Go Back   SageTV Community > Information & Announcements > SageTV Downloads & Instructions
SageTV Downloads & Instructions This forum is for discussions containing Downloads and Instructions related to the Open Source version of SageTV. Please do not post questions in this forum.
Old 11-09-2019, 10:13 AM
bigbill's Avatar
bigbill bigbill is offline
64 bit, ready for primetime?
I see the 64bit version hasn't been updated for 8 months. Is it ready for primetime? I don't use the USBRT.
Thanks, Bill
Sage Server: SageTV v9.1.8
Hardware Dell T20 Mini Tower, 4th Gen Pentium, 8GB RAM, Win10 Pro 64 bit, 3 x 4TB WD Green, 128GB SSD boot drive. Capture: 2 Dual HDHR, (OTA Winegard HD8200U, CM4221HD), 3 @ STP-HD200's fw=v20100909 TV's: 70", 55" & 40" Sony's - Playon/PlayLater, Blue Iris. FFMPEG script converting MPEG2 to MP4 long term storage.
Motorhome Sage Server: SageTV v9.1.8 Intel NUC6CAYH, HD300, Nvidia Shield 2017, 1 Dual HDHR 4TB Passport storage, Winegard BatWing RV antenna.
Old 11-09-2019, 10:27 AM
wnjj wnjj is offline
Thanks, Bill
I know people are using it and there havenít been any bug reports for some time now. There was a recent patch for DirecTV serial control that isnít in a release build yet but it affected 32 and 64 bit versions of 9.2.
If youíre concerned, you should be able to install side by side and revert back if needed.
Old 11-10-2019, 09:27 AM
bigbill's Avatar
Thanks! The installer asks a couple of question under the LAV filters question that I am not sure about.
Enable Sagetv Stream Demux ?
Always Swap for AC3 Filter ?
What breaks if I do or dont install those? -Bill
Old 11-10-2019, 10:07 AM
I think with the LAV filters that get installed now those optional items aren’t really needed. They’re both related to playback on the server itself and only for certain formats. Those are both registry entries you can change later if needed.
Old 11-10-2019, 01:13 PM
jusjoken jusjoken is offline
The installer has them defaulted to the correct values unless they were already set on your system. so best to leave them as is.
k
Old 11-10-2019, 02:36 PM
bigbill's Avatar
Thanks! I wasn't really sure if I would need them or not. -Bill
Old 11-19-2019, 12:43 PM
sdsean's Avatar
sdsean sdsean is offline
There was a recent patch for DirecTV serial control that isn’t in a release build yet but it affected 32 and 64 bit versions of 9.2.
Any idea when that would be pulled in? I don't want to try it out before then since everything I have is done serial control
i7 3.33 GHz EE Quad Core+HT, 12GB DDR3 1333Mhz RAM, ATI HD6870 2GB VRM, 512GB Samsung SSD OS Drive, EVGA SLI x58 Mobo, Win7 Ultimatex64, Gyration MCE Remote, Hauppauge HD-DVR (x3), HD-HR, 2x H21-100, 1x H21-200 DirecTV STBs, 1 SIIG / CyberSerial 4 Port Serial PCI card, 1 PCIex1 Inland/NEC 5 port USB card
Old 11-19-2019, 02:18 PM
I don't know when the next release will be but if you want to upgrade you can install the latest then patch the DLL and sage.jar from this post and it will be equivalent. https://forums.sagetv.com/forums/sho...2&postcount=20
Old 11-23-2019, 02:04 PM
KryptoNyte's Avatar
I noticed that after fresh installing 64 bit to take the place of the 32 bit version that the tuner configuration no longer presents the merit value for alteration (this feature was added not too long ago).
Old 11-23-2019, 02:26 PM
Tiki's Avatar
Tiki Tiki is offline
Itís still there, it it is not enabled by default. You need to change one of the settings to see it.
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 11-23-2019, 04:15 PM
KryptoNyte's Avatar
Yeah, it was near the very bottom of the "custom" settings. Thanks.
P2 Ready for All stuckless Phoenix 0 05-19-2013 06:27 AM
Ready-Boost bits General Discussion 2 02-21-2011 02:25 PM
Feature Req : Prefer fravorites recorded not in PrimeTime bialio SageTV Software 11 08-08-2008 10:43 AM
Bush messes up primetime schedule - how do I update amg SageTV EPG Service 5 04-30-2005 08:12 AM
ok ready to go...almost dvd_maniac SageTV Software 11 04-02-2004 06:00 PM
