Old 05-20-2003, 06:38 AM
rrussell's Avatar
rrussell rrussell is offline
Trouble importing old MPG files
So as a result of switching to SageTV, I have a couple of dozen old MPG files from my WinTV days, named things like "Show001.mpg", "Show002.mpg", "Show003.mpg" etc.
I plopped them into the "import" directory, and the prog dutifully imported two of them into the library. But, no matter what I do, it won't import the rest:
I've tried moving them and resetting the import dir option.
I've tried moving them out and back into the same import dir.
I've tried it one at a time, and all at once.
Any suggestions? Is the naming convention an issue? It doesn't seem to be a date/timestamp thing...
R
Old 05-20-2003, 07:06 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
If you're using the beta version, the log file will tell you why it rejected any imports. Just look for the file name. Let me know why, and then I can help more.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-21-2003, 06:07 AM
rrussell's Avatar
Roger that. I'm using 1.2.8 so no log. I'll see if I can't get to it this weekend (or, hopefully, sooner).
Old 05-21-2003, 03:33 PM
rrussell's Avatar
Aha! I got to it sooner than this weekend.
I'm attaching the txt file.
A quick search for "import" led me to lines like:
Wed 5/21 17:19:38.835 testFile=D:\Program Files\Frey Technologies\SageTV\Import\1000000 Years BC.MPG
Wed 5/21 17:19:39.065 MF Failed Init:MediaFile[FA[BAD AIRING] host=pvr D:\Program Files\Frey Technologies\SageTV\Import\1000000 Years BC.MPG, Seg0[Sun 3/2 15:02:00.820-Sun 3/2 15:02:00.820]]
Are the mpgs corrupt?
LMK what you found...
Rob
Old 05-21-2003, 06:39 PM
Narflex's Avatar
Sage
If you open one of those MPG files in WMP what's the duration on it?
That failure occurs when the file is reported as being of zero length duration (so it assumes the MPG file's corrupted).
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-21-2003, 07:26 PM
rrussell's Avatar
Well, for example, 10000000 years BC reports 2:02:16 in length.
The "Enterprise" episodes all say somewhere around 1 hour, which is right where they should be.
Can I send you one somehow? They're sizeable, as you can imagine.
Old 05-22-2003, 05:47 PM
Narflex's Avatar
Sage
How about you just cut off the first couple minutes of one, and then try to import that. It it still fails, and WMP reports a couple minute duration, you can then send me that file easily.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-23-2003, 06:43 AM
rrussell's Avatar
Sure... um.
Care to recommend a tool for that?
Old 05-23-2003, 11:38 AM
Narflex's Avatar
Sage
Here's one I wrote for it. Just put the .class file in the same folder as what you want to copy.
Then go to DOS, cd into that directory and type:
java HeadCopy sourceFile.mpg destinationFile.mpg 200000
That'll copy the first 200000 bytes from sourceFile.mpg to destinationFile.mpg
File Type: zip headcopy.zip (603 Bytes, 209 views)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-26-2003, 11:59 AM
rrussell's Avatar
OK, done - still didn't import.
The (apparently) relevant segment of SageTV_0.txt reads:
Mon 5/26 13:42:06.220 MARK 1 currRecord=null enc=Hauppauge WinTV PVR PCI II Capture clients=[]
Mon 5/26 13:42:06.230 Seeker in AUTOMATIC mode nextRecord=A[193015,192256,"Treasure Makers",14902@0527.10:30,30] nextTTA=74873780
Mon 5/26 13:42:06.230 newRecord=null
Mon 5/26 13:42:06.230 NOTHING TO RECORD FOR NOW...
