2019, 01:15 PM
doodeedoo doodeedoo is offline
EventGhost, USB UIRT and 64bit not working
Does anyone have EventGhost working with USB UIRT and SageTV 64 bit?
Fresh install of STV 9.2.1 64 bit on Windows 10
USB UIRT installed and working with STV only, both receiving and sending, after copying the 2 files
EG both versions 4 R1722 and 5 RC6. UUIRT works with both versions if STV is not running
Cannot get both STV and EG to use UUIRT at same time. Whichever program starts first grabs control of UUIRT (send and receive) and the other can't use. STV just does not respond via UUIRT if EG is started first. If STV is started first, EG log states 'Error starting plugin' and 'Device not found'.
Fresh install of STV 9.2.1 32 bit on same system works correctly with UUIRT and EvenGhost at the same time.
Old 06-24-2019, 05:48 AM
Tiki's Avatar
Tiki Tiki is offline
You said you have both transmitting and receiving working at the same time in Sage 64-Bit for Windows? Were you using Sage in service mode (where the recording engine runs as a separate process from the UI), or in stand-alone mode (where closing the UI stops the recording engine)?
I am guessing you were using stand-alone mode. Because I could not get this to work in Service mode.
I don't use Event Ghost, but I would guess that the same issue that prevents the USBUIRT from working correctly with Sage in Service Mode would also prevent it from working with two different programs at the same time.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 06-24-2019, 01:26 PM
JustFred JustFred is offline
Is EventGhost a 32-bit program?
I just discovered that attempting to use USB-UIRT by other programs fails whenever Sage-x64 is running. But accessing USB-UIRT from a 32-bit program while running Sage-x86 works fine.
I've built a new uu_irsage.dll for Sage-x64 with a fix that looks like it works in my test cases. Send me a PM if you'd like to test it out.
Old 06-24-2019, 05:28 PM
Tiki's Avatar
Will this also fix the problem with not being able to use transmitter and receiver at same time with 64-bit Sage in service mode?
Source:
Comcast Cable
HDHR, HVR-2250
Old 06-24-2019, 05:48 PM
Unknown. I've always been able to both Tx & Rx from within the Sage-x64 server in service mode. Never was able to duplicate the problem you refer to. PM me if you'd like to try my uu_irsage.dll. No harm to try it.
Old 06-25-2019, 06:12 PM
JustFred, thanks for sharing the dll. Unfortunately did not allow EG and SageTV to share the UUIRT.
Tiki, yes, stand alone mode.
Old 07-31-2019, 03:03 PM
If you're running an HD-PVR2, try using the IR blaster that ships with it. I got that working with Sage 64, unfortunately my video isn't usable.
ASRock B450M Pro4 AM4 mATX AMD Motherboard, AMD Ryzen 5 2600 3.4GHz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD - Black SN750 NVMe SSD 250GB, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, HD-PVR2, WinTV-dualHD USB, Windows 10 64bit
Old 09-04-2019, 11:38 AM
sacrament055 sacrament055 is offline
I've noticed that my Sage Server running in service mode doesn't seem to respond to my USB-UIRT when I launch the client on the same server. Does your fix mentioned here resolve that?
I'd like to use my SageTV remote with my client on the server
Old 09-04-2019, 01:37 PM
Check this thread out as it may help: https://forums.sagetv.com/forums/showthread.php?t=45049
Old 09-04-2019, 05:16 PM
Are the Sage server service and client both 64-bit? It would help to know the versions and bitness of the Sage server and client. Are you also running EventGhost (which bitness?)
USB-UIRT has a limitation that prevents it from being used by a mixture of 32-bit and 64-bit programs at the same time. This has been confirmed by Jon (the creator of USB-UIRT).
Old 09-04-2019, 05:26 PM
Yes I'm running the SageTV x64 shortcut while running SageTV 64bit as a service.
I'm only trying to use my USB-UIRT as a receiver so that I can use my SageTV remote on my Server/Client.
Thanks for your help.
Windows 64bit Installer Not Working on Windows 7 will SageTV Downloads & Instructions 8 01-23-2019 04:59 PM
Linux 64bit MiniClient (issues with JTux on 64bit) stuckless SageTV Github Development 23 08-19-2015 12:54 PM
Windows 8 Pro 64bit + Vbox DTA-150 not working laberet Hardware Support 4 12-31-2012 07:50 PM
Wake Up my HTPC with USB-UIRT/Eventghost/W7/MSI board THX-UltraII Hardware Support 1 06-08-2011 02:14 AM
Sharing USB-UIRT w/ SageTV and Eventghost? peternm22 Hardware Support 3 04-03-2011 10:45 PM
