Old 03-24-2010, 06:33 PM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
Hauppauge 2250 no channels in Win7 64bit
I have a dual boot system with XP-Pro 32bit and WIN7 64bit. I tried a complete scan and it found no channels. I copied the frq and scn files from the XP install and still no luck...
I have the latest version of Sage install and this is a fresh install on Win7 Enterprise 64bit
If this doesn't work right, Then:
"I'm going to blow up the Earth!"
Old 03-24-2010, 06:53 PM
HelenWeathers's Avatar
Are you running the drivers that MS loaded during the install or the drivers from the Hauppauge web site?
IIRC, I had problems with the MS drivers but ended up OK with the Hauppauge drivers.
I was doing OTA ATSC only (you didn't mention ATSC vs QAM). And I'm on Win 7 32bit.
EDIT: This whole thread is on the 2250 but much of it is from before Win 7. But there's some info a bit before and after this post:
http://forums.freytechnologies.com/f...&postcount=147
Old 03-28-2010, 09:34 AM
QuasiInsomniac QuasiInsomniac is offline
Exact same problem. Any solution to this yet? Ironic the timing isnt it? I am using the Hauppauge drivers.
I have Win 7 64-bit with a HVR-1800 and HVR-2250. The 1800 sees QAM channels fine, but a scan with the 2250 yields no results. I have also copied the freq files over.
Newbie setup question - 2250, Win7 x64 hijakk Hardware Support 5 03-14-2010 01:00 PM
hvr 2250 analog recording quality w7 64bit? JonTom Hardware Support 1 12-06-2009 03:55 PM
Problem when running in Win7 64bit rdefino SageTV Software 1 11-30-2009 12:47 PM
Hauppauge 2250 and recording 2 channels from cable box bphillips41 Hardware Support 10 06-13-2009 07:20 AM
Server 2003 64bit drivers for hauppauge 1800?? CaptSammy Hardware Support 0 02-16-2008 07:45 PM
