S/PDIF digital volume control? - Resolved - found a way
Resolved -- see last post
------------------<original 1st post>--------------------------------------- I just switched from analog stereo to digital S/PDIF optical. My problem is that I can no longer control the volume with Sage? (Master volume does not control S/PDIF output, wave volume does). I do not want to control it from my receiver via my remote because it is out of sight to my remote (ie., I can't!). I've searched the threads and can't find anything on how to get Sage to adjust the S/PDIF digital volume. Any help appreciated!
HDHomeRun x2 Cable Box via Hauppauge HD PVR and USB-UIRT 2 SageTV's HD300 Intel Core 2 Quad Q9650 @4025 MHz, 8G G.Skill Performance DFI Lanparty DK X48-T2RS Plus; SilverStone Decathlon DA1000 (died - back to an ancient enermax) eVGA 7900 GT KO RoHS -- Zalman VP900CU Cooling Synology NAS 22TB Last edited by davidk21770; 05-09-2012 at 04:22 PM. |
Generally speaking, controlling volume in the digital domain is not a good practice. Maybe your receiver has an optional IR extender input?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.10.3, sagetvopen-sagetv-server-opendct-java11 Docker (version 2.0.6) Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
I thought that it just changed a volume field in the data stream (not a real change).
It's being done by windows anyway unless I have the wave volume at max.
HDHomeRun x2 Cable Box via Hauppauge HD PVR and USB-UIRT 2 SageTV's HD300 Intel Core 2 Quad Q9650 @4025 MHz, 8G G.Skill Performance DFI Lanparty DK X48-T2RS Plus; SilverStone Decathlon DA1000 (died - back to an ancient enermax) eVGA 7900 GT KO RoHS -- Zalman VP900CU Cooling Synology NAS 22TB |
There's no volume metadata in the audio stream, any volume change is "real".
The bigger issue is that digital can be a bitstream, ie an AC3 or DTS stream, and this simply cannot be changed because they are not audio, they are "data" until they reach your AVR. |
In my earlier days of actually building a client HTPC box, I went the route of loading a software AC3 decoder and linking analog to my receiver just so I could control volume. It was a PITA to keep the stack working, plus in those days the decoder chewed up a lot of CPU. I found an offboard decoder that would take TOSLINK and decode to 6 analog channels with a built in IR receiver for volume control. I was able to map the volume control and was happy for a while.
When Sage brought out their HD-x00 media extenders, I flipped back around and relocated the amp with the media extenders. Looks to me like the trade off is you can run one cable (TOSlink or Coax) to take a digital stream to the amp and run an IR repeater to control volume - the Two Cable approach. OR, you can run 6 line level cable pairs and get a decoder box to set alongside your media extender for local digital volume control - the Six Cable approach. Sure wish the HDMI CEC was there and "just worked":-) Here is a link to a preamp decoder similar to my first attempt. Good luck. http://www.hdtvsupply.com/dolby-ac3-...o-decoder.html
Frankentivo: iStar D-380HB, SuperMicro X107-F-O, Xeon 1270v3 CPU, Kingston 8 GB 1600MHz DDRR3L x 4 Tuners: 4 x HDHR OTA, 4 x HDHR3 OTA, 3 x HDHR Prime UnRAID Pro: 1 x Samsung 500GB Cache, 5 x WD Red 4TB (1 Parity, 4 Data) Extenders: 2 x HD-200, 1 x HD-300 on Atlona PRO3HD66m Sage: V9.0.14.567 with OpenDCT on unRaid docker, Gemstone, BMT, Web UI, PlayOn, TiSage |
I think AC3Filter enables you to do this. Not sure, though -- give it a try.
I believe that I am using the AC3 decoder. Maybe that's why I can control the digital output via wave volume -- but sage won't adjust it (well, my wife tells me that it works for a few of her shows, but not most and I haven't had a chance to check to see what's common).
BUT, I ended-up putting a mirror on a desk that faces my receiver so I can direct my remote at the mirror and control my receiver. Low tech, but working quite well ![]() Thanks for the inputs!
Update! It can be done by Sage!
It is possible to get sage to control the wave volume.
Edit the properties file and change: media_player_uses_system_volume=false Note that this sometimes has the side effect of sage leaving the wave volume at 0 on exit. I made an ahk script (auto hot keys) to restore the volume to my defaults.
Master Volume Control and SageTV Volume | jdamore | SageTV Software | 0 | 03-21-2009 10:31 AM |
How to make SageTV volume control reflect system volume controls? | kevinmd88 | SageTV Software | 0 | 02-27-2009 03:09 PM |
Vista volume control, how do I like sage to the hardware volume? | AJ Bertelson | SageTV Software | 1 | 11-23-2008 08:46 PM |
Volume control problems with digital out | bgorrell | Hardware Support | 20 | 06-17-2004 05:32 AM |
SageTV volume up seems to rebalance volume control? | carlgar | SageTV Software | 0 | 10-18-2003 01:51 PM |
