Old 03-17-2008, 10:57 PM
hchucky hchucky is offline
Capture Devices Gone After Reboot
I removed my Divco FusionHDTV card over the weekend and installed a ROCKETRAID controller card. Before removing the Fustion card I uninstalled the software and rebooted. After installing the RAID card the system performed well for the rest of the weekend.
This afternoon it crashed with what looked like a permissions issues accessing the media share. I rebooted the box, started SageTV and all of my tuners are gone.
On a related note it does not appear that Fustion cleaned up all the driver entries properly. I was getting the "The FusionHDTV 88x, WDM Crossbar service failed to start due to the following error:
The system cannot find the file specified." error until I went into Autoruns and deselected the "system32\drivers\zl88xbar.sys" so it would not try and load it.
I am running the latest version 6.3.10 with 2 PVR250 and 1 PVR350 cards loaded.
Slice of the debug log:
Mon 3/17 23:42:32.406 MMC calling detectCaptureDevices on sage.cc@587c94
Mon 3/17 23:42:32.410 devices detected=[]
Mon 3/17 23:42:32.411 EncoderMap={}
Mon 3/17 23:42:32.411 MMC calling detectCaptureDevices on sage.l@15b0afd
Mon 3/17 23:42:32.416 Device detecting->:{65E8773D-8F56-11D0-A3B9-00A0C9223196}
Mon 3/17 23:42:32.475 Device detecting->:{FD0A5AF4-B41D-11d2-9C95-00C04F7971E0}
Mon 3/17 23:42:32.485 Device detecting->:{71985F48-1CA1-11d3-9CC8-00C04F7971E0}
Mon 3/17 23:42:32.486 systemCapDevices=[NVIDIA(R) nForce(TM) Audio, Hauppauge WinTV PVR PCI II Capture, Hauppauge WinTV PVR PCI II Capture, Hauppauge WinTV PVR PCI II Capture]
Mon 3/17 23:42:32.487 Checking encoder key:551195576
Mon 3/17 23:42:32.496 Created DShowCapDev object for:Hauppauge WinTV PVR PCI II Capture #3
Mon 3/17 23:42:32.496 Checking encoder key:-1785355725
Mon 3/17 23:42:32.497 Created DShowCapDev object for:FusionHDTV, Transport Stream Capture
Mon 3/17 23:42:32.498 Checking encoder key:1642691032
Mon 3/17 23:42:32.499 Created DShowCapDev object for:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.500 Checking encoder key:551195575
Mon 3/17 23:42:32.501 Created DShowCapDev object for:Hauppauge WinTV PVR PCI II Capture #2
Mon 3/17 23:42:32.502 EncoderMap1={Hauppauge WinTV PVR PCI II Capture #3=Hauppauge WinTV PVR PCI II Capture #3, FusionHDTV, Transport Stream Capture=FusionHDTV, Transport Stream Capture, Hauppauge WinTV PVR PCI II Capture=Hauppauge WinTV PVR PCI II Capture, Hauppauge WinTV PVR PCI II Capture #2=Hauppauge WinTV PVR PCI II Capture #2}
Mon 3/17 23:42:32.543 Capture device Hauppauge WinTV PVR PCI II Capture (2) exists
Mon 3/17 23:42:32.580 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-10 (1 0) select
Mon 3/17 23:42:32.580 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-2 (\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-10' id:'PCI\VEN_4444&DEV_0803&SUBSYS_40000070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.584 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.585 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.585 BDA capture is not found on location:'pci:1-10' id:'PCI\VEN_4444&DEV_0803&SUBSYS_40000070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.585 debug BDA CaptureDetail:0x0 hasBDAInput:0x0
Mon 3/17 23:42:32.590 CaptureFilter in AM_KSCATEGORY_CAPTURE
Mon 3/17 23:42:32.590 DeviceCap: 0x10810
Mon 3/17 23:42:32.609 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-10 (1 0) select
Mon 3/17 23:42:32.609 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-2 (\\?\pci#ven_4444&dev_0803&subsys_40000070&rev_01#4&3b1d9ab8&0&5040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-10' id:'PCI\VEN_4444&DEV_0803&SUBSYS_40000070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.611 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.611 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.611 BDA capture is not found on location:'pci:1-10' id:'PCI\VEN_4444&DEV_0803&SUBSYS_40000070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.611 BDA FindVideoPin:0xad9ecc hasBDAInput:0 on Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.615 not found tuner pin in crossbar for device, try search second cross bar Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.615 Encoder failed the check:Hauppauge WinTV PVR PCI II Capture #3
