Old 11-30-2009, 09:33 AM
rdefino rdefino is offline
Problem when running in Win7 64bit
I have sagetv running on win7 32bit fine. So Loaded up a drive with win7 64 bit and installed sage and then copied over my wiz.bin & properties file. But sage won't see my recording. Then I was a sagetv directory under the programs files too so I copied the wiz.bin file to it. Still won't see my recording.
Any thought?
SageTv server: 2008 64 BIT R2, Asus MN2-E, AMD dual core 4200, 4gb ram, Promise raid 5 8TB, 80gb Sata boot drive w/OS, 2/ dual tuner HDhomeruns, HD-PVR
3/HD-100's, 1/HD-200
Old 11-30-2009, 12:47 PM
Rico66 Rico66 is offline
Default installations of 32 bit apps end up under program files (x86). So unless you changed your installation path sage is now under program files (x86)\sagetv, whereas your sage.properties file still has references to program files\sagetv. Therefore you will need to edit the properties file to fix this.
Problem with Win7, SageTV Service, and WHS AzJazz SageTV Software 2 11-08-2009 05:01 PM
Anyone running 64bit with SageTV on Linux? bcjenkins SageTV Linux 74 07-05-2009 12:59 AM
Deleting while shows are running problem. TheraEdge SageTV Software 1 09-11-2007 12:25 PM
To 64bit or not to 64bit teknubic Hardware Support 19 07-25-2006 10:57 AM
Problem running Sage as Service Hector SageTV Beta Test Software 0 10-17-2004 03:17 AM
