.stvi imports with 6.013 not sticking
I submitted this bug, but wonder if it is only me?? Since upgrading to 6.0.13 I can't seem to get Sage to import any of my .stvi packages.. rather, they import but Sage does not create a new .xml file that incorporates them so when you close Sage it starts back with the stock .xml file.. so there are no *-1.xml, *-2.xml and such created...
Anybody else seeing this? |
I see this to, the stock stv file does not change and a new one is not created but the imports are working in the current session. I used studio to save the stv to a new file and that kept the imports.
Ditto for me. I used the import STVI to import several STVi's and that DID work. But I cannot select one and have it stick or create a new stv. Tested several times. It will stay for the one session only.
When I closed Sage to try a restart it told me that changes were made and asked me to save them. I did and it modified the existing stv without creating a new one. When I reopened it it had the same file name but all the new changes. Definitely a bug. I am sending my log files. |
Thanks! |
You can save the STV by opening Studio (Ctrl+Shift+F12), then use the "Save As" command in the File menu.
If the the original SageTV3.xml file gets overwritten, it can be downloaded here. - Andy
This surely could not have been missed in beta testing geez. This is so annoying. Setup all the clients reboot and all the changes are gone. All my clents are keyboardless and headless. Not easy to a (Ctrl+Shift+F12)
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. |
I can confirm that this is happening for me too in 6.0.13. Importing stvi's loads them in the current session, but does not write a new .xml file, so when you power cycle the client, the stvi's are not loaded anymore.
If your clients don't have keyboards (like mine), do it on the server. |
![]() Gerry
He fellas stop picking on me LOL :-). I got over it sniff!!! :-(
Fixed for next build
Got confirmation just now from Sage that this bug has been found and fixed for the next build.. though we don't know when that will be... for now using the Studio 'Save As' method seems to have worked... If you have mvp's, like I do, I simply closed Sage and then edited the clients properties file to use the .xml file I saved using the above 'studio' method.. then restarted sage, went and unplugged all my MVP's and then re-plugged them in to force them to reload.. all is well for now..
If you install my Menu Shortcut Bars plugin any STVi you import after it will automatically be saved after the import as a side effect of my plugin. You will need to use Studio after importing my plugin to save the changes but all other plugins after that will get saved automatically.
Here is why: The plugin runs code after every import to look for Custom1-5 commands in anything imported and transfer the code to it's local menu so that the Custom1-5 commands are thereby intercepted from any menu in the STV. After it moves this code it saves the the current STV whether there were any changes or not. Sorry to hijack the thread to plug my own STVi but I thought this might help some folks with later imports if they don't want to get into studio to save the changes each time or just are worried that they might forget and have to do it again. This "feature" of my plugin will work very well on an MVP with this SageTV bug. Also I thought once installed you might like the features it makes available. BobP. |
importing stv's don't stick after restart?
I didn't see anyone mention this.
but with 6.0.13 when I import any custom stv's it works fine and then when I exit sage and come back to it I am using the default STV. can anyone else confirm this? * Merged with existing topic * |
Big Gerr _______ Server - WHS 2011: Sage 7.1.9 - 1 x HD Prime and 2 x HDHomeRun - Intel Atom D525 1.6 GHz, Acer Easystore, RAM 4 GB, 4 x 2TB hotswap drives, 1 x 2TB USB ext Clients: 2 x PC Clients, 1 x HD300, 2 x HD-200, 1 x HD-100 DEV Client: Win 7 Ultimate 64 bit - AMD 64 x2 6000+, Gigabyte GA-MA790GP-DS4H MB, RAM 4GB, HD OS:500GB, DATA:1 x 500GB, Pace RGN STB. Last edited by gplasky; 11-01-2006 at 07:15 PM. |
STV Importing not working properly
Not sure if this is a user error or bug, but I just noticed the STV import function is not working properly. I uninstalled my SageClient, deleted the program files\sagetv directory and reinstalled the Client. Now when I try to import STVi's no "backup" of the original STV is made. I also had to install some imports two or three times before they showed up in the STV. (Web Radio, Intelligent Suggestions, EDL ComSkip.)
Anybody else seen this or do I need a refresher course on importing into STVs?
This is a known bug with 6.0.13 and is said to already fixed for the next release. Until then there are several workarounds.
One is to use studio to save the changes to the stv after installing all of your imports. If you do a search you should be able to find plenty of information on the other methods. |
I merged the latest question about this with the original topic & made it sticky until the next version is released.
I hate to be a grouch, but do you guys really have to fix 4096 bugs before you release the next build? Can't you just realease a build with what you've fixed already? It's been 2 weeks since we've been hearing that this has been fixed, and that's been fixed, but no new build on the horizon yet. Any time estimate at least?