Mon 3/17 23:42:32.616 Permanently ignoring encoder:Hauppauge WinTV PVR PCI II Capture #3
Mon 3/17 23:42:32.616 Removing encoder because it failed the check:Hauppauge WinTV PVR PCI II Capture #3
Mon 3/17 23:42:32.616 Saving properties file to C:\Program Files\SageTV\SageTV\Sage.properties
Mon 3/17 23:42:32.716 Capture device FusionHDTV, Transport Stream Capture (0) does not exist
Mon 3/17 23:42:32.717 Encoder failed the check:FusionHDTV, Transport Stream Capture
Mon 3/17 23:42:32.726 Saving properties file to C:\Program Files\SageTV\SageTV\Sage.properties
Mon 3/17 23:42:32.769 Removing encoder because it failed the check:FusionHDTV, Transport Stream Capture
Mon 3/17 23:42:32.774 Capture device Hauppauge WinTV PVR PCI II Capture (0) exists
Mon 3/17 23:42:32.782 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-7 (1 0) select
Mon 3/17 23:42:32.782 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-0 (\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-7' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.784 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.784 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.784 BDA capture is not found on location:'pci:1-7' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.784 debug BDA CaptureDetail:0x0 hasBDAInput:0x0
Mon 3/17 23:42:32.789 CaptureFilter in AM_KSCATEGORY_CAPTURE
Mon 3/17 23:42:32.789 DeviceCap: 0x10810
Mon 3/17 23:42:32.807 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-7 (1 0) select
Mon 3/17 23:42:32.807 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-0 (\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&3840#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-7' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.809 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.809 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.809 BDA capture is not found on location:'pci:1-7' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.809 BDA FindVideoPin:0xade9cc hasBDAInput:0 on Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.812 not found tuner pin in crossbar for device, try search second cross bar Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.812 Encoder failed the check:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.812 Permanently ignoring encoder:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.813 Removing encoder because it failed the check:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.818 Capture device Hauppauge WinTV PVR PCI II Capture (1) exists
Mon 3/17 23:42:32.826 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-8 (1 0) select
Mon 3/17 23:42:32.826 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-1 (\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-8' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.828 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.828 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.828 BDA capture is not found on location:'pci:1-8' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.828 debug BDA CaptureDetail:0x0 hasBDAInput:0x0
Mon 3/17 23:42:32.833 CaptureFilter in AM_KSCATEGORY_CAPTURE
Mon 3/17 23:42:32.833 DeviceCap: 0x10810
Mon 3/17 23:42:32.853 BAD Tuner index :1 dev:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture name:@device:pnp:\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture loc:pci:1-8 (1 0) select
Mon 3/17 23:42:32.854 Check BDA capture device:Hauppauge WinTV PVR PCI II Capture-1 (\\?\pci#ven_4444&dev_0016&subsys_40090070&rev_01#4&3b1d9ab8&0&4040#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\hauppauge wintv pvr pci ii capture) on location:'pci:1-8' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' [state1, index:0] .
Mon 3/17 23:42:32.855 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{03884cb6-e89a-4deb-b69e-8dc621686e6a}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.855 >>BDA capture device found:@device:pnp:\\?\root#system#0000#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{8e60217d-a2ee-47f8-b0c5-0f44c55f66dc}&global; loc:'' id:'root\swenum'
Mon 3/17 23:42:32.855 BDA capture is not found on location:'pci:1-8' id:'PCI\VEN_4444&DEV_0016&SUBSYS_40090070&REV_01' for Hauppauge WinTV PVR PCI II Capture.
