Old 07-11-2010, 06:15 AM
Exclamation Placeshifter Functionality
First a little background. I run SageTV as a service on a WHS machine. I use an HD200 or Placeshifter to access the SageTV server.
I recently decided to add a HTPC to my environment. I was using Placeshifter to set the configuration options. When I tried to set the remote control function, I could not find any menu item to let me choose which remote to use. I finally remoted into the WHS server and brought up SageTV. That is when I discovered the “Remote Control Configuration” menu item is NOT available through Placeshifter.
I was just wondering what other functionality is not available in Placeshifter?
John
Old 07-11-2010, 09:58 AM
DVD/BD playback. Hardware Accellerated playback. If you are setting up an HTPC, you DON"T want to use placeshifter. SageTVClient is the proper software for that application.
Old 07-12-2010, 09:01 PM
I am pretty sure that Placeshifter also doesn't work with 1080i content from the HD-PVR - at least it didn't used to.
Old 07-13-2010, 05:52 PM
bsung bsung is offline
It works if you consider a 1+ second audio lag (or being too early, don't remember which) something that you can live with. I never had much luck letting Sage choose the right bandwidth to use b/c my buffer still seems to run out too often, but with a fixed bandwdith, you can get video and audio with 1+ second lag.
Old 07-15-2010, 12:45 AM
Spectrum Spectrum is offline
Yeah Placeshifter does not get along with any interlaced content from the HDPVR, even 480i across a gigabit connection is un-playable for me. It's not the bandwidth required, it has something to do with the way Placeshifter handles the interlaced content produced by the HDPVR. I gave up and set my STB to 720P and haven't looked back.
Fuzzy is right, client is the best way to accomplish what you are after.
placeshifter, whs
PlaceShifter Functionality shhas SageTV Placeshifter 2 04-29-2006 04:43 AM
Confusing Functionality??? Deadbolt SageTV Software 3 10-21-2004 04:37 PM
has this functionality been added? JPW SageTV Beta Test Software 19 04-24-2004 07:11 AM
