Old 08-29-2010, 04:44 PM
hogburgs's Avatar
hogburgs hogburgs is offline
ComskipPlayback plugin install failed
SageTV V7.09.230
Java Vr. 1.6.0_21
Windows 7 Home Premium, fully updated.
Tried to install Comskip Playback by JREkiwi from the Sage 7 plugin installer. It fails, seems to not fully extract a zip file. I get a dialog “Plugin Install Progress: Done - Failed - Zip Extraction of http//download.sagetv.com/plugins/JREkiwi/ComskipPlayback/Comskip_Playback_Sample.zip” I hit the close button and get “The UI needs to be reloaded...etc”.
Did a search of these forums but didn’t find any referance to install problem like this. Please help.
I don’t have any plugins installed at this time.
Old 08-29-2010, 05:06 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Originally Posted by hogburgs View Post
SageTV V7.09.230
Java Vr. 1.6.0_21
There is a bug in 7.09 where it doesn't create directories in the zip file. It's fixed in later versions of SageTV.
John
Old 08-29-2010, 05:43 PM
JREkiwi's Avatar
You could manually create the directory C:\Program Files\SageTV\SageTV\STVs\SageTV7\Externals with any non-default paths adjusted as required.
The plugin should install after that.
John
Old 08-29-2010, 07:51 PM
hogburgs's Avatar
That worked
Thank you John, that worked perfectly.
Ken
plugin, install once, available everywhere? Deacon Crusher SageTV Beta Test Software 4 07-23-2010 12:52 PM
Plugin Request: Configuration before install PLUCKYHD SageTV Studio 16 07-07-2010 04:43 AM
Using Mythcommflag to create an EDL (ComskipPlayback-compatible) skip file on Linux touchstone SageTV Customizations 9 06-29-2010 06:09 PM
SageTV install location drive failed alwzn4vr SageTV Software 2 06-13-2010 07:15 PM
