Old 10-25-2016, 01:11 PM
Ender Ender is offline
Upgrade to STV9, some plugins will not update
Hello all,
I recently performed an in place upgrade to SageTV 9. Now some of my plugins are flagged update available, but will not update. They are flagged incompatible due to HttpCore/Client 4.0.1.1 which are dependencies of livepvrdata4j.
Though nothing appears to be amiss, Phoenix api/Core Services (Currently on 2.5.13) will not update due to this as well as The Movie DB Library.
My question is, should I just bite the bullet, and do a clean install, or is this fixable? I could do either, just it has been at least five years since I did a full bare metal install.
I have attached a set of logs if it is found to be useful.
Old 10-25-2016, 04:15 PM
jusjoken jusjoken is offline
Before doing a clean install I would suggest uninstalling some plugins and then reinstall starting with the phoenix-api/core which itself will install many of the dependencies others will use.
k
Old 10-26-2016, 07:32 AM
the phoenix services in the new version require a newer java
Windows 7 64bit Home Premium
1tb 3 disk Recording Pool
all in a beautiful Antec 1200
HD100/HD300 extenders
Old 10-26-2016, 08:11 AM
Yes, at least java 1.7 I believe for many of the plugins going forward (really, most are programmed with 1.8 in mind).
Old 10-26-2016, 11:55 AM
Thank You everyone for the assistance. Not sure what fixed it, but I uninstall several addons until I could remove the httpCore/Client. Then all went well.
As for Java, already on 1.8.0_45
All seems well for now, just as long as SRE works with Game 2 tonight
Old 10-27-2016, 06:20 AM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
Will plugins automatically update once a newer Java is in place?
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 10-27-2016, 06:28 AM
No
Which plugins should we include as core plugins, if we were to auto-install plugins? stuckless SageTV Github Development 35 07-08-2016 04:01 PM
help with plugins after upgrade from 7.0.23 to 7.1.9 nettech_gt SageTV v7 Customizations 0 10-02-2011 09:45 PM
Suggestion: Plugin menu wording... upgrade & update Brent94Z SageTV Beta Test Software 3 06-07-2010 04:15 PM
SageTV's instruction re 6.1 upgrade (update) stevech General Discussion 4 04-13-2007 05:19 AM
