Old 11-20-2009, 02:06 PM
Addict's Avatar
Addict Addict is offline
Question SageTVTranscoder Utiliztion Issues with Placeshifter
Hi folks,
Trying to use my Placeshifter on HD (from HD-PVR) content, but am getting choppy playback (brief pause every couple of seconds). The situation:
* Placeshifter CPU is minimally used, it's not a local playback issue.
* Changing the Placeshifter to force low-bandwidth streaming (i.e. auto vs. 250kbps) does not change playback at all. I have a 1Mbps outbound pipe from my server.
* Placeshifting works perfectly on SD content.
* I see that the SageTVTranscoder process is hovering around 50% CPU utilization on my dual-core, but will never go any higher.
* I've attempted to raise the priority of the SageTVTranscoder to "High" and "Realtime" from the default "Below Average" setting, but that doesn't help either.
Is there any way to get the SageTVTranscoder to use more than 50% of my CPU capability so it can transcode in a timely fashion?
Server specs in my signature...
Al Bsharah / Twitter
Clients:
Two STX-HD100 High-Def Extenders
Media Server / NAS:
Case: Thermaltake Armor CPU: AMD Opteron 1218 (2.6GHz Dual Core) Motherboard: ASUS MN2-LR Memory: 2GB Gfx Card: Headless Tuner: Hauppauge HD-PVR, Hauppauge PVR-350 (not in use) O/S: Windows 7 Sage: Latest RAID: On-Board Drives: 6 x 1.5TB SATA RAID-5, 2 x 80GB IDE RAID-1 (O/S) Storage: 7.5TB Total
Old 11-20-2009, 02:25 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Short answer: no. Transcoding is (currently) single-threaded, meaning that it can't split the work across multiple cores. It can use all of one core, but not more than that (unless of course you have multiple clients running multiple transcoding jobs). For now, higher CPU clock speed is the only way to increase transcoder performance.
-- Greg
Old 11-20-2009, 04:59 PM
Addict's Avatar
Bah, really? That's a shame. Just upgraded my system, so another upgrade isn't on the horizon. It's still surprising to me how few applications are multi-threaded considering the widespread use of multi-core systems...
Clients:
Media Server / NAS:
Old 11-23-2009, 02:53 AM
freedml freedml is offline
If you're on a local network Placeshifter will not usually dynamically change its bandwidth usage. You need to fool it into thinking it's working over the internet (search dyndns on the forums) so it will do the best it can.
choppy, cpu, placeshifter, playback, transcode
Placeshifter Router issues... STV-Newbe SageTV Placeshifter 8 11-08-2008 07:19 PM
Audio Issues with Placeshifter taylormadearmy SageTV Placeshifter 1 03-10-2008 04:18 PM
Mac Placeshifter issues ptaylor SageTV Placeshifter 8 12-21-2006 07:36 PM
Mac Placeshifter issues? FidgetyRat SageTV Placeshifter 3 12-20-2006 12:06 PM
Issues: Linux Placeshifter jroe SageTV Placeshifter 4 08-13-2006 03:27 PM
