Old 02-02-2008, 03:24 PM
klaberte klaberte is offline
Help! No STVi imports working!
In the past, I've had no problems adding stvi's. However, today I tried to install the auto compress stvi and "it didn't work", meaning, after several restarts of Sage, there was no evidence that anything had been altered.
Curious, I set the stv back to SageTV3.xml and tried to reinstall the simple web radio plugin (which before today had worked fine). Now, after trying to install this, the simple web radio plugin "doesn't work", i.e. it is nowhere to be found in the online services.
What am I doing wrong? Is there something besides setting the stv back to SageTV3.xml to roll back the upgrades? Help!
Old 02-02-2008, 11:27 PM
srothwell's Avatar
srothwell srothwell is offline
Since upgrading to 6.3.8RC I've also had problems with STVi's, but only one..... autoCompress.
The issue seems to be that the "cursor" no longer works. It will import OK, but if you try to do anything like detailed setup or something that the Sage cursor needs to move, it won't show up.
Going back to an STV that doesn't have Autocompress makes it work.
The STVi's I have that still work are: Dynamic Menus, AutoAspect and IMDB.
I suspect it has something to do with the expanded Favorites. AutoCompress integrates with Favorites so maybe everything got messed up.
Stacy
Old 02-03-2008, 12:43 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
What version of Java are you running?
John
Old 02-03-2008, 10:24 AM
1.4.2. Thanks for the idea. I'll update and report back...
Old 02-03-2008, 11:07 AM
Yes, updating to JRE 1.6.3 did the trick! Thanks for the quick help!
Vbox Cat's Eye 3560 stopped working after scanning for channels cord Hardware Support 3 01-20-2008 02:13 PM
Is there an easy way to generate an stvi? stuckless SageTV Studio 2 10-09-2007 09:17 AM
creating STVi matrix35 SageTV Studio 6 02-25-2007 06:48 PM
Translate STVi owilsky SageTV Studio 10 10-21-2006 07:46 AM
STVI loaded twice..help...please garyellis SageTV Software 7 07-28-2006 04:53 PM
