Old 07-21-2005, 06:14 PM
snoopy's Avatar
snoopy snoopy is offline
Time 'offset'?
I know I remember seeing something but can't locate it now. I need to offset the time shows start to exactly 10seconds later than scheduled due to the fact that my cable company is actually re-broadcasting there satellite feed. It's not actually the same feed as I once thought. DTV is 10 seconds behind the time that the same show is broadcast by my cable company.
Padding won't work due to conflict issues and I know I remember seeing something about 'offset'. Can anyone tell me where?
The newest v7 release of SageTV, now a free upgrade for existing owners of SageTV, is a dream come true for any TV enthusiast. Combine it with Play-On for Netflix and Hulu (among others) and no stone has been left unturned. SageTV is TV done right!
-- Snoopy
Old 07-21-2005, 06:23 PM
mlbdude's Avatar
mlbdude mlbdude is offline
Padding gets ignored in case of conflicts. I would suggest using that on your favorites.
Old 07-21-2005, 06:26 PM
snoopy's Avatar
where is the 'offset' option though? I remember seeing that somewhere.
-- Snoopy
Old 07-21-2005, 06:45 PM
mlbdude's Avatar
Never heard of an offset. Don't think Sage will let you do a default pad unless you use Neilms addon.
Old 07-22-2005, 03:05 AM
nielm's Avatar
nielm nielm is offline
The only mention of offset in the standard STVs is for video aspect ratio modification.
Note: Padding gets ignored for back-to-back favorites *on the same channel*, so faves on different channels will still have conflicts.
Old 07-23-2005, 01:42 AM
reboot_this's Avatar
reboot_this reboot_this is offline
There are videoframe "playback_delay" settings in the properties file, but that wouldn't help because that just sets the delay between when something is recorded to the time it is displayed on your tv/monitor...
you could always buy a time server program and sync your computer's time to a server that is about 10 seconds off... this is what I did, I sync to the utcnist.colorado.edu timeserver which for some reason is 10 seconds off of my local time and perfect for syncing my computer's time with comcast's time
HTPC HW: Gigabyte GA-EP45-UD3P, Intel Q9400, 2GB Corsair RAM, PNY Nvidia GT210 vid card, 3 HVR2250s, 2 PVR250s, USB-UIRT (2 STBs), Internal FireWire/Dual IDE Converter (IFC-1)
HTPC SW: XP Pro/SP 2, SageTV v7.1.5.252 Beta, Java v1.6.0_10, PVR drivers v1.18.21.23257, HVR drivers 7.6.1.27118
HD100 Extender: 2 (server is just a server)
Future plans: 1 more HVR2250, 1 Ceton CC 4-way tuner, 10TB diskspace
Issues: 1 PVR250 not working, system board?
Old 07-24-2008, 02:33 AM
CANightHawk CANightHawk is offline
Blowing the dust off this thread..
I too am interested in having properly synced time but that it be intentionally offset a few seconds forward, a duration of my choosing -- i.e. "proper NIST atomic time PLUS four seconds"
I have Time Warner Digital Cable, and for reason all their programming seems to be offset in relation to my system clock, by EXACTLY four seconds. On every channel. That can't be coincidence .. can it?
Called them on it, had them do a time check on their computers there, and sure enough their system is four seconds ahead, they did a trouble ticket several months ago but it hasn't changed anything. Eventually I just "lived with it."
Like previous posters, padding helps but is not really a fix, it's a band-aid only.. It gets kind of annoying for shows that are back-to-back and they all go up to the bitter end (MythBusters, Dirty Jobs, local news, etc).
Using Sage Client 6.45 on Core2Duo, Java is current 1.60_r6 [I think], and using current NVidia drivers. Only issue I have is the time being off by these pesky four seconds.
Whadaya think?
Old 07-24-2008, 03:18 AM
zzmystique's Avatar
zzmystique zzmystique is offline
this is something that bugs me to - some chanels here are 30 seconds out other are between 2 and 3 minutes and padding just doesn't work.
This is definately a feature I would like introduced.
ZZMystique
My setup: Server: SageTV v7, Intel i5, 8GB, 180GB SSD, 4TB HDD, Win7HP & (DVB Viewer Pro with DVB Viewer for SageTV using 2xTBS6281 DVB-T2).
Old 08-03-2008, 04:36 PM
Is this a feasible option, or does anyone know of a paid (or free?) option? I wouldn't even know how to code it, but as much as I can automate things it would be nice ...
Currently my clock doesn't drift hardly at all, but "getting it right" is the science project.
Is this something we can submit to the Sage team to add an offset subset to the "sync with server" option of the clients?
Old 08-03-2008, 07:04 PM
Why doesn't padding work? This is exactly the reason for having the padding option. We pad everything we record.
Old 05-25-2010, 06:36 AM
I hate to dredge up an old topic but .. has this been addressed in version 7 somewhere?
Yes, padding works, but we'd like a little more tweakability, like on the order of seconds not just minutes. Sometimes the last 15 seconds of the show are where the "cliffhanger" and it's cut off because of time drifts between networks ughhh ..
Is there a secret [or public?] setting in v7 beta somewhere, for show-specific padding of fractional minutes (i.e. 1 min 10 seconds, 4 seconds late start, etc)?
Cheers
