Old 12-18-2008, 12:52 PM
ajkalb ajkalb is offline
Installation Crashes
I am trying to install SageTV on Windows XP.
Each time I tried to install, I would get one question further in the initial setup queries before it crashed.
Finally, I have gotten to the path setup menu and can get no further without a crash.
The crashes do not BSOD. Everything goes black and doesn't reset.
Has anyone seen similar issues? Is there a fix?
My machine is configured as follows:
Athlon x64 (2.6GHz, I think)
Asus A8N-VM CSM (with latest BIOS).
Hauppauge HVN-2250
NVidia 8600GT
Montego 7.1
Windows XP SP3
I have the most recent drivers on everything.
Old 12-18-2008, 01:39 PM
vexhold's Avatar
vexhold vexhold is offline
What does your Event Viewer say happened?
Old 12-18-2008, 02:23 PM
Event Viewer?
Thanks for the reply.
Event Viewer ... I'm not sure what you mean by that?
Could you please clarify?
Thanks.
Old 12-18-2008, 02:25 PM
vexhold's Avatar
Right click on "My Computer"
Choose Manage
Click on the plus next to Event Viewer
There will be four catagories here with windows error messages.
Look in either System or Application
Red is usually error messages (ie crashes) yellow is a warning flag
Old 12-18-2008, 04:34 PM
Will try.
Thanks vexhold.
I will try this tonight when I'm in front of the machine.
crash, install
C+ Library crashes with DTV Serial/UIRT control? heffe2001 SageTV Beta Test Software 6 11-19-2008 01:49 PM
Capture card installation order? JmpnJimBob Hardware Support 0 11-19-2008 12:12 PM
SageMC v6.3.8 Installation Survey MeInMaui SageMC Custom Interface 20 11-08-2008 03:32 PM
Upgrading Installation Advice Tenspeed SageTV Software 2 10-25-2008 12:12 PM
HDHR and HDPVR channel changing problem - sage client crashes rubell SageTV Software 2 09-03-2008 11:21 PM
