Loading Preview. Please wait, and wait and wait...
This is an ongoing part of my troubleshooting...
I have 3 identical Hauppauge PVR 150 cards (OEM from pcalchemy). One of them seems to have a problem. In the video sources setup, When I select the input, it does not generate a preview. The other 2 cards do generate a preview. I assume this is a hardware problem, but I wanted to ask if it is possible that I'm doing something wrong in setup. |
This has happened to me in the past. I have a Hauppauge Rosyln and PVR 150. This usually only happened when sage got shut down unexpectedly due to a power failure. Upon reboot--I had to reinstall my tuners (this issue was fixed in a recent release though). Anyway, when I went to reinstall my tuners--one would always hang on the preview screen. I think I was able to fix it by doing a combo of things. First. Restart your computer and see what happens. Next, try reseating your card or moving the card to a different PCI slot. Restart again. Hope it helps.
JUC
Server: Athlon 2000XP; 1GB Kingston Ram; 250GB Seagate; 160GB Seagate; 160GB Western Digital; Lite-on DVD player; Hauppauge Rosyln; Hauppauge PVR-150; ATI AIW 7500; Actisys 200L; running stock v5 .stv Client: MVP Extender running SageMC |
"hanging" on the preview is a known issue on the forum, you should be able to just go past it even though you don't get a preview. IIRC, I just hit the OK button and it goes to the next screen.
So, as long as you pick the correct input, it doesn't really matter if it loads the preview. |
reinstalling clean (deleting program files folder) fixed the probem for me
I've seen this everytime I've had to resetup my tuners too.
