Old 11-09-2007, 05:31 AM
sainswor99's Avatar
Animations in 6.3.1
Since the Animations are no longer secret, I thought I'd create a new thread. I searched the old thread, but didn't find an answer, but did find a related question:
Originally Posted by sundansx View Post
Tried them out...quite nice.
Narflex...could you add an option in properties or customize menu to enable the user to change the transition speed? I like the animations, but want them to transition faster.
Thanks.
Originally Posted by Opus4 View Post
The STV currently in development has options to enable/disable various animation categories. And, there are properties you can change to set the duration for them.
Under Setup--> Customize --> Animation Options, I see I can turn some of the animation options off, but highlighting the buttons is not one of them. Everything else looks great; just the highlights don't work so well for me.
I'm using Placeshifter on a LAN with a mouse, and while I really like the menu transitions (the slides, etc), the hovering highlight (following my mouse) is a bit slow. I can usually click the button before the highlight gets there. Without the animations (6.2), the highlight followed the mouse much closer. Is there any way to adjust the speed of the animation or turn it off for the highlights?
Thanks, Stu
Old 11-09-2007, 06:32 AM
The ui/animation/focus_transition_duration property should control the focus animation speed. There isn't an option to disable it, but setting the duration to 0 should have that result.
Old 11-09-2007, 08:08 AM
sainswor99's Avatar
That did it; thanks, Andy.
Link Animations to Menu Items? jagee23 SageTV Customizations 2 07-24-2006 07:03 AM
Am i the only one that want's to see animations in the ui? blackgold9 SageTV Beta Test Software 28 10-02-2005 08:09 AM
UI Animations Droid SageTV Customizations 7 10-17-2004 04:37 AM