Mon 3/17 23:42:32.855 BDA FindVideoPin:0x53a0a4c hasBDAInput:0 on Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.858 not found tuner pin in crossbar for device, try search second cross bar Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.859 Encoder failed the check:Hauppauge WinTV PVR PCI II Capture #2
Mon 3/17 23:42:32.859 Permanently ignoring encoder:Hauppauge WinTV PVR PCI II Capture #2
Mon 3/17 23:42:32.859 Removing encoder because it failed the check:Hauppauge WinTV PVR PCI II Capture #2
Mon 3/17 23:42:32.859 Processing new system dev:NVIDIA(R) nForce(TM) Audio
Mon 3/17 23:42:32.859 Processing new system dev:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.859 Device already has been processed
Mon 3/17 23:42:32.860 Processing new system dev:Hauppauge WinTV PVR PCI II Capture
Mon 3/17 23:42:32.860 Device already has been processed
Mon 3/17 23:42:32.860 devices detected=[]
Mon 3/17 23:42:32.860 EncoderMap={}
Old 03-17-2008, 11:10 PM
See if the tuners are listed on the mmc/ignore_encoders property line in sage.properties. If they are, make sure SageTV is not running, make a backup copy of the properties file, edit sage.properties to remove that property line, then restart SageTV.
Old 03-18-2008, 06:57 AM
Thanks Andy, I checked that property and the Fusion was listed but not the Hauppauge tuners. I cleared it anyway but the results are the same, no tuners present.
FWIW the Hauppauge tuners still show up fine in Device Manager.
HC
mmc/ignore_encoders=BDA Slip De-Framer|NVIDIA DualTV YUV Capture|SB Live\! MIDI Port [9400]|NVIDIA(R) nForce(TM) Audio|BDA MPE Filter|FusionHDTV, WDM Video Capture|NVIDIA DualTV YUV Capture 2|FusionHDTV, BDA Tuner|SB Live\! Audio [9400]|FusionHDTV, AvStream Audio Capture|
Old 03-18-2008, 10:36 AM
What OS are you using? If you are using Vista, are you sure you chekced the correct properties file? (There's a FAQ about where that file is located in Vista.)
Otherwise, contact support because the log says the tuenrs are being permantently ignored. Maybe thigns need to be reinstalled after the crash, though.
Old 03-18-2008, 11:16 AM
I am using WindowsXP. I checked the properties file in C:\Program Files\SageTV\SageTV\Sage.properties.
I will open up a ticket with support.
Tom
Old 11-14-2008, 12:37 PM
perfessor101 perfessor101 is offline
Same Problem here ...
Hello,
I have a Bad Tuner Index problem too latest SageTV release 2008 Nov 14 ...
I had it a week ago and did a restore from Acronis True Image ... but this takes a two or more hours ... and I need to sleep in less that that. (Love it when a system goes wonky just before bed time) also it seems it will be back within a week ...
Did you find a fix?
Thanks for your time,
Bobby
ps -- Program Mode for SageTV still works I guess until a Crash ...
SageTV Server: Windows 7 64Bit, Phenom II X6 1090T, Asus M4A89GTD-PRO/USB3 (AM3), ATI Radeon HD 4290, 2 x KHX1600C9D3/4GX, 4 x HD-PVR2 Gaming, , 4 x 320GB recording drives, 2 x USB-UIRT, SageTV Server Beta
SageTV Client & 2 x HD-300 Extender.
40.8TB unRaid 6.6.5 media server
Old 11-14-2008, 10:24 PM
I rebuilt my system. It was the only way I was able to resolve the issue. I started to experience other drive related issues after the rebuild. Turns out the power supply was bad.
HC
Puzzled: Sage not using 3rd tuner wvpolekat SageTV Software 2 11-15-2007 01:36 PM
Fusion 3 devices now listing both WDM capture AND TS capture DavidFeinzeig SageTV Software 2 01-09-2006 09:01 AM
AUUUGH I Give UP!!! TripleTapper SageTV Media Extender 46 01-03-2006 02:35 PM
