Old 06-29-2009, 02:53 AM
nathkrul nathkrul is offline
importing .xml, how do you do it.
Hi, I have downloaded the sagetv application, which is far better than the vista mc interface, although I couldnt get the spdif to work in XP it works ok in my vista ultimate.
Now my question, I have sagetv working great, I downloaded the imovies plugin, is says to copy the 2 folders over to the sagetv directory then import the .xml, but I am stumped as to how you import the .xml. I tried importing it using the settings/detailed setup/advanced, I tried the sagetv application package importer, but after selecting the .xml imovies it broke the interface and I had to copy the backup sagetv I made back over.
The manage stv plugins does'nt see the .xml, so how do you do it.
I have searched the forum with various search criteria but to no avail, I am stumped please help, I would like to get the imovied working with my HD films.
Thank you
Colin
Old 06-29-2009, 03:38 AM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
iMovies is an import for the SageMC alternate user interface. It will not work in the default SageTV UI.
Aloha,
Mike
- Nikolaus (4yrs old)
Importing STVi's as XML files brb84 SageMC Custom Interface 3 08-22-2008 05:11 PM
Utility: BTV XML to Sage XML converter nielm SageTV Customizations 4 01-06-2008 04:00 PM
Stoopid newbie question - simple XML edit SageTV3.xml pseudonym SageTV Studio 3 08-12-2007 06:44 PM
importing stvi/xml question Chroner SageTV Customizations 7 12-03-2006 10:46 AM
problems with importing xml data 1972 SageTV EPG Service 4 07-04-2004 05:37 AM
