SageTV Studio Discussion related to the SageTV Studio application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the Studio software application should be posted here. |
Resizing Tables
In my AMG project that I'm working on (Advanced Mini Guide) I've got a table that gets the number of rows from a property. This works pretty well, however I'm seeing something weird when I try to change that property at runtime.
It seems like the table is limited on the upper end in size to the initial size it was when it is first created. For instance, if the property is 5 when Sage starts, I can change the property and see the table update from 5 to 4 or 3 or 2 or 1. But if I move it up to 6 rows, it still displays as 5. If I leave the property at 6, and restart Sage, then it shows up as 6 the next time it is drawn. btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
Table size can't be changed dynamically, like you've been trying. I do this in several places in the default STV, but I take other steps to make sure the table uses the new values for the number of rows or columns. I essentially set the new size, then reload the menu where those new values are used.
To pick one menu w/a resizeable table, see the "LiveTVGuide w/ Optional Preview" menu in the default STV. The BeforeMenuLoad hook checks to see if the menu needs to be reloaded with the correct grid size, sets the appropriate static contexts, & then reloads the menu. During the following menu load, it will see that nothing needs to change & just continue. Note that if you follow the reference widget to see where this is checked, you will see a "Back" command used if the grid resizing is done while the menu is already loaded. This prevents the user from seeing the old grid size if they try to use Back later. Calling the API function to clear the menu cache might accomplish the same thing (haven't tried it), but that will clear the cache for all menus instead of just the one being changed. - Andy
I don't know if this helps, but I had to set up resizable tables for the icon based main menu in SageMC. I wanted the size to change on the fly without having to exit the pop-up options menu. The way I did it was to pre-define a number of table widgets, each with it's own number of rows and columns. The contents of each table is just a linked reference to the same code, so that each table contains the same data. Then I essentially use a case statement to choose the table with the desired dimensions. This actually seems to work quite well. It isn't quite as compact as Andy's method, but I suspect you will only have a few variants so it shouldn't be too bad.
Your other option would be to use panels for all of the items in the AMG instead of tables. You can then change the size by just enabling/disabling individual panels. The advantage of this approach is that you can use AnimateTransition to animate the movement of the contents between all cells, including the large focused cell. You will be able to see an example of all of this in the fixed focus icon menus in the next release of SageMC. Feel free to PM me if you want any help on this and I'll give you my e-mail address. I will definitely be using this mini guide when it is done, so I have more than just a passing interest in it. ![]() Aloha, Mike Last edited by MeInMaui; 01-22-2008 at 01:04 PM. |
Thanks for the tip Andy.
Luckily I didn't run into that problem. (and I ended up with 60 table variants to choose from! ![]() Guess I got really lucky, as my widget chain leading up to the table is very short. Aloha, Mike |
Navigation wrapping and scrolling tables | MeInMaui | SageTV Studio | 9 | 12-21-2007 02:53 PM |
Video resizing problem | Chroner | SageTV Software | 0 | 08-24-2007 11:46 AM |
Troubling Tables | kuch68 | SageTV Studio | 5 | 09-13-2006 01:06 PM |
2.1.10 - TV not resizing or slow resizing when go between menu PIP to fullscreen TV | ruel | SageTV Software | 0 | 11-04-2004 01:17 AM |
Overlay Resizing | CanadianEh | SageTV Beta Test Software | 12 | 04-21-2004 06:08 AM |
