Old 05-09-2006, 02:17 PM
alon24 alon24 is offline
I am sorry for hijacking this thread, but...
Is there a way to have a table (like the one with nielms menus, that shows comming recordings) and that pressing left will move forward in the table and right nove back?
I ask this because if we want to localize Sage for hebrew (right to left writing) we need to change that.
Again sorry for hijacking...
Server
SageTv 6.3.5, Core2Duo 6300 ,2Gigs ,Saphire x1650, PVR250, 2*320GB + 160GB, java 1.6.1
Client
SageTV Client 6.3.5 , AMD 3000, 1024Mb, Saphire x1600Pro256HDMI, java 1.6.1
Using Nielm's Web server 2.22
Old 05-09-2006, 02:27 PM
I stuck it in its own thread.
It depends on what you mean... if you want to change the direction that those arrows go, you could override the listeners for those commands & change what they do.
If you want the table to show things in reverse order, you could change how the data is sorted before it is fed to the table.
One of those might do what you are thinking of.
Old 05-09-2006, 02:55 PM
Ok, so I took your advice, sorted in reverse and changed the numbers to show (NumPages - TableRow) .
How do i make the table show the last item, so that will be the default when trying view it?
(instead of starting with showing row 1- show row 8- last one)??
Server
Client
Old 05-09-2006, 03:08 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Put an attribute called DefaultFocus on your table items, and make it false for all except the last item, which should be true. See p. 48 of the Studio manual.
-- Greg
Old 05-10-2006, 04:09 AM
nielm's Avatar
nielm nielm is offline
.. or if you want it visible but not focused, in AfterMenuLoad hook, call EnsureVisibilityForVariable with appropriate args...
