Old 09-05-2010, 06:15 PM
gabrielcab gabrielcab is offline
WinTV-HVR-2250 IR for setup box
Hello, how can i make work the IR blaster from my WinTV-HVR-2250?, i have it working with MCE but with Sage i cannot manage to enable it to change channels for my setup box. thanks
Old 09-06-2010, 06:12 AM
Install the IR software that comes with the IR blaster before installing Sage. And then make sure the default box is checked in Sage to use it when you install Sage. ALso reference the Sage manual that is installed with the program.
Old 09-06-2010, 09:33 AM
Tiki's Avatar
Tiki Tiki is offline
IIRC, I think there was a setting in the Hauppauge configuration software where you told it whether you were using it with Windows MCE or something else. I'm not sure if this applied to the blaster, the IR receiver, or both. But, if you set it to MCE, it won't work for anything but MCE.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Hauppauge WinTV-HVR-2250 setup/install issue: Analog tuners not capturing CC text taylork Hardware Support 8 09-29-2010 07:23 PM
WinTV-HVR-2250 with HD DirecTV oldprogrammer Hardware Support 4 04-06-2009 01:10 PM
Hauppauge WinTV-HVR-2250 John.Kelly Hardware Support 7 12-23-2008 05:08 PM
WinTV-HVR-2250 IR Blaster ktriebol Hardware Support 2 11-07-2008 03:32 PM
WinTV-HVR-2250, Antenna, & Satellite Box ktriebol Hardware Support 11 11-05-2008 07:08 PM
