Old 04-12-2022, 02:04 PM
Channel display number when a channel is on multiple lineups
My local channels are available on both OTA and cable (via an HD-PVR). I would prefer if the OTA channels showed up under their OTA number. For example, I would like channel WGRZDT to show up as channel 2-1 in my guide. But it shows up as something like channel 517 which is the cable lineup number.
When a channel is on two lineups, both OTA and cable, how do I force it to show it in the guide under the OTA number rather than the cable number? I still want it to be available on all tuners in order to reduce any potential conflicts.
Old 04-12-2022, 04:49 PM
Tiki's Avatar
Tiki Tiki is offline
You have to go through the lineup and remap the channels. You need to change the logical channel number.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 04-13-2022, 09:53 AM
OK thanks. I am just speculating but it appears to me that the channel number used in the guide is based on a first come, first served basis. In other words, if the cable lineup is added to your system before the OTA lineup then the channel number used in the guide will be the one from the cable lineup.
Can anyone else confirm that?
Old 04-13-2022, 01:27 PM
Agree
Old 04-13-2022, 05:22 PM
KryptoNyte's Avatar
I concur.
I modified my tuners/lineups over the weekend, exactly opposite to the OP, so my OTA channel numbers appear in the guide instead of my cable-card channel numbers (I did confirm it's not based on tuner merit).
So then I started playing with the tuner merit feature in the SageTV UI on any server/client interface and found that although the channel number remains as OTA in the guide, it will in fact switch tuner priority from OTA to cable-card (without ever acknowledging the cable-card channel number) - and it will do this live, without a restart of the SageTV service.
multiple lineups - dual channel maps - conflicting channels - help! tvmaster2 SageTV Software 9 08-27-2018 01:23 PM
Enhancement: Add option to display channel names in channel guide sflamm Phoenix 0 07-26-2011 05:22 PM
Change channel label to use actual channel number hockeyfan SageTV Software 0 12-21-2010 08:01 PM
channel lineups from multiple providers shorki SageTV EPG Service 0 09-18-2006 10:36 AM
Access Same channel with multiple lineups that_kid SageTV EPG Service 2 02-14-2005 06:08 AM