Mon 5/26 13:42:06.230 VF processing job null nPlayin=false
Mon 5/26 13:42:06.230 VF thread is now waiting for 0:00:00.000
Mon 5/26 13:42:06.531 testFile=D:\Program Files\Frey Technologies\SageTV\Import\enterprise_clipped.mpg
Mon 5/26 13:42:10.576 UIManager.gotoSleep(false) isTaskbar=true
Mon 5/26 13:42:10.636 setUI(sage.t@126ecd2)
Mon 5/26 13:42:12.429 setUI(sage.t@243e61)
Mon 5/26 13:42:12.559 MF Failed Init:MediaFile[FA[BAD AIRING] host=pvr D:\Program Files\Frey Technologies\SageTV\Import\enterprise_clipped.mpg, Seg0[Mon 5/26 13:41:51.008-Mon 5/26 13:41:51.008]]
Mon 5/26 13:42:12.559 testFile=D:\Program Files\Frey Technologies\SageTV\Import\HeadCopy.class
Mon 5/26 13:42:14.752 MF Failed Init:MediaFile[FA[BAD AIRING] host=pvr D:\Program Files\Frey Technologies\SageTV\Import\HeadCopy.class, Seg0[Thu 3/27 13:47:28.000-Thu 3/27 13:47:28.000]]
Mon 5/26 13:42:16.795 Seeker waiting for 1245 mins.
At this point, WMP doesn't recognize any length in that file, though, or play anything beyond the first couple of frames, it seems. I clipped the first 200K bytes as suggested from enterprise001.mpg. Also tried with a 2meg chunk. Also tried changing directories. Nothin's working... yet!
Do you need the whole log file?
Rob
Old 05-27-2003, 01:05 PM
rrussell's Avatar
Actually, so - it is still failing to import, but WMP is reporting no duration. What can I do next?
Old 05-27-2003, 07:56 PM
Narflex's Avatar
Sage
Email that small MPG file to support@freytechnologies.com that's what I need.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-28-2003, 07:53 AM
rrussell's Avatar
Will do. I'll try to get to it tonight, or next monday at the latest. (ha)
FWIW I was looking through those old mpg files and none of them are ones that I really NEED to keep. If this has not yet become an o-fish-al bug that you want to fix, I'm happy to let it drop.
OTOH if you wanna fix it (and who wouldn't) I'm also happy to send you the file.
Old 05-28-2003, 03:02 PM
Narflex's Avatar
Sage
No one else is currently reporting a problem with it. But a bug is a bug and should be fixed regardless of it currently affects anyone. Send me the file when you get around to it.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-29-2003, 06:18 AM
rrussell's Avatar
OK, it is on its way. Enjoy! (?)
Old 06-07-2003, 06:44 PM
Lester Jacobs Lester Jacobs is offline
I'm also having problems importing files. I put two files in the import directory, stopped and restarted SageTV and the files were not imported. These same files play fine in PowerDVD and can be read and processed by Ulead without any problems. They are SVCD compliant mpeg-2 files.
Any ideas on what could be wrong?
UPDATE: Just tried SageRecorder and it can see and play the files. This seems to prove that the files themselves are not corrupt. Therefore I don't know why SageTV is rejecting the files.
Lester
Lester Jacobs
Web: http://www.digicasa.com
"The shortest answer is doing."
English Proverb. Collected in: George Herbert, Jacula Prudentum (1651).
Old 06-08-2003, 08:17 AM
Omegadsl Omegadsl is offline
Lester
Is this with all mpeg-2 files or only the ones that are SVCD compliant? For me, it's all mpeg-2 files that won't import.
Old 06-08-2003, 01:32 PM
Narflex's Avatar
Sage
Create this registry variable as a DWORD and see if any error messages come up when you run SageTV:
HKLM\Software\Frey Technologies\Common\consolewin=1
Jeffrey Kardatzke
Google
Founder of SageTV
Old 06-08-2003, 08:55 PM
I get the following when I start up SageTV (with or without files in the import directory;
Sun 6/8 22:52:18.357 Failed to find:\\?\display#ntativrv26#5&2f4fd774&0&80000008&01&00#
Cheers
Lester
Lester Jacobs
Old 06-09-2003, 09:43 AM
Jeff, are all three of us having the same problem or are different things messed up on each of our systems? I want to help find what is causing this but if it can not be fixed I might attempt a clean install (of XP, etc.). The reason I am reluctant to do that, is because I have no idea what caused this and I am not sure it won't happen again (since I'll probably install the conflicting software again).
