Am i the only one that want's to see animations in the ui?
I would like to see a smoothly animated ui. Thats the only thing that gives me mce envy? Anyone else?
I'd quite like animated menu transitions (e.g. from main -> TV Guide, etc) .
I also have MCE 2005, although I don't use it (I could never get the TV quality any good - wheras with Sage it's superb). I did like the menu transitions, and they had a good WAF. If sage or any STV author ever does anything like that, it would be cool, but I'd also want the option to switch them off - they did get on my nerves after a while !! Cheers Mark |
The option would be nice and be a nice addition to the UI
Only as an option you can turn off! Turning off animations in the UI is just about the first thing I do when I install any OS!!
I can't get those nanoseconds that it takes to animate things back! ![]() No offense intended, everyone has their own preferences.
Wayne Dunham |
I'm well up for some animations. The MCE 2005 UI is the most slick UI I have seen yet, and part of it is due to the animation. I personally think that the (very simple) animation in 2005 adds to the quality 'feel'.
I agree that it should be turn off-and-on-able, so as to please everybody. Do we actually know if this is possible in Sage? How hard would it be to imlement? |
It is possible to do, I almost did it for SageMC. However, since I have them turned off in MCE myself I never took the time to do it.
STV Tease
![]() Cheers Mark |
i'd be a non animation user. eye candy is not for me - just a nice clean interface which is exactly what mlbdude provided.
speaking of which, mlb, do you anticipate adding any of the new 3.0 options to the setup list in sageMC? actually the one which is current that i find more important is the "refresh imported files" button. before i worry with 3.0 i need to figure how not to have the channel changes freeze first and when i get that licked then i'll worry with getting FSE to work. beyond that (and with CD playback added) i'll be one pretty freaking happy camper. oh i'm a liar - i want a real, productive, multi format, with dvd built in, extender too!!!!!!! ![]() |
You can refresh your import files individually in each library with the Options command. A new STV with some features from the Detailed setup area will be coming soon. Once the 3.x beta stabalizes a bit.
thanks, mlb, i always thought i was a moron but at least you helped confirm it!
![]() still trying to figure out the FSE vmr9 right now. the yes setting will stick for me but when it does work it's still quite choppy and doesn't look very good and then other times it will just error out. i think this is more related to my screwing around with quartz.dll files and old files/multiple driver installs than it is a sage problem though. i have a fresh drive with win xp pro pre loaded though so i might drop it in the htpc this weekend and play around. |
I'd be a big supporter of UI animations. I guess it boils down to how you use your system. Those that also use it as a computer probably would disable it, but for me I prefer making my system as much like an appliance as possible and animations go a long way toward hiding the fact that it is a PC at heart.
-PGPfan |
I wouldn't mind seeing some animations in the UI, with the caveot that they only do something when a task is selected. I do not care for animation for the sake of animation, like the MS Office help charactors.
I may add some to SageMC. In MCE they are crappy though cause they actually slow down your actions. They are nice to see though
Good news!
I'd agree that it'd totally be nice to have the bells and whistles of the MCE UI. But its not that high on the 'things I'd like Sage to do' list
(read: the SageMC UI rules!!!! ![]() ![]() ![]()
My persional PVR: Intel Celeron-D 2.66 GHz, 512 MB, Hauppauge PVR350 (incl. remote control), XFX-5200, 2x160 GB HD, WinXP MCE 2005 (ex-SageTV user) |
I remember having it in my code at one time along with the rotating A in Sage a while back, but I took it out as the PVR350 slowed to a crawl for me. But turning it off would be a great idea. Lauren |
Hi Lauren,
If I remember right, the animation of the MCE menu (starting at the 'Home' page) had selections for TV, DVD, Music, Photo's, etc. When you selected say "Music", the screen would instantly leave the home screen and then (beginning small and in the center of the screen) zoom toward you to fill the entire screen. This all took place (the zooming at least) in about .25 of a second. I believe that an animation during screen transitions would be nice IF done correctly. To me, correctly means instantly leave the current screen (since, if you are leaving it you no longer care to see it) and animate the introduction of a new screen. Sounds silly, but what it does is actually add a little subconcious 'excitement' to the NEW screen. -PGPfan |
If any of those with studio out there are reading - i would be more than happy to supply some animated icons and whatnot, just let me know if you want to work on something. not too busy this summer...
-kayoti |
Having a little animation in the menu customization import would be very nice. It doesn't have to be anything complicated, just a little movement would look cool.
